To those ONLY who has or had V2 Spacers... Experiences????
Old May 7, 2012 | 07:01 AM
Jbling700's Avatar
I'm buying v2 spacers off of somebody on this org and I need to know has anybody had good or bad experiences with it... What Torch is recommended???
Old May 7, 2012 | 08:41 AM
Ghozt's Avatar
make sure there isn't any damage to them, improperly installed spacers (or improperly removed) can be damaged by overtorquing during install or prying them off during uninstall. torque them to manufacturer recommended 75 ft/lbs and then re-torque them again after 500 miles (which requires taking the wheels off).
Old May 7, 2012 | 03:29 PM
Jbling700's Avatar
Thanks Ghozt... I forgot you had used them in the past LOL It's only for the rears anyways...So after I re-torque 500 miles, that's it??? I'm good to go or re-torquing once more?
Old May 7, 2012 | 04:13 PM
Ghozt's Avatar
you can check them again if you want to be safe but they should be fine after that. i needed a 4 wheel alignment after putting my spacers on though fyi
Old May 7, 2012 | 08:09 PM
Dieseldan's Avatar
no problem here have the same kind ghozt has
makes a HUGE improvment on looks to stick wheels out where they should be
did same thing torque then retourqe only one was slightly loose when checked
Old May 7, 2012 | 10:09 PM
Jbling700's Avatar
Ok thanks for the info Ghozt and Dieseldan.... I hope this was useful to people who are curious also LOL
Old May 8, 2012 | 05:29 AM
PSU09MAXIMA's Avatar
does adding spacers do anything like making the tires wear quicker or anything like that?
Old May 8, 2012 | 06:24 AM
GM_Traitor3.5VQ's Avatar
As long as your toe and camber are still within spec, nope
Old May 8, 2012 | 07:10 AM
thanks I'm still basically new to mod scene appreciate the help
Old May 8, 2012 | 08:18 AM
Jbling700's Avatar
I don't know but all I know that it makes the Stance of your car wider if you want to keep your factory 18's or 19's....
Old May 8, 2012 | 08:38 AM
Not a problem! You can figure that most mods like lowering springs, coilovers, new wheels with custom offset, wheel spacers or longer endlinks are going to throw off the factory suspension geometry and will require a 4-wheel alignment.
Speaking of which, I still need to get my 4-wheel alignment done this week
Old May 8, 2012 | 09:06 AM
Yeah I dont plan on doing anything with my suspension bc up here in PA the roads suck period. I was just thinking of doing my stock wheels making them sit flush
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Pied
Sep 26, 2015 03:29 PM
TxBroncosFan
Sep 21, 2015 06:54 PM
lrb6805
Sep 18, 2015 07:07 PM
