Coolant Change
Old Mar 9, 2018 | 08:23 AM
MaximusN8's Avatar
Coolant Change
Have another question for anyone who has any info, I'm due for the coolant change on my Maxima and have a question do I have to drain the whole cooling system or just drain the radiator and reservoir and refill with Nissan OEM coolant or should I drain the radiator then run water through the system before replacing with coolant? Some people I've spoken to tell me to just drain the radiator and reservoir and refill with new coolant and call it a day does anyone here on the forum have any insight on this or step by step process on how they've had it done?
Thank You
Old Mar 9, 2018 | 09:08 AM
MadMax07SL's Avatar
Drain, fill with water, you can get a flush concentrate to mix with water, run the engine until hot, let cool, drain again. You could even do a second rinse if you have time, nothing wrong with that, get's all of the concentrate out. Then fill with appropriate coolant.
Old Mar 9, 2018 | 11:46 AM
MaximusN8's Avatar
Thank you I really appreciate the info. I will do that as soon as the weather gets better.
Old Mar 10, 2018 | 08:44 PM
bleedingsujit's Avatar
Be sure to use distilled water.
97_GXE
Jan 26, 2014 08:36 PM
Jonny98max
Apr 12, 2006 12:08 PM
FishyMan
Fluids and Lubricants
Oct 24, 2005 12:52 PM
HarrisH
Sep 29, 2005 04:10 PM
MaxVQ
Jan 8, 2003 03:17 PM
