Replacing exhaust gasket below Catylitic converter
Old May 18, 2020 | 01:55 PM
KArthur's Avatar
I have an exhaust leak and it is the flange just downstream of the cats. While I have this off, I would like to replace the studs and bolts in the flanges, Does anyone know the length and pitch of the studs that I need? I will have both the front and rear flanges apart, so I will do both of them.
Has anyone done this already? It does not look like it will be that bad to do as long as I dont twist off any of the rusted bolts.
2010 S model
Old May 31, 2020 | 08:49 AM
KArthur's Avatar
I got into this repair yesterday. In case someone else does this, the bolts in the flanges are M10x1.5 x 25mm (doorman #981-525).
When I was taking out these bolts, I noticed the catalytic converter was very loose. After I got the flange unbolted, the cat would have just fell off.
The upper flange (where it bolts to the exhaust manifold) had a defective weld. See picture below.
This is a factory converter.
I would think that since this came from the factory like this, there are many, many more cars with this issue. This is a dangerous situation because of exhaust fumes (carbon monoxide) getting into the cabin and could actually cause someone to die! If you smell exhaust fumes or think you hear an exhaust leak, get it checked out.
This repared cost me about $30 in gaskets and bolts. Took about 9hrs to do this because of the difficulty to get to all the bolts and breaking them loose. Had to heat most of them with a torch.
If you look at the welds, there is 0% penetration into the flange. It was a nice looking bead, just no peneteration. I repaired this by re-welding the flange back on.
Old May 31, 2020 | 06:22 PM
Bificus99's Avatar
I have seen this on Frontiers before.
Old May 31, 2020 | 08:46 PM
KArthur's Avatar
There should be a factory recall on this because someone could die from CO. poisoning.
This is an expensive repair if you have to take it to a shop.
Old Jun 1, 2020 | 07:01 AM
LtLeary's Avatar
Agreed, about $1100 all in at Meinike (includes cat)
Donkeypunch
Oct 31, 2014 05:02 PM
bmxsteve
May 11, 2006 02:41 AM
SurraTT
May 11, 2005 05:52 PM
96white
Mar 21, 2004 06:36 AM
claytonc
May 15, 2003 08:09 AM
