New Owner 17 SV ... Couple of Questions..
Old Jan 17, 2019 | 08:36 AM
d.ceraso's Avatar
Hey all i would like to say, I am so happy to be back w/ the nissan family. I used to own a 2004 nissan sentra spec-v 6 speed. I loved the 2.5l in the sentra. Now w/ the big boy max and the 3.5 i am so happy to be back. Anyways, I do havea couple of questions related to the maxima... First of all, the auto start from the key, is there anything i have to do special? I press and hold the button and it does not auto-start. Secondly, Can i order a 2nd key and program it myself? If so is there a tutorial anywhere online that walks me through it?
Finally, what id s good source people use here for aftermarket parts?
Thanks for the info everybody. I attached a pic of my beauty.
Old Jan 17, 2019 | 08:50 AM
MadMax07SL's Avatar
Pretty sure you have to lock the doors before remote start will work. If they are unlocked when you try it, that's not going to work.
Old Jan 17, 2019 | 08:51 AM
gizzsdad's Avatar
Usually best practice to hit the lock button at least once (I was told twice), then hold the start button ( I usually hold until I see the lights come on.
Congrats - nice looking car!
MadMax07SL's Avatar
Also to note, within the settings on the dash you can actually disable remote start (again, pretty sure). Previous owner may have turned that off.
Old Jan 17, 2019 | 08:52 AM
2young2retire's Avatar
To remote start first push the lock button on the fob and then within 5 seconds push and hold down the start button.
Why would you accept a car with only one key? But in answer to your question you cannot program the key fobs yourself. You must either go to the dealer or a locksmith that has the necessary equipment.
I had a third fob programmed at the dealer at no cost after the purchase of my '17 Platinum. Bought it from ebay
https://www.ebay.com/usr/1midatlanti...72.m2749.l2754
and it worked perfectly. In the past I have had fobs programmed at the dealer for $40. There are no parts necessary to program one, just a few minutes with a computer.
NisCal17's Avatar
in order to remote start you have to press lock and then press and hold start for about 5 seconds till you see hazard flash and it should start.
There’s also an option which needs to be engaged in the settings. Just go to menu and see if it’s ON.
Not it sure about key making but I would suggest to call Nissan and check with them.
Regarding aftermarket parts... I’m pretty sure some of members will suggest a good source for parts. I’ve seen die hard modders here. You can also check the thread for recent mods which members post here.
https://maxima.org/forums/8th-genera...r-8th-gen.html
Old Jan 17, 2019 | 08:58 AM
NisCal17's Avatar
BTW remote start works even when the car is not within view. I can start my car 120 feet away parked outside the building through multiple concrete and brick walls. I just happened to have security camera installed in the parking area. The other day I tested it looking at the monitor from my house. And it fired up.
Old Jan 17, 2019 | 09:36 AM
wild willy's Avatar
For the record, u remote start guys that warm your care before you drive it....................one of the worst things you can do to your car. That is all
Old Jan 17, 2019 | 10:07 AM
robtroxel's Avatar
WW, why do you say this? I think the remote started car stops after 10 minutes. Would not use mine unless I was going to continue driving the car to a destination
Old Jan 17, 2019 | 10:23 AM
wild willy's Avatar
https://www.popularmechanics.com/car...-harms-engine/
https://www.familyhandyman.com/autom...in-the-winter/
Old Jan 17, 2019 | 10:29 AM
robtroxel's Avatar
Interesting articles! I would agree though I do a remote start as I am going to the garage. Idle time is no more than 3-5 minutes.
Old Jan 17, 2019 | 10:41 AM
wild willy's Avatar
My wife and I argue about this all of the time......lol I told her...Never a remote start....She would start it the night before....lol
Old Jan 17, 2019 | 10:52 AM
Mason Hatcher's Avatar
I have and will continue to remote start mine when it is cold or really hot. I do it so that I am comfortable while driving. I installed a Drone Mobile remote start so that I could start it even from too far for the keyfob to reach.
Old Jan 17, 2019 | 11:07 AM
d.ceraso's Avatar
Thank you everybody for the information. I am going to try it When i am leaving for work. I also have to send the signal through a few walls and a decent way to the parking lot.. so it will be a good test.
Looking forward to learning a lot here.
Old Jan 17, 2019 | 11:33 AM
NisCal17's Avatar
I usual give it between 2-3 minutes before going. It’s in mid 20s F at night.
Old Jan 17, 2019 | 11:52 AM
lionel2013's Avatar
I don't have any proof but I do believe there has to be some line of sight/blind spot issue with the restart because I too have had trouble getting it going a few times, even though I am positive I locked the doors, sometimes even twice. I have a 2018 Maxima SV.
Old Jan 17, 2019 | 03:56 PM
FLGulf's Avatar
Some financial institutions require that they hold one of the keys as a condition of a loan approval in order to simplify a repossession if necessary. This isn't usually disclosed to the buyer if financing is arranged through the car dealer, but if they give you a late-model used car with one key, that's most likely the reason.
Old Jan 17, 2019 | 04:05 PM
wild willy's Avatar
I have been buying new cars since 1989....I have never encountered this or hear it....but it is a damn good Idea for deadbeats.
Old Jan 17, 2019 | 04:07 PM
d.ceraso's Avatar
the car is used, have you ever bought a used vehicle before? They don’t always. Have both sets of keys. I found the Nissan key fob online for $40 and my dealer will program it for $69.99 so not too bad.
Old Jan 17, 2019 | 04:08 PM
d.ceraso's Avatar
Also, got the remote start working wasn’t holding it long enough 👍
Old Jan 17, 2019 | 04:10 PM
I would have a hard time leaving the dealership with only one key for the car. If the financial institution wants a key then they should have one programmed for themselves. That may be the way it works, it's just that I would not want only one key. If you misplace it then you are SOL.
Old Jan 17, 2019 | 05:04 PM
sschumer's Avatar
Per this 2 minute video that shows how Remote Start works, the range is 200 feet:
Old Jan 17, 2019 | 06:35 PM
compyelc4's Avatar
I have experienced this a few times with my 17SL. If I am about 100 ft. or so away and I can't see my car, often when I reach the car it has not started. If I am about the same distance and can see the car, then it starts 100% of the time.
Old Jan 18, 2019 | 03:03 AM
wild willy's Avatar
Yes, I have bought a couple used.
mynesbts
Jan 21, 2019 09:36 AM
Heat0212
Oct 28, 2015 06:33 PM
Cdubbs89
Nov 12, 2014 08:15 PM
cbruno
28
Aug 26, 2008 08:55 AM
SlimGoaty
24
Mar 11, 2005 05:39 PM
