Spacers for the 7th Gen
Old Apr 18, 2015 | 03:24 PM
tehrooni's Avatar
I have factory 18" wheels with Eibach springs. I'm looking for spacers to give the wheels just enough space to look flush from the sides. Anyone can recommend anything? Would appreciate you have links or pictures
Old Apr 18, 2015 | 10:55 PM
1996blackmax's Avatar
H&R DRM Type TRAK Spacers. I have the OEM 19's & I went with 20mm up front & 25 in the rear. Really brought the look of the car together. I bought mine from Stillen.
http://www.stillen.com/product/wheel...sw-114732.html
http://www.stillen.com/product/wheel...sw-114735.html
Old Apr 19, 2015 | 04:00 AM
tehrooni's Avatar
Thanks, I'm having my Eibach springs installed tomorrow and I'm about to order the spacers. Did you need Camber kits? Any issues with alignment? Also with the spacers did you have to constantly check torque or once you put them on they're good to go? Would appreciate your input.
Old Apr 19, 2015 | 07:55 AM
Texakinz's Avatar
Hey 1996BlackMax
I'm also looking into putting spacers on my Maxima, I have OEM 19". I know i want to put 20mm in front and 25mm in the back, my only question is Balance and Rotation. I have read that if you go to Discount Tire for Balance and Rotation, to ask them not to use the airgun, instead to do it by hand. Is any of this true?
Old Apr 19, 2015 | 12:38 PM
Your welcome. In my case, the car needed the rear camber kit to get the alignment in spec. I did take my wheels off to recheck the torque on the spacers after installing them. I do this any time the spacers come off & go back on.
Originally Posted by Texakinz
Hey 1996BlackMax
Putting them by hand is the best way. You do not want them using an impact gun on them. I also go to discount & was told by them that their gun doesnt put a lot of force on the lug nuts.
Old Apr 19, 2015 | 08:28 PM
Daaavid's Avatar
Dependent upon your Discount Tire's management, but the three times that I have went there in two different cities, they handled it exactly the same. The guys used the impact gun to spin the lug nut on with barely any amount of torque, then used a torque wrench to torque down the wheel after it was on the ground. Specify the amount of torque you want considering you have spacers, but they will follow what the OEM specs are.
Old Mar 2, 2017 | 10:03 AM
jgmanni's Avatar
I have a 7th get and I'm wondering the same. Are the H&R's good to go out of the box or do I need to buy any other components?
hot04
Sep 18, 2015 06:14 AM
ik95
Sep 16, 2015 08:11 PM
2012Maximus
Sep 10, 2015 12:50 AM
Wareagle92
Sep 3, 2015 07:18 PM
