Radiator Fans not turning on
Old Oct 26, 2024 | 05:23 PM
maxipriest777's Avatar
Hi all just purchased a 7th Gen in good
condition. Brilliant silver, interior is flawless. Runs great. Only one problem.
The radiator Fans are not turning on.
When I turn on the A/C no fan movement.
When I let the car sit and run for a while.
No fan movement.
I checked the radiator fan fuse under the hood. Wasn't blown.
I changed both Rad relay1 and Rad relay2.
Still no fan movement.
Where else should I look ?
Any help would be greatly appreciated
Thank you
Old Oct 27, 2024 | 04:48 PM
LtLeary's Avatar
Time for Ocam's razor. The fans need replacing.
Old Oct 27, 2024 | 04:54 PM
Akums, probably
Thanks very much for the fast response.
Buying a new set of fans would be the easy path
But. What happens when those new fans
are installed, and they still aren't turning on
Isn't there a fan control module somewhere on my 2014 Maxima?
Question is. Where is it located on my car ?
Thanks again
Old Oct 28, 2024 | 08:04 AM
LtLeary's Avatar
As you can see, the ECM actually controls the FAN via the relays. If you have doubts, use a power probe and apply voltage directly to the fan motor. You can Test, don't just shoot parts although I can say I have had two fan replacements on my 09 in the almost 500k I owned it which is what leads me to believe it is bad fans.
oren
Jun 7, 2018 08:47 AM
ilanpro
Nov 27, 2011 07:10 AM
skyjay617
Aug 14, 2008 07:43 PM
TJ_Max
Sep 2, 2004 10:30 AM
jeffj51
May 19, 2004 04:45 PM
