2010 maxima starting problem
Old Dec 8, 2018 | 10:17 AM
jeremywatts33's Avatar
I recently purchased a 2010 maxima for my daughter, I haven’t had any problems until now. The car shut off going down the road, upon investigation I found part of the belt to be broke. I had it towed home so I could replace it but now it won’t start. All the lights in the dash come on when I push the start button but it won’t engage the starter. Any ideas on what I’m missing? All the fuses are good, brake switch good, steering lock good. I need help
Old Dec 8, 2018 | 10:33 AM
Nmax5150's Avatar
Did you check both battery terminals? Are they corroded ? check that Neg cable.. NIssan has a history of the ground side rotting... Make sure battery is good and the connections are tight and not corroded first.
Old Dec 8, 2018 | 10:42 AM
everything is clean the battery is new bought it in August
Old Dec 8, 2018 | 10:47 AM
Nmax5150's Avatar
What is the voltage at the battery? Do you have a Multimeter? Seems odd, just replacing a drive belt, would cause the car not to fire....
Old Dec 8, 2018 | 10:59 AM
it’s checking over 12 volts. I thought the same too so I put it on charge and still getting the same thing
Old Dec 8, 2018 | 11:15 AM
Nmax5150's Avatar
Well.. without looking at the car.. its hard to really properly diagnose the issue... Might sound like a odd question.. is the car is park? lol.. Sorry have to ask....
Old Dec 8, 2018 | 12:16 PM
Richard66's Avatar
Sounds like the steering lock module failure. Nissan has an open recall for 2009/10 to pull this thing out.
Old Dec 8, 2018 | 12:46 PM
yeah I put it neutral and tried to start it. It sounds like a relay or the starter clicks a few times then the fans come on
Old Dec 8, 2018 | 12:54 PM
I suppose the recall was done on it because the lock has been removed
Old Sep 6, 2019 | 06:57 PM
Jarvis71's Avatar
Follow up on 2010 Maxima Starting issue after frayed belt...
Hi guys: just had this happen to me, where car shut down, and inspection revealed a frayed serpentine belt. Replaced belt, but now it won’t start.... what was the resolution on the OP? Thanks in advance....
Old Sep 7, 2019 | 01:00 PM
Gin2Win's Avatar
Check for a short. The belt whipping around may have exposed some wires.
Old Aug 28, 2020 | 01:54 PM
Julie Florian's Avatar
I need help with my 2010 Nissan Maxima, car won't start googled all the DIY fixes and tells me to tap on the steering wheel lock box to get started and then remove the fuse.....well box is gone and so is the fuse........so what do I do now? Seems like a safety issue not allowing the car to start. Any ideas on this one?????
Old Aug 28, 2020 | 03:13 PM
BronxSleeperMax187's Avatar
Did you swap the battery....a jump won't help some times.
Old Aug 28, 2020 | 03:56 PM
Costee's Avatar
The box is not to be removed.
Mack Bryson
Jan 22, 2019 03:25 AM
bigjoe
20
Nov 17, 2014 07:56 AM
nauticss
Sep 22, 2014 06:18 AM
Visionzwp21
Dec 6, 2013 02:25 AM
Mike Travassos
Nov 21, 2013 02:54 PM
