Left headlight sometimes on sometimes off
Old Nov 12, 2023 | 10:35 PM
nelgin's Avatar
Hi all,
I'm got a 2007 Maxima and recently my left headlight went out. Oddly when I turned the lights off and back on it came back on. Occasionally it'll flicker but often turning off and back on gets it going, at least for a while, so I know the bulb is good (or should be).
I don't suspect a loose cable since turning off and on again starts it up, and same for the fuse.
From the videos I've looked at it could either be the ballast or the harness that connects from it to the light fixture.
Obviously, I don't want to buy 2 parts but then again, I don't want to go through the whole process of removing the light fixture twice. So what would be my best bet to diagnose which parts is most likely the bad part?
Thanks,
Old Nov 13, 2023 | 03:41 AM
Les7311's Avatar
Most times it’s the LED bulb going bad
replace both when doing surgery - not hard
Old Nov 13, 2023 | 04:49 AM
Maxgig's Avatar
Like Les7311 said change them both at the same time. the reason being I've found is that the bulbs get dimmer over time from age and use. If you just change one you will definitely notice a difference in how bright the new bulb is over the old one.
Old Nov 13, 2023 | 06:10 AM
Les7311's Avatar
On my ‘11, Stealership wanted over $100 for one bulb,
looked over the EBay and found both for little under $30
happy DIY surgery on delivery….. / half lower the front bumper / Utube for instructions….(again, easy..)
Old Nov 13, 2023 | 08:23 AM
nelgin's Avatar
I guess I'll change the bulb first and then see where we go from there.
Thanks,
ashtserur
Nov 16, 2022 02:25 PM
spreenyk888
Mar 20, 2012 01:01 PM
headhunt3r
Dec 6, 2007 09:27 AM
Nisman
May 29, 2005 12:05 PM
Nismotic
Jun 20, 2003 01:34 PM
