No Start
Old Sep 15, 2023 | 02:10 PM
CaptKen's Avatar
Angry No Start
2009 Maxima push button start
Suddenly car won't start. All dashboard lights come on. ACC, radio and Nav system all work. Been thru all the videos and posts about the steering lock mechanism, brake pedal switch and pulling fuses. Here are the facts:
Replaced car battery
Replaced brake pedal switch
FOB confirmed to work, in and out of the port
Can hear the steering lock mechanism lock and unlock. Confirm steering wheel locks and unlocks
Gear shift dashboard indicator works
"Step on brake" indicator changes to MPG indicator when Start button pushed but goes back to step on brake after about 15 seconds
No starter noises
At wits end. Any Ideas?
Old Sep 15, 2023 | 04:46 PM
LtLeary's Avatar
I would check battery connections first (clean and tighten) the get the starter checked.
Old Sep 16, 2023 | 07:23 AM
CaptKen's Avatar
Thanx but already cleaned the terminals when installed new battery. Haven't checked the starter yet but I honestly don' think that's it.
Old Sep 17, 2023 | 11:26 AM
Richard66's Avatar
CaptKen did you ever get your no start problem fixed?
Old Sep 17, 2023 | 11:53 AM
CaptKen's Avatar
No Start
Not yet will test starter tomorrow.. after that maybe the IPDM?
Old Sep 17, 2023 | 01:04 PM
Richard66's Avatar
I was rereading your first post and you mentioned you heard the steering lock mechanism lock and unlock. Are you sure its unlocked, or were you hearing the lock motor running. Put your car in the ignition run position and after you hear the motor work the locking mechanism, attempt to turn the steering wheel. If you can turn the steering wheel with some force the locking mechanism is unlocked. If you cannot turn the wheel the lock is still engaged thereby you get the no start.
Old Sep 17, 2023 | 03:17 PM
Costee's Avatar
Possibly a ground issue. Check the battery negative cable down. It'd be helpful to have the BCM and IPDM scanned.
Happytobehere
Oct 6, 2018 09:00 AM
G35
May 8, 2016 05:00 PM
Mike Travassos
Nov 21, 2013 02:54 PM
DragonMaxima
Oct 17, 2006 06:37 AM
