LED Turn Signals
Old Nov 13, 2015 | 05:25 AM
spidgeon's Avatar
LED Brake & Turn Signals
Has anyone changed their brake and turn signals to LED yet? I keep seeing this on other cars and love the look. Which bulbs did you use, brightness, etc. Have you experienced any issues?
Old Nov 23, 2015 | 05:30 AM
spidgeon's Avatar
Anyone do this yet?
Old Nov 23, 2015 | 08:04 AM
doctorpullit's Avatar
Nope. I may do the reverse lights and then I'm done. For some reason, I thought the brake lights were already LED. Is it just the tail lights?
Old Nov 23, 2015 | 03:50 PM
spidgeon's Avatar
Only the 3rd brake light is LED. There are two separate halogen bulbs, one for the brake and one for the turn signals. Both are the 7440 bulbs. I saw an Infiniti Q50 at an intersection today with the turn signal on and just loved the look. With all the tech in the Maxima, I'm shocked there wasn't LED brake and turn signals already in the Platinum.
Old Nov 23, 2015 | 09:33 PM
If you find LED bulbs to use and replace yours, please post the results.
Old Nov 24, 2015 | 04:07 AM
jinzen's Avatar
Retrofit Source sells white or amber 7440 LED bulbs which I'm sure will work well but are $35 for a pair, so $70 to replace all the brakes and turn signals.
I might do it, since those bulbs are usually very easy to replace.
Old Nov 24, 2015 | 04:09 AM
jinzen's Avatar
Spidgeon, can you post all of the bulb sizes for the ones you've replaced?
License plate
Fogs
Front Turn Signals
I am most likely getting white LEDs for the first two and Amber for front turn signal, which I did in my Evoque and it worked well.
Old Nov 24, 2015 | 10:31 AM
spidgeon's Avatar
License plate
Fogs
Front Turn Signals
Turn signals I haven't done yet, I'm researching which bulbs to use for that now. If you have suggestions for turn signals, please post. Below are the bulbs I have put in.
Fogs - H16s
License plate - 921s
Reverse lights - 921s
Old Dec 10, 2015 | 02:30 PM
solariis's Avatar
Fogs - H16s
Any updates on what size bulb for turn signals? I cant seem to it anywhere online.
Old Dec 10, 2015 | 06:08 PM
spidgeon's Avatar
Here's the link to my post about changing the turn signals
https://maxima.org/forums/8th-genera...placement.html
Frank Fontaine
Oct 30, 2015 06:13 AM
MaximaGuy14
Oct 22, 2015 01:38 AM
DaveJ
Oct 20, 2015 09:04 AM
ColdCananda
Oct 19, 2015 10:00 AM
FanaticMadMax
Oct 15, 2015 11:19 AM
