Morning Brake Pedal
Old Jul 19, 2011 | 12:58 PM
yvnrg1981's Avatar
Morning Brake Pedal
Ok so this started happening several months back...but hasn't affected anything at all. After leaving the car for several hours the brake pedal would be like a rock. You know if you pump the brakes after the car is off until you can't really pump them anymore, well that's what happens after several hours of the car standing. As soon as I start the car all is fine. Any thoughts?
Old Jul 19, 2011 | 07:50 PM
Antny74's Avatar
mine does the same, I'm guessing it is normal
Old Jul 20, 2011 | 07:22 PM
Lanzz's Avatar
Mine did that after the dealer replaced the master cylinder. Never figured out why, because I had enough issues with the car, that I traded it in that way.
Old Jul 20, 2011 | 07:47 PM
NismoAltimaGuy's Avatar
Maybe similar issue to this that the Altima has with the vacuum line...
http://www.nissanclub.com/forums/200...-its-cold.html
Old Jul 20, 2011 | 09:21 PM
sg1214's Avatar
It could just be because when you start the car the power brake system comes on, Power brakes are turned off when the car is turned off. I know what your talking about, and Im sure its normal.
Old Jul 21, 2011 | 08:37 PM
Antny74's Avatar
*Bumpin this thread* so that others will say yes or no to this occurence on a daily basis?
Old Jul 23, 2011 | 05:18 AM
Dan0076's Avatar
I have a '09 and just recently noticed this. I have a 136k miles and never really noticed it before. I also recently had a tune up done at a Nissan dealership (at 135k). I will mention this when I go back in next week and see what they say.
Old Jul 24, 2011 | 01:05 AM
lightonthehill's Avatar
This is exactly the way my car behaves, and exactly the reason why it behaves this way. I would be surprised if it behaved any other way.
Old Jul 25, 2011 | 11:37 AM
yvnrg1981's Avatar
I would understand if that's they way it always behaved. Keep in mind it only started doing not to long ago. Wouldn't it make sense for it to always do it from the start if that's the way it's supposed to be.
Old Jul 25, 2011 | 12:38 PM
IFuXwiTuZ's Avatar
that doesnt happen to my car
Old Jul 25, 2011 | 11:51 PM
You are the one who knows your car best. If you are sure something has changed, I would think a visit to your dealer would
be in order. I tend to agree with you that, however the car does things, it should not change the way it is doing things unless
something has happened.
When it comes to brakes, we need to be absolutely sure.
Old Jul 26, 2011 | 08:24 AM
njmaxseltd's Avatar
The brake booster is operated by engine produced vacuum.
When the engine is off, there is no vacuum and the brake booster may bleed down over time. The result is the hard as a rock brake pedal.
mpbclutch33
Dec 26, 2015 11:11 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
