I finally found out why my eibachs have been makin noise
Old Jun 26, 2015 | 01:07 PM
official_style's Avatar
Also, the strut bearings are bad on both sides. Car is a 14 with 18k on it. I'm really happy right now 😡
Old Jun 26, 2015 | 06:40 PM
Bificus99's Avatar
Dang. I think my strut bearings are making racket, but I have twice the miles. They shouldn't be making noise either.
Old Jul 2, 2015 | 01:26 PM
Just an update, I was still having the noises. I spoke to eibach, they updated the front spring design and are warrantying my front springs. They were very easy to deal with, great customer service.
Old Jul 2, 2015 | 03:48 PM
rEVIL's Avatar
so wth, they agreed to change your both front springs just because of noise, no damages, defects...wow...I thought this noise because of struts or strut bearings(clik-clik-click noise when turning any direction on slow speed)...
Old Jul 2, 2015 | 04:37 PM
It's a loud spring popping noise when you turn the wheels, it's been happening ever since I got the eibachs on. Whe I spoke to eibach, they told me they redesigned the front springs for the maxima because a lot of people are having this problem, and sent me the new ones under warranty.
Old Jul 3, 2015 | 04:51 AM
rEVIL's Avatar
unbelievable, I have that noise since my eibach was installed(couple months), and mechanic thought it could be because of strut bearings...so I`m about to order new shocks and struts...but now I`m comfused...
Old Jul 3, 2015 | 06:57 AM
Bro it's the springs. Call eibach and tell them, and they will send you the new front ones. They switched the front springs from a progressive to a linear spring so it won't have the binding issues.
Old Jul 20, 2015 | 08:38 AM
scotthac24's Avatar
ive been having the same issue since i had my springs put on last summer so after i saw this thread, i called eibach the other day and they told me that they wouldnt have the new linear springs available until the sell out of the progressive ones....
1. does this sound right or should i call and try to get someone else to help me?
2. other than the annoying sound, is this damaging my car at all?
thanks
Old Jul 20, 2015 | 10:54 AM
GNCMaxima's Avatar
FINALLY! Ive been researching non stop since March of last year. I dont know why mine does this and others dont have this problem? I figured there was just a bad batch or something but never thought about calling them.
Old Jul 20, 2015 | 04:03 PM
Bro I have the new springs call back and be like put your f@ckin boss on or something
Old Jul 20, 2015 | 04:06 PM
And it will break stuff like the strut mount thing
Old Jul 20, 2015 | 04:29 PM
Nitehawk11sv's Avatar
So to those of us ready to buy eibachs like today from ebay or such site, what would you all suggest we be looking for? Dont want to buy a bad set and damage the max.
Old Jul 21, 2015 | 06:43 AM
09max_sv's Avatar
Now, any chance you got the part number for the new Linier eibach spring kit ? Perhaps we can order it ahead of time.
Old Jul 21, 2015 | 09:11 AM
MaximaDrvr's Avatar
I know people are saying they want the linear springs, but do you even know what you are asking?
I kind of doubt Eibach would even release such a thing. More linear, maybe, but not linear rate. Are people really willing to sacrifice their ride quality for 1" drop?
Old Jul 21, 2015 | 09:17 AM
pdub34's Avatar
Never had this issue, maybe it's a new design for the newer Max's?
Old Jul 22, 2015 | 08:38 AM
Sir Tilus's Avatar
My springs were/are doing the same thing and I now understand why. After speaking to tech support he confirmed that there would be no safety or damage concerns with the spring noise issue. Unfortunately I was not able to get a new set of springs right away but they should have them in a few months. They took all of my info down, now I have to send them proof of purchase which is fine and once the old stock runs out, they will start sending out the redesigned springs...the noise if more annoying than anything and it's been a few months since the install...I can wait a couple more months!
Old Jul 22, 2015 | 02:10 PM
scotthac24's Avatar
i just got off the phone with eibach for the 2nd time this week and they told me the same thing....as long as its not doing any damage, i can deal with the noise...hope they get the new ones in sooner than later tho
Old Jul 22, 2015 | 08:29 PM
Dudemaine's Avatar
+1 that I've never had the issue either and my springs were installed in February 2014; worst thing for me was that I did not grease poly bushings enough and had to re-do to stop squeaking and I've been fine ever since.
Old Jul 24, 2015 | 04:22 AM
Here is one of the new springs they sent me
Old Aug 6, 2015 | 12:34 AM
MississippiMax's Avatar
Has anyone had trouble with the rear springs creaking and moaning? I just got mine on today and the fronts are quiet as hell, my rears are definitely making noise though. Mostly over bumps and uneven terrain and not really while I'm turning
Old Aug 6, 2015 | 12:37 AM
The back noises will go away unless the sway mounts need grease
Old Aug 6, 2015 | 06:35 AM
Sir Tilus's Avatar
Awesome, curious to know if the design has fixed the issue...let us know after you have them installed!
Old Aug 6, 2015 | 01:23 PM
maxud's Avatar
you sure its the springs and not stabilizer bar bushings?
I had the creaking rear end when I bought the car. There was a TSB
on that, which I brought to the dealer. After that, I had no more noise.
I guess you will have to experiment with bouncing your car while listening
for the source of the noise.
Old Aug 6, 2015 | 02:26 PM
We did also install a racingline RSB with RL rear end links at the time of the install but greased the bar and bushings like crazy. Does anything need to be done to the endlinks?
Old Aug 6, 2015 | 03:57 PM
I'll post pics of the install later just to double check me and victor did them right but like I said we greased the bushings and the noise only comes from up and down motions like it would be the springs so I might give it a few days before I jump to any conclusions unless the endlinks are too tight or need to be greased as well
Old Aug 6, 2015 | 05:17 PM
maxud's Avatar
the noise I was speaking off also came back from the rear end and also only when going up and down, specifically going over speed bumps.
If your end links (stabilizer bar links) have grease zirks, then you definitely need to grease them. If they are sealed, then no greasing is necessary.
I guess one quick way to tell if its stabilizer bar related or spring related is to disconnect the links and bounce the car.
Old Aug 6, 2015 | 07:03 PM
rEVIL's Avatar
well I had some clink-clink noise at rear suspension, but this was even before my ebachs...so couple days ago I changed shocks and struts with mount kit, rear and front stabilizer bar links, rear bushings...and that noise gone. Just still have on front popping noise when turning any direction on slow speed, so now I`m 100% sure this noise is from springs, but I tired to go back each week to mechanics and trow out money and time...I can live with that for now...
Old Aug 6, 2015 | 09:36 PM
I'll go ahead and tell you I don't know what a zirk is, the end links are from racingline, do those bushing need to be greased as well as the bushings holding the bar? Already greased up the latter
Old Aug 7, 2015 | 06:21 AM
maxud's Avatar
sorry I misspelled it, its grease zerk, here is what it looks like. Racing line site is down, so I can't tell you if they have serviceable joints or not.
Old Aug 7, 2015 | 09:38 AM
I just jacked my car up and got some white lithium to the end link bushings, on a test drive around the neighborhood it seemed to be progressively getting quieter. I guess only time will tell if I will have to remove the end links and grease them up good or not. It's definitely the endlinks, I noticed the noise when the car would rock side to side and after the initial spray it did seem to help
So... Yeah...
Old Aug 7, 2015 | 10:19 AM
maxud's Avatar
So... Yeah...
I was confused for a second, but then looked up racing line site, which is now up. Yeah, they use completely different style end links with bushings, vs oem style with balljoints. I guess your best bet is talk contact Racing line and ask them what if any lubrication is required for endlinks. In their online instructions they don't mention anything like that.
Mar 12, 2020 12:06 AM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
