Relearn process
Old Sep 13, 2016 | 12:35 PM
Bificus99's Avatar
Relearn process
I was working on my max last week and due to an abundance of caution I unplugged the battery. When complete I assembled everything back and reconnected the battery. I quickly noticed it running differently, not bad but just different. So question is should I do all the relearn stuff or let it do it all on its own?
Found on the interwebs:
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch to “ON”.
3. Turn ignition switch to “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock. 1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Confirm that the accelerator pedal is fully released, then turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old Sep 13, 2016 | 02:02 PM
tnj9's Avatar
I've unplugged my battery to work on my light kit and too noticed a difference in the drive. I typically drive to conserve fuel and read in the manual the car "learns how you drive and will adjust itself accordingly" or something t that effect, could that be why when I try to drive more briskly or goof around with my car buddies it seems to lag because its not normally how I drive and it "re-learned" after I unhooked the battery?
Old May 14, 2024 | 05:41 AM
mrconnections's Avatar
i cannot for the life of me get the position relearn to engage the throttle body; any ideas?
Patsky
Jan 10, 2008 03:19 PM
Smoke_Screen
Jan 3, 2008 04:28 PM
Daily Driver2k2
44
Feb 17, 2005 05:39 PM
mad_maxx03
Mar 19, 2004 05:57 PM
takamine
Jan 31, 2004 03:36 PM
