Right control arm
Old Aug 13, 2019 | 06:19 PM
MaximusN8's Avatar
Right control arm
Hi
Has anyone changed the right or left control arms on a 7th gen? My right one is in need of replacement and I'm looking for any advice or tips on this repair.
Thank you
Old Aug 14, 2019 | 10:29 AM
LtLeary's Avatar
Originally Posted by MaximusN8
Hi
Thank you
Pretty straight forward.
. The air wrench/impact wrench saved my bacon. Some use a pickle fork/heat/hammer to break the seal on the ball joint but I used a "screw separator" type. Whatever works best for you.
Old Aug 16, 2019 | 04:05 PM
MaximusN8's Avatar
Thank you Lt for the info I appreciate it!
Old Aug 16, 2019 | 08:24 PM
MaximusN8's Avatar
Originally Posted by LtLeary
Pretty straight forward. https://youtu.be/441Wv7wQIIo. The air wrench/impact wrench saved my bacon. Some use a pickle fork/heat/hammer to break the seal on the ball joint but I used a "screw separator" type. Whatever works best for you.
Lt what brand control arm do you recommend for reliability?
Old Aug 17, 2019 | 08:22 AM
LtLeary's Avatar
Well it has been 4 years and still good so I would say this has been pretty good. Dorman 521-724 Control Arm
Amazon Amazon
Old Aug 17, 2019 | 08:59 PM
MaximusN8's Avatar
Well it has been 4 years and still good so I would say this has been pretty good. Dorman 521-724 Control Arm https://www.amazon.com/dp/B00GHT8TQA..._7mYTRAEIGSbXF
Thanks Lt.
Old Aug 18, 2019 | 05:53 AM
BronxSleeperMax187's Avatar
But he doesn't know about your driving habits....some take turns like its Nascar lol.
Old Aug 28, 2019 | 04:58 PM
MaximusN8's Avatar
Hi Lt.
I'm probably going to tackle this job this weekend is this the same process on our cars as the video?
Old Aug 29, 2019 | 06:35 AM
LtLeary's Avatar
Pretty close. Not a hard job with the real tools.
Old Aug 29, 2019 | 12:55 PM
2011_maxima's Avatar
Max,
I recently replaced mine (lower driver's side) it was pretty straight foward (if you have mechanical work history). The only suggestion I have is that it takes ALOT of effort to get the "bolt holes" to line back up. Getting them in place to put all 3 bolts back in is a challenge!!! It took me a half hour or so to remove & then about 2 hours to figure out how to get lined back up.... I am sure that there is a "sequence" given to the service techs, BUT that is top secret info that I was not able to get...
good luck
Old Aug 29, 2019 | 02:03 PM
MaximusN8's Avatar
Originally Posted by 2011_maxima
Max,
good luck
Lol, Thanks for the heads up. I use to work as a mechanic at Pep Boys back when I was 20 and did it for about a year or a little over then I left there because the pay was horrible and never followed through working as a mechanic again. I'm 39 now and still know my way more or less around a car and do some of the work on my cars or relatives cars as needed on the weekends. I get parts at mechanics prices at my local parts store and picked up a Mevotech Supreme control arm, I'm aware of this brand but don't usually use them I usually prefer Moog or Dorman with suspension components. I may return the Mevotech and just order a Moog or Dorman.
Old Aug 30, 2019 | 11:26 AM
LWilspeed's Avatar
I put a right side Mevotech supreme on my car and the ball joint went out within a year. Maybe my fault, but I don't recall hitting anything real big. There are lots of potholes but the left side arm (which I didn't replace so it is older) survived and the joint is still great. I got a new Mevotech under warranty....but it made me doubt the ball joints on those arms. I have had good success with the supreme line of Mevotech parts in the past....but this was my first control arm. Doing it over, I'd probably go with Moog.
Old Aug 30, 2019 | 03:38 PM
MaximusN8's Avatar
The Mevotech looks well built but I don't trust it, I called my parts store today I bought the part from and they ordered me a Dorman. I trust Dorman from previous experiences a heck of a lot more than Mevotech.
talisman311
22
Aug 23, 2017 12:05 PM
4DGA32
Aug 30, 2012 06:35 AM
chillin014
42
Aug 24, 2007 06:36 PM
vqmaxman
241
Mar 10, 2007 12:12 PM
arges
Dec 19, 2002 12:46 AM
