Warning Lights!
Old Apr 18, 2016 | 05:57 PM
Dbain83's Avatar
Warning Lights!
It's like Christmas on my combi meter....ABS, VDC, and Foward Collision all lit up...just happened out of nowhere. I've had the car 4 days. Any ideas?
Old Apr 18, 2016 | 07:13 PM
Richard66's Avatar
It is telling you multiple systems failure, or the warning lights are not working properly. either way a trip to the dealership is necessary.
Old Apr 18, 2016 | 08:06 PM
lightonthehill's Avatar
I don't recall anyone here reporting this particular combination of warning lights. I don't see how the forward collision system is tied to those other two lights, unless detection of a braking problem can trigger it. I would check the fluid level in the master brake cylinder reservoir, and if it is low, fill it with fresh brake fluid (not fluid left over from bygone days). If the reservoir is already at the full mark, a trip to the dealer should be made SOON. I would be a little wary of trying to drive far with that combination of lights lit up.
Old Apr 25, 2016 | 01:20 PM
Kalrakam's Avatar
Warning Lights
Forward collision light will randomly trigger every single time I am driving. It doesn't matter if it's raining or sunny, the error will pop up which will not let me use my cruise control.
However, my car did got into an accident and the damage was on the side where the sensor is installed. Shop and dealership said that that the sensor looks ok so not sure what the problem is.
I am going to get the sensor replaced so hopefully that will fix the issue.
Old Apr 25, 2016 | 02:08 PM
I believe that you're pointing at the sonar sensor which detects objects in low speed maneuvering like when you're parking. The camera in the front I believe is what senses the frontal collision warning. If I'm not mistaken though, ABS, frontal collision warning, and traction control operate closely in regards to pulling what each of the wheel speed sensors are indicating (at least I would assume). Did you have the body work repaired by the dealership? If not, be very weary as the service department may blame the accident causing this issue and would then be a non-warranty matter, potentially charging you a diagnostic charge.
Old May 7, 2016 | 03:19 PM
Kalrakam's Avatar
So there is no actual camera in the front. There is a small radarsensor module in the front underneath the front headlights that controls the cruise control and senses frontal collision warning and all that good stuff.
I finally took my car to the shop and they were able to install a brand new sensor. The shop then took it to the Nissan dealership to get it calibrated. My car had to get an alignment in order to get the sensor to calibrate. So far I haven't received any error yet, but then again it's only been 1 day. Hopefully this fixed the issue.
Old May 8, 2016 | 12:25 AM
Part of the uncertainty here is because different models of the 8th gen Maxima have different sensors and cameras. My Platinum has a camera peeping through the bottom half of the Nissan 'hamburger' in the front grille. Among other things, it furnishes the front portion of the 'all-around' camera view from 'above' the car. That 'above' view is wonderful for really old folks like me. My neck hasn't allowed me to turn my head backwards since way back when I was in my seventies. It is nice to know how many inches I am from the edge of the garage door, or from the curb on any side or end of the car. I have also adjusted to the various beepings that can come from any part of the car if it gets too close to anything. Ain't modern technology wonderful?
Old May 18, 2016 | 09:10 AM
corpdecker's Avatar
My car did this at one point and the cause was one of the fuses in the interior fuse box was blown. This was preventing my brake lights from coming on (yikes!) and for whatever reason the signal for such a situation was the swirvy car and impact lights were stuck on like you are seeing. If you haven't ruled that out, be sure to do so ASAP, it's dangerous to drive around without brake lights.
Old May 18, 2016 | 11:44 AM
Thanks for this good info corpdecker. I have not had this strange and confusing light array, but if it happens, I will now have something to check for.
Old Mar 29, 2019 | 12:53 PM
2017 Maxima Plat's Avatar
Exclamation Defective Radar System / FEB
I had a Altima and the front radar only went into error or fault mode when snow & ice covered the front end.... now with my 2017 Maxima it'll be dry & sunny, cars around or not, moving or stopped, the error appears once a drive or 5 times, no rhyme or reason. My last service appointment, the dealer checked the system and found nothing wrong....I took some screen shots of my dash with the fault indicator on and return to Nissan next week. I've got the top of the line extended warranty which hasn't been used up until now... but hopefully they'll look after the problem without me having to do battle with them....I appreciate all the posts with similar issues, so I won't let them off the hook... thanks everyone!
Old Mar 29, 2019 | 04:04 PM
Steptide's Avatar
My wife has a 17 rogue and we recently got a notice of a software update for the emergency braking. I don't know if the software is the same on a maxima, but I can't imagine the systems between the 2 vehicles are different. I imagine the parts would be the same. Anyway, might be worth asking the dealer about
Old Jul 11, 2019 | 08:05 PM
UMan's Avatar
Did you ever find out what caused this ?????
Old Apr 25, 2024 | 08:15 PM
Jcahill's Avatar
Checking back in 2024
Not sure if this thread is active but I’m having the same issue. Anyone find a solution?
Old Jun 11, 2024 | 10:23 AM
GabbyCookie's Avatar
Old Jun 11, 2024 | 11:23 AM
Jcahill's Avatar
Found Solution
I found the solution for my issue. It was a ABS wheel speed sensor (2016 Maxima).
My passenger side rear sensor wire was broken.. was pretty easy to see when I took the wheel off.
bought an aftermarket sensor off parts galaxy (thru Amazon) for $40.
Installed and all warning lights went away. Hope this helps!
Anthony Feliu
Mar 19, 2018 05:12 AM
Htown9901
Apr 16, 2017 04:44 AM
Ghozt
18
Jan 8, 2016 11:20 AM
CrIMs0n MaX 92
Jul 12, 2013 09:26 AM
