Feel like im buring gas like crazy
Old Sep 6, 2016 | 05:43 PM
hacura3000's Avatar
I feel like im filling up my max too often. Im not sure if this makes any sense but I had a stillen cold air intake on the car and went back factory. Now someone put my aftermarket intake in and i put the factory 1 back in and i doubt i missed any steps. Not sure if this is considered a leak in the pic
I put in a new air filter with the factory intake and put a can of seafoam also in the tank to see if it would increase my mpg. I dont think i need a tune up because i only have 72000 miles.Please any input would help. Thank u
Old Sep 6, 2016 | 05:59 PM
MaximaDrvr's Avatar
That is not a leak.
How many miles a tank are you getting?
Old Sep 7, 2016 | 02:17 AM
Maxima954's Avatar
Bit off topic but did you feel a difference going back to stock?
Old Sep 7, 2016 | 04:46 AM
hacura3000's Avatar
That is not a leak.
I didnt think it was a leak either but i feel like around that opening it should be a little tighter. 280-290 with a full tank and that is with me treating the pedal like a baby.
Old Sep 7, 2016 | 04:47 AM
hacura3000's Avatar
[QUOTE=Maxima954;9124616]Bit off topic but did you feel a difference going back to stock?[
Just a bit, nothing crazy.
Old Sep 7, 2016 | 07:31 AM
Bificus99's Avatar
Mileage in the city that would not be too bad. Highway not so great. Did you feel the stock airbox as better or worse than the intake?
Old Sep 7, 2016 | 09:52 PM
thekevinwright's Avatar
You might be burning through gas dude. I can get a good 340-415 (check it, I actually did 415 once) on a full tank in Los Angeles. Maybe the type of gas you're using is off as well?
Old Sep 8, 2016 | 01:55 AM
hacura3000's Avatar
Thats the type of numbers i want to see. I'll try a different gas company next time i fill up.
Old Sep 8, 2016 | 02:05 AM
hacura3000's Avatar
Online it says high 300 im supposed to be getting city but i do understand wear and tear plays a part. I dont know.
Old Sep 8, 2016 | 07:32 AM
Richard66's Avatar
To find out for sure, top the tank off with good gas, Chevron, Texaco, Shell and take a highway trip of 200 miles, top off the tank again and figure your mileage, you should get at least something like 28-30 mpg, that's what I'm getting on the highway.
Old Sep 8, 2016 | 07:41 AM
Go for it bro! My gas stations are (in preference)
1. 76
2. Chevron/Shell (depending on prices on that particular day)
If you still don't get at least 300, then take it into the shop. But at least two controlled tests to make sure
Old Sep 8, 2016 | 10:09 AM
Mread's Avatar
thats insane. i average about 13mpg city and at max 21mpg hwy. have had the dealer reset the ecm and computer both multiple times. helped for a couple days and then back to ****.
Old Sep 8, 2016 | 05:14 PM
Richard66's Avatar
Nothing insane about it. Been getting that since I bought it 6 years ago. If that's all you are getting then either your foot is in it to far or there is something else with the car that is not right.
Old Sep 8, 2016 | 05:29 PM
agreed. here in LA, i can get somewhere around 40-45 mpg at times. I think it's because the engine becomes more efficient the higher the RPM go. weird, but that's how I keep a good gas tank
Old Sep 9, 2016 | 02:24 AM
hacura3000's Avatar
Ok, i'll try the different gas. Thanks
Old Sep 9, 2016 | 06:31 AM
MadMax07SL's Avatar
Bad plugs would be something to consider too. These are rated at 100K if I recall, but when I had mine replaced on the 07 at about 65k even the dealership was surprised how bad they were with the mileage. They kept telling me to wait, and I insisted. Car drove completely different, and had slightly better MPG.
Old Sep 10, 2016 | 02:29 AM
hacura3000's Avatar
How was your car driving, was it driving roughwith bad mpg?
Old Sep 12, 2016 | 04:18 AM
tnj9's Avatar
The way you drive? When Im pissed off/ running late like tbe past couple weeks have been with me I can get as bad as 260-280ish miles a tank, accelerating fast and lots of harder braking, some idling too. But I've gotten a little over 500 miles a tank on all highway driving for a roadtrip and can get regularly over 400 if I drive with preservation of fuel, transmission, and brakes in mind, otherwise known as cheaply but not grandma-like. Also, usually always use 93/91 (premium) octane. But went cheap in Georgia and put E85 in and ended up with high idle, sluggish performance, and less than 200 highway mpg, obviously that was a mistake and octane and ethanol makes a difference.
Old Sep 12, 2016 | 11:02 AM
MadMax07SL's Avatar
It wasn't too rough before, but after plugs replace the response was considerably better. MPG's improved a little...mostly around town so it was hard to gage, highway mileage wasn't impacted that much as I recall.
Old Sep 12, 2016 | 12:47 PM
mattz300's Avatar
So you're tellin me that if I stop going to Arco I will go from 295 per tank to 350 per tank??
Old Sep 13, 2016 | 02:35 AM
hacura3000's Avatar
Ok, i'll look into that.Thanks
Old Sep 13, 2016 | 02:36 AM
hacura3000's Avatar
Damn thats good numbers wish i coupd that 500 on hwy. im going to try snd chage from racetrac n see if that makes a difference
Old Sep 13, 2016 | 01:47 PM
tnj9's Avatar
I also have went from a KN drop in to a KN typhoon ram air, the ram air seems slightly better due to airflow as the heat guard seems to try to keep the hot air out as there arent any true CAI as far as I know for our Maxes. Yes people say that the warm air that gets sucked in negates any gains but imho the factory scoop that gets preserved sucks in cooler air and heat plate minimizes the amount of heat that gets into the intake and the overall better airflow negates any losses by slightly warmer air intrusion so imo its better, especially in cooler weather but even in summer, had stock setup last summer thru early spring (kn drop in) and went to typhoon after, so far seems to have slightly improved mileage. Also keep tires at 45 psi, no lower, 18" SV non-sport.
enterconnect
May 31, 2016 02:02 PM
Adamlavigne
May 2, 2016 08:43 PM
Benjamjr95
Apr 2, 2016 09:50 PM
Maxima50
Mar 3, 2016 07:49 AM
