Back Up Camera for 2013 SV without NAV ?
Old May 22, 2015 | 09:53 AM
KGMtech's Avatar
I did some research here, but I wanted to know if the technology has improved to allow a nice, plug'n'play rear-view camera to be added to a 2013 SV that does not have factory navigation? My dealer says that Nissan Parts has nothing to offer owners like me
I've got the video inputs in the center console, but if I understand correctly this can only be used if the car is in park with the parking brake applied?
And no, I have no interest in getting Navigation installed...I've always preferred the Garmins to the factory systems for ease of updates and given that most of my driving is in areas that I don't need navigation.
Thanks in advance for any assistance,
Old May 22, 2015 | 10:35 AM
Daaavid's Avatar
You can do a navigation/DVD bypass that allows you to utilize the RCA ports when not in park. The dealer is not permitted to do this as it is illegal, but any outside stereo shop should be able to do it. There are YouTube videos online as well. Maybe you can possibly find a camera that taps into that?
Old May 22, 2015 | 01:22 PM
LWilspeed's Avatar
I was wondering if some place like crutchfield would have an adpater - doesn't look like they offer anything for our car.
However (this isn't exactly what you were looking for) there are some pretty decent back up camera/rear view mirror combos out there. Some have a wireless link as long as you run power to the camera on your rear lic plate and power to the new rear view mirror. Or you could hard wire one in - but you would have to change out the rear view mirror.
Not quite as nice as using the screen already in your dash, but wouldn't be too bad.
Or if you go the RCA route like Daaavid said you could get search rca back up camera. Maybe something like this would work:
Amazon.com : Pyle PLCM18BC License Plate Mount Rear View Backup Parking Reverse Camera, Built-in Distance Scale Lines, Night Vision Waterproof Cam, Zinc Black Chrome : Vehicle Backup Cameras : Electronics Amazon.com : Pyle PLCM18BC License Plate Mount Rear View Backup Parking Reverse Camera, Built-in Distance Scale Lines, Night Vision Waterproof Cam, Zinc Black Chrome : Vehicle Backup Cameras : Electronics
Old May 22, 2015 | 02:52 PM
13Maximasv's Avatar
Since 2013 SV's were available with a backup camera from the factory without the navigation option it seems odd that the dealer wouldn't have parts for it
Old Jun 2, 2015 | 09:31 AM
omario's Avatar
my 2010 SV has a backup camera with no nav from the factory. It's called the monitor package.
Old Jun 2, 2015 | 09:38 AM
dmcmahan12's Avatar
My 2012 also has the back up camera and no NAV. Makes no sense you can't get it from Nissan http://parts.nissanusa.com/nissanpar...partcode=28442
This is what I found and there is a part number for it.
Old Jun 2, 2015 | 10:16 AM
mikekay's Avatar
Interested in this as well. Maybe its to complicated to hook up since it needs to know when you are in reverse to turn on the camera for you correct?
Old Jun 2, 2015 | 10:36 AM
Richard66's Avatar
Another alternative to explore. I have an RV with backup camera and it does not require the vehicle to be in reverse to operate. The screen is built into the sun visor and the on/off switch is on the screen. The only requirement to make it work is the ignition has to be in the on position.
There has to be backup camera kits out there where they can be installed anywhere in the car and no connection to the reverse required. All they need is a power source.
Old Jun 2, 2015 | 10:41 AM
mikekay's Avatar
Kinda kills the convenience though does it not, I mean yes retrofit available (universal systems) but something that would tap into the current wiring would be most ideal.
But if it was super easy I'm sure there would already be a DIY, dont have a service book handy to compare the wiring.
Old Jun 3, 2015 | 05:14 AM
1996blackmax's Avatar
Link to factory service manual (2010)...
http://www.nicoclub.com/FSM/Maxima/2010/
Old Jun 3, 2015 | 10:57 AM
mikekay's Avatar
Thanks for the manual -- but there is no section for AV.pdf for the 2012 -- I dont think they are completely the same as the 2010 orrrrrrrr.....
Old Jun 4, 2015 | 08:46 PM
DennisMik's Avatar
I think the AV.pdf file is missing. If you call up the cover page for the 2012 manual (file FWD.pdf), down towards the bottom it lists an AV section.
Old Jun 9, 2015 | 09:03 AM
mikekay's Avatar
I wonder how these boys do it?
Old Jun 9, 2015 | 09:10 AM
mikekay's Avatar
Upon furthur inspection, they say in the manual for that system:
***FOR CAMERA INSTALLATION ONLY** Locate VI -2 cable in box and connect it to BACK of
Prodigy One at Video in connection point (3.5 mm jack) Yellow RCA is for rear camera input.
Could VI-2 be the 'R' cable we are looking for?
Old Jun 9, 2015 | 09:18 AM
mikekay's Avatar
Or you could even connect it to your reverse lights:
But on the 2012 maxima - the purple wire is the reverse wire:
https://maxima.org/forums/7th-genera...ire-color.html
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
crazyespn
Sep 3, 2015 01:30 PM
Justin Kroll
Sep 2, 2015 11:06 AM
