ABS and traction light on
Old Jul 22, 2024 | 07:40 AM
harvey02's Avatar
My 2011 SV was making a whining noise from the front driver side for a while and then the abs and traction lights turned on. I decided to change the wheel bearing and abs sensor and the noise went away but the lights are still on. It's been 100 miles since I've changed it and I can't get the lights to go off. I tried disconnecting the battery for 24 hours and that didn't help. I checked for codes using OBD but nothing comes up.
Any ideas?
Thanks!
Old Jul 24, 2024 | 03:35 AM
LtLeary's Avatar
You may want to top off the brake fluid...this is a common source of the brake/abs/traction light issue.
Old Jul 28, 2024 | 06:47 AM
harvey02's Avatar
Thanks. I checked that but it is full.
Old Jul 28, 2024 | 12:42 PM
MaximusN8's Avatar
It's possible your alternator is starting to fail. Go get it tested and see if it's charging efficiently.
Old Jul 28, 2024 | 03:41 PM
q_nerk's Avatar
First of all check dtc's. After that we can start help with diagnose.
blkmax1
Apr 9, 2024 11:53 AM
xUltra
21
Sep 23, 2005 11:29 AM
upstatemax
May 25, 2005 08:23 AM
schernov
18
Jun 2, 2004 02:24 PM
Grisadiche
Apr 27, 2004 01:08 PM
