Fog lights and pass headlight issue
Old Sep 18, 2018 | 05:25 PM
lalo8828's Avatar
hello all, my fog lights and passenger headlight suddenly went out, also the high beam on the passenger headlight
driver side headlight works fine. Checked the fuses and they seemed fine, I replaced them and still nothing. Any input/help would be greatly appreciated. Thanx in advance
Old Sep 18, 2018 | 07:48 PM
Richard66's Avatar
Need a little more information. Model and year of car, mileage, OEM or third party lights, HID's, LED, or Halogen. Someone with electrical experience will help.
Old Sep 19, 2018 | 04:17 AM
lalo8828's Avatar
09 Maxima sv sport. Factory HID headlights and factory fog lights, 79k
Old Sep 19, 2018 | 07:48 AM
Nopike's Avatar
I would give you similar advise as I gave another person with headlight issues.
https://maxima.org/forums/7th-genera...eadlights.html
Section EXL of the factory manual should help you out. The circuit diagram for the headlight is on page EXL51, the fog lamps are on page EXL71. http://www.nicoclub.com/FSM/Maxima/2009/
I would keep things simple. Just look at the head lamp low beam circuit. Is there power going to pin 1 of the low beam headlight? If yes you may have a bad ballast or Xenon bulb.
If you do not have power to your low beam then try swapping the two 15 amp low beam fuses.
Make sure you are getting 12VDC at pin 1 and ground at pin 2 of the headlights. If you have a voltmeter you can compare you readings on the good side with the bad side.
Old Sep 19, 2018 | 08:14 AM
Nopike's Avatar
I believe the four headlight fuses , 15 Amp for low beam and 10 Amp for high. And the high and low beam relays are located in the fuse box in the engine compartment.
Forget about the fog lights, once you get your headlights working properly the fog lights may do the same.
How did this problem come about? Just out of the blue? Did somebody work on the car?
Old Sep 20, 2018 | 06:04 AM
Nopike's Avatar
Seems pretty unusual that your low beam and high beam would go out at the same time and only on one side of the vehicle. I would suspect an issue with the connection at the headlight assembly.
Old Sep 20, 2018 | 07:02 AM
lalo8828's Avatar
Yes it happened suddenly. Lol. Thank you all for the great input. I’m goin to have someone more mechanical inclined look at it as electronics it’s not really my thing. Lol
really appreciate the help fellas. I guess I can’t complain, it’s the first issue the car has ever given me
Old Sep 25, 2018 | 11:55 AM
lalo8828's Avatar
Ok so a lil update. Put new fuses on and the pass headlight keeps blowing the fuse immediately, I even saw a lil smoke from the headlight so today I checked the bulbs thru the wheel well and everything seems ok. I’m still working on the low beam cap cover cause I can’t get that SOB out. It just turns and doesn’t come out and I don’t want to pry it out
I wanna see if the igniter burned. Does anyone think this might be the issue, a bad igniter and bad ballast? Please advise. Thanx
Old Sep 25, 2018 | 05:13 PM
Nopike's Avatar
Disconnect the connector at the bulb/ ballast, if the fuse does not blow when you try and turn the headlights on it means those are shorted and causing the fuse to blow.
jsmith1
Aug 28, 2022 06:19 PM
Blue Milk
Mar 4, 2019 01:44 PM
blackmax85
24
Feb 5, 2014 08:12 AM
SickSE
27
Jul 30, 2011 04:17 PM
bdmaxima
Sep 30, 2009 11:50 AM
