Viper SmartStart
Old Jan 3, 2014 | 05:23 PM
Hawks102089's Avatar
Viper SmartStart
I have a few questions I can't seem to find answers to online. I found a place to install the VSS3001 for $429.00.
I want to know two things:
1) when I start the vehicle from my phone, do I get a conformation or anything that my vehicle has started?
2) How long will the vehicle run before shutting off? And what are the options for how long it can run?
Old Jan 3, 2014 | 05:42 PM
Ghozt's Avatar
yeah you'll get confirmation that the command was received. you can also update the status page to see if the remote start is running or not. default time is 10 minutes but you can adjust that, generally though longer than that isn't going to do much besides waste gas
Old Jan 3, 2014 | 06:25 PM
Excellent, thanks! Also, I was curious as to how this works with push to start? When I get in the car, what do I do to start driving? Do I just have to his the button I usually hit to start the car and go? I've read some remote starts you have to shut the car off and then restart it which would just be annoying
Old Jan 3, 2014 | 09:48 PM
pdub34's Avatar
Ditto to what Ghozt said and also it's more reliable now than it used to back in 2010.
Old Jan 4, 2014 | 07:11 AM
Ghozt's Avatar
for Vipers it depends on the firmware they flash your unit too, if its the older firmware then you get in and press the start button twice then put your foot on the brake and go. if its the newer firmware once your car detects the OEM keyfob, you have 15 seconds to get in and put the car in gear or it turns off
Old Jan 4, 2014 | 05:23 PM
Thanks guys. Getting it installed on the 19th since that's the first available appointment. Can't wait
Old Jan 16, 2014 | 12:48 PM
For those of you with expierience, is it worth the extra $150 for the GPS feature? I don't see the use for it but wanted to hear from those if you who might have it and have a good use for it.
Old Jan 16, 2014 | 09:20 PM
pdub34's Avatar
$150 for the yearly fee I am assuming? I pay the $70 one it's good enough unless u need the other features.
Old Jan 16, 2014 | 09:34 PM
Ghozt's Avatar
heres the trick, after it expires wait a month or so Viper will send you a special offer. I just renewed annually for smartstart+gps tracking for about $60 for the next year. i can do without it for one month lol
Old Jan 17, 2014 | 07:05 AM
I was originally just getting the module for the lock/unlock and remote start. I was considering getting the one with the GPS but trying to figure out if that module was worth an extra $150.
Old Jan 22, 2014 | 06:45 PM
smokin5s's Avatar
GPS module is not needed since when you lock the doors, and your phone has a GPS, it will mark the car location at that time so it's easy to track back down... the only time it would be needed is if the car is stolen.
BTW, I've had my smart start for just over a year, the only issue I want to call out is if your battery is weak, it won't start.
Old Feb 9, 2014 | 04:06 PM
brooklynboss22's Avatar
Is it doing good or did you have some problems with it?
Old Feb 10, 2014 | 07:52 AM
pdub34's Avatar
I will try this next year!
Old Feb 10, 2014 | 07:53 AM
pdub34's Avatar
Originally Posted by smokin5s
GPS module is not needed since when you lock the doors, and your phone has a GPS, it will mark the car location at that time so it's easy to track back down... the only time it would be needed is if the car is stolen. BTW, I've had my smart start for just over a year, the only issue I want to call out is if your battery is weak, it won't start.
The GPS comes in handy with insurance and locating your car "live". If someone takes it they might not know u have it and you can track it!
zzznightmarezz
Sep 21, 2015 06:32 PM
tifosiv122
Dec 15, 2001 11:56 PM
SCCA Solo2
Aug 13, 2001 12:54 PM
MrBurner
Jul 15, 2001 04:53 PM
MOBOY
Jul 12, 2001 12:24 PM
