Tire Maintenance light not resetting 2010
Old Jan 31, 2020 | 04:04 PM
PJalst1's Avatar
My 2010 tire Maintenance Alert is not resetting. I just had my oil and filter changed and had new tires put on all around. My mechanic said that he reset all the alerts(Oil, Oil filter, tires). After restarting my car, I noticed the Tire Maintenance alert was still on. All the other maintenance lights were off. I tried resetting it myself(which I know how to do), but when I later restarted my car I noticed that the tire alert was still on. I think there may be some type of problem with the tire alert only. Has anyone else had this problem?
Old Feb 1, 2020 | 09:38 AM
MaximusN8's Avatar
Try disconnecting the battery and reconnecting it and see if that helps, I've never had this issue or seen it anywhere on the forums. I would try that and see if that resolves the issue for you. Good luck
Old Feb 2, 2020 | 11:46 AM
PJalst1's Avatar
Disconnecting the battery worked, the Tire Maintenance light is off. Thanks for the tip
Old Feb 2, 2020 | 11:52 AM
MaximusN8's Avatar
No problem, glad it worked out for you!
reswedberg
Sep 19, 2018 04:30 AM
sean33
Tires and Wheels
25
Sep 8, 2005 12:58 PM
joemax1
Dec 9, 2004 08:43 PM
flthere
Tires and Wheels
27
Sep 27, 2004 09:52 PM
