2014 Maxima sv w sport package
Old Sep 9, 2020 | 06:07 PM
DukeBlue2020's Avatar
My memory controls the seats has stopped working though the seats work great manually. Is there a way to reset this or is there a fuse that I should check and if so where is it locate....
Old Sep 9, 2020 | 07:12 PM
Nopike's Avatar
Follow these procedures to set the memory positions: • Confirm the shift lever is in the P (PARK) position. • Push the ignition switch to the ON position. • Adjust the driver’s seat, steering column and outside mirrors to the desired positions using the adjusting switches for each feature. • Push the SET switch within 5 seconds and push the memory switch (1 or 2) for at least 1 second. • The indicator light on the memory switch you select will illuminate for approximately 5 seconds. • The driver’s seat, steering column and outside mirror positions are now set to your preferences.
Old Sep 9, 2020 | 07:18 PM
Captive8's Avatar
Not sure your exact situation and circumstances, but one thing that is NOT intuitive is that:
- if you've had your battery disconnected
OR
- if you've otherwise been without power (dead battery, etc.)....the memory seat function will not work.
After restoring power, you must drive the car to at least 25MPH, before the memory seat feature becomes operable again.
But of course, checking your fuse is always a sensible part of initial troubleshooting. A lot of what can go wrong with the ADP along with initialization procedures for this and various other systems is in the owner's manual....you DO have an owner's manual, don't you?
Another clue as to what's going on would be the other part of the ADP...the auto entry/exit function. Did it quit functioning also? Do the lights on the memory switches illuminate when the buttons are pressed or no?
Old Sep 10, 2020 | 10:31 AM
2014 Nissan Maxima
Thank you I will try that. However, just so I'm clear the lights for the setting control 1 and 2 are not lighting up will that be a thing in my doing what you
suggested??
Old Sep 11, 2020 | 08:32 AM
Costee's Avatar
The switch is probably gone bad.
Old Sep 12, 2020 | 07:50 AM
tbm5690's Avatar
Disconnect the battery for a few minutes and then hook it back up and see if that fixes it. If not, could be the switch as previously mentioned.
capri66
Nov 24, 2014 10:28 AM
KGMtech
Dec 10, 2013 04:35 AM
stodge
Sep 29, 2013 07:18 AM
Minarets
36
Aug 6, 2009 10:49 PM
