Replace dash on 7th Gen?
Old Oct 6, 2024 | 10:42 PM
pajacobsen's Avatar
Hello,
Gen 7, 2010 SV.. 85,000 miles... melting dash syndrome...
Has anyone replaced their dash on a Gen 7? If so, how complicated was the operation?
Also, the part is 68200-ZX70A, but it is discontinued. Any idea on how to secure one?
Thanks!
Old Oct 7, 2024 | 06:10 AM
2002SEMT's Avatar
Originally Posted by pajacobsen
Hello,
Thanks!
Go to a self-service salvage yard, preferably up North. On my 6th Gen the sun even cooks the bezel/vent assembly around the radio screen, Taking one out at the salvage yard will teach you how to change the one in your car. My bezel/vent assembly came out of a car in Manitoba.
Old Oct 7, 2024 | 12:34 PM
pajacobsen's Avatar
So you figure north to escape the humidity that creates the problem?
Also, what kind of duration were you looking at for disassembly and did you notice any point of no returns (IKEA style manufacturing - you can put it together once, but you can't take it apart and reinstall it)?
Old Oct 13, 2024 | 01:27 PM
BlackCrimsonChin's Avatar
Your best bet is a junk yard. It's a decent amount of work. You need to remove the radio, glove box, cluster, and drop the steering column. And make sure you put the gear shifter in drive (and put on parking brake/something in front the wheels) so it's not in the way when you pull it out. There's a stubborn screw on the passenger side by the vents that you might need a swivel socket to get to since it's so close to the windshield. Disconnect the battery since you'll be messing with airbags. You can look up the g37 dashboard removal on youtube, it's a similar dash & process.
Old Oct 16, 2024 | 08:56 AM
pajacobsen's Avatar
Thanks.. Sounds painful... Will the Max allow for shift to Drive without power/key (and/or is there a physical override somehow).
Old Oct 16, 2024 | 09:51 AM
Richard66's Avatar
The physical shift override is little dark cover next to the shifter, pry off cover with screwdriver then insert screwdriver in hole and push down, move shifter.
Old Oct 16, 2024 | 12:49 PM
Removing the shifter **** might give you enough clearance. You just have to pull down the silver piece on the **** and remove a pin holding it to the shifter (it tends to fly off so be careful losing it). But the shifter is delicate so probably better shifting it back with the **** on.
Old Oct 17, 2024 | 10:47 AM
pajacobsen's Avatar
Thanks!
Old Oct 17, 2024 | 10:48 AM
pajacobsen's Avatar
Thank you
LtLeary
18
Jan 20, 2020 05:16 PM
Bobz09
Mar 16, 2019 10:24 AM
Stelianos
Jul 4, 2016 08:04 AM
nate_man
Jan 7, 2016 03:29 PM
MaxDriver98
Aug 19, 2003 07:41 PM
