Thoughts on Clanking noise?
Old Jun 27, 2016 | 03:04 PM
NCSUpilot's Avatar
2009 143k miles. Noise happens under load while in drive. I typically notice it when driving in neighborhood streets and when I accelerate (even a soft acceleration).
In the video you can't hear it at first from the top, but at 0:16 I go down underneath and you can clearly hear it. At this point, the car is in drive and under medium acceleration (brakes on of course).
Toward the end, we put it into park and accelerate and you can't hear it.
Any thoughts on this? I was initially thinking idler pulley bearings, but it doesn't appear to be localized there.
Thanks for any input!
Old Jun 27, 2016 | 06:00 PM
NCSUpilot's Avatar
Mystery solved...Turns out to be the cuffs around the exhaust. All 4 have broken loose and when you accelerate the whole engine shifts backwards and they lean and start to rattle.
Any thoughts on what to do with those cuffs? Should I take it to an exhaust shop and have them fixed? Or just cut them out?
Old Jun 28, 2016 | 10:35 AM
NCSUpilot's Avatar
Any thoughts on what I should do with these? Should i take it to an exhaust shop...anyone know if they're repairable? Or should i just cut them off?
Old Jun 29, 2016 | 01:30 PM
glockedc's Avatar
Mine are all loose too, I just leave them be. But the local mechanic said I could cut them off without issue YMMV!
Old Jun 30, 2016 | 07:50 AM
LudaTej's Avatar
Exhaust rattle - YouTube
I feel like I have this same exact issue. Only two cuffs were loose when I went under the car so I cut those two off but still getting the rattle. I might take a look and see if the other two came loose as well.
JoshG
85
Jun 19, 2016 04:16 PM
CS_AR
Apr 17, 2016 11:27 AM
ah922
Apr 13, 2016 05:43 AM
Roblee
Apr 11, 2016 09:48 PM
Veloce06
Apr 7, 2016 05:37 AM
