ABS, TCS off & Slip light all on
Old Mar 30, 2026 | 06:39 PM
lawd5353's Avatar
My ABS, TCS off and SLIP lights are all on on my 2008 Maxima (130,000 miles). I have replaced both rear bearings and wires, Issue went away for a week. Car will run fine, then when I push the throttle the car will act like it is struggling to get the power down for maybe 5 seconds, then the ABS, TCS and slip light come on and the engine issue stops until the light goes off again. It only happens once a drive as the light will sometimes clear after I turn the car off. I have put a throttle position sensor on the car as well to see if that helps as I read that could be a cause, with only little improvement.
Old Mar 31, 2026 | 10:16 AM
slvr2KSE5's Avatar
what fault codes are present?
Old Apr 1, 2026 | 05:21 AM
lawd5353's Avatar
C1110 - ABS Control unit internal fault
C1106 - LR wheel speed sensor signal (already replaced)
P1564 - Automatic spew controller device switch (not sure if this is relevant)
Old Apr 1, 2026 | 08:07 AM
slvr2KSE5's Avatar
p1564 isnt related to the abs problem. its acsd switch circuit malfunction (usually a broken clockspring).
the c1110 is concerning. there is a TSB for 04-07 that addresses the concern. 08 may have the same issue but was not included. NTB07-016 but it seems the ecu is the common cause on 2008 years.
youre going to need to scope both rear sensors and watch the pattern for any inconsistencies.
Nateg12
Mar 9, 2024 01:19 PM
egali045
Apr 2, 2015 10:20 AM
danielm5486
May 31, 2009 06:59 PM
KLOOGY
22
Apr 23, 2004 10:19 PM
