2012 Nissan Maxima S belt size to bypass ac compressor
Old Nov 9, 2019 | 10:53 AM
emoney21's Avatar
I don’t have enough money right now for a new ac compressor so I’m going to bypass it. Any help on what belt size I need to get ? Only for a week
Old Nov 9, 2019 | 04:35 PM
User1's Avatar
Why are you bypassing?
Old Nov 9, 2019 | 04:37 PM
emoney21's Avatar
A/c compressor locked up
Old Nov 9, 2019 | 06:38 PM
Richard66's Avatar
Couldn't you just remove your belt, use a string of sorts, run it around the new route you wish to take then measure it. It should be close.
Old Nov 9, 2019 | 06:41 PM
emoney21's Avatar
I’m not no mechanic. I just need the belt size that’s its that’s all. What I wanna do with my car is my business
Old Nov 9, 2019 | 06:48 PM
User1's Avatar
I'm not sure. Sorry.
Old Nov 9, 2019 | 08:17 PM
maxipower's Avatar
maybe if you called the dealership..they may tell which size belt
Old Nov 8, 2021 | 07:48 AM
Troubl3iii's Avatar
To give a straight answer and not a why .
I Know this is a old post but like you ,I was looking for away to bypass the AC compressor until I had the means and time to change it out . I came across this post and the only response you were getting is - why - ...lol never seen a complete and full answer to the question at hand here or anywhere for a 7th gen AC compressor delete.
So for anyone else that falls in this position you will need a 7 rib serpentine belt at no less than 53 inches no more than 53 3/4 routing the belt the same way just instead of going around the AC pully from the idler pulley go straight from the idler pulley to alternator pully and so on. I used a Duralast 535kk7 and I still had a tension pully from when I replaced all pullys a year ago and I used it in the place of the OEM idler pulley it is just a little smaller than the idler pulley and everything fit perfectly no problems at all . So hopefully this helps someone as much as it would have helped me ..
This is the belt you will need..
Old Nov 8, 2021 | 07:50 AM
Troubl3iii's Avatar
Old Feb 25, 2026 | 03:29 PM
wyattsulli's Avatar
[QUOTE=Troubl3iii;9242185]
This belt will only work with a smaller idler pulley. The belt i used was a 53.6in 7 rib belt, part no. 7pk1360. I bought the belt in the picture thinking it would work but it was double sided, you WILL NEED a one sided belt because the idler pulleys sit so close together i couldnt even get it between them. Hopefully i can save someone from the headache and torment i experienced working on this pos. Stay blessed
05' MaximaMan
Oct 8, 2017 06:36 PM
nate07sl
Feb 27, 2012 04:51 AM
Racer_M
Aug 6, 2011 03:23 PM
vnphantom
May 28, 2007 07:19 PM
TonyGotSkilz
Nov 27, 2003 07:22 PM
