Bluetooth Connection Issues
Old Mar 17, 2019 | 03:17 PM
Dwade81's Avatar
2018 Maxima, Bluetooth worked just fine until today. Will not connect any phone. Also, while trouble shooting, will not delete previously connected devices. Within the screen it says it's deleted but it still shows up. Nothing has worked to try and reconnect my phone to Bluetooth.
Old Mar 17, 2019 | 03:57 PM
7yankee's Avatar
Try resetting infotainment unit
If you have the infotainment center, this is what I have to do about once a week.
With the audio off press and hold the menu button (not the screen one, the physical one) the turn the volume **** up and down 4 or more times rapidly. You'll see the unit enables a diagnostic mode. You need only select the return arrow on the screen and the infotainment center will turn off. After 20 or 30 seconds it'll restart and your Bluetooth should be back to normal.
hope the works for you, good luck
Old Mar 17, 2019 | 06:37 PM
sschumer's Avatar
Why not contact NissanConnect Support? I've used them and thought they were great. https://www.nissanusa.com/connect/support
Old Mar 24, 2019 | 12:09 PM
Sir Buckeye's Avatar
I have this happen from time to time where it won't connect my to my phone. It only happens when I use the remote start feature and let it warm up. It probably has something to do with the phone dropping in and out of range. Anyway, it usually returns to normal if I leave the car shut off for 15 minutes or so, then start it back up. If this doesn't work, I've had success by pairing a second new device, then deleting the first device and re-pair.
Old Mar 25, 2019 | 06:43 AM
robtroxel's Avatar
Great tip. Thanks for putting this post up. I have not messed with the Diagnostic Screen but I see this as fairly simple to do.
Old Jun 15, 2022 | 12:02 PM
kwlbrown's Avatar
Thank you so much, first time I needed to do this in 4 years but you saved my day.
Old Jun 18, 2022 | 06:31 PM
compyelc4's Avatar
Have you tried re-booting the thing, by disconnecting and reconnecting your battery? You never know.
Old Jun 20, 2022 | 08:10 AM
Jmphilly's Avatar
Bluetooth Connection Failed
Any updates? I have a 2017 platinum. I noticed it giving me the "Bluetooth connection failed" message when I would remote start the car then walk out of range. I thought I fixed it by leaving the phone near the car when I remote started. Now I'm getting the issue to the point that I haven't been able to use Bluetooth for days. I deleted my phone yesterday and reconnected, worked fine. This morning it went back to not working. Even after I deleted phone and reconnected...
I had a 2016 SL (was totaled thanks to some idiot kid falling asleep at the wheel) and it never had any of these issues.
Old Feb 4, 2023 | 05:51 AM
cnhaussies08's Avatar
17 Maxima
this doesn't do anything for me
Old Mar 1, 2023 | 05:08 PM
devilboy95's Avatar
Howdy! I just got a 2021 Maxima platinum. My phone, a Pixel 7, connects just fine for calls and texts. When I click "Bluetooth" for audio, my phone does not show up. I checked to make sure music was enabled in the Maxima connection, I'm at a loss as to what I'm doing wrong.
Old Mar 1, 2023 | 06:21 PM
2young2retire's Avatar
I had the unit replaced under warranty in my '17 Platinum but the problem returned. Whenever I lose connection I just do the reboot and it is good for a month or so. No biggie.
Old May 31, 2025 | 02:07 PM
deadlyberet85's Avatar
the damn thing… AirPods, forget the AirPod devices and see if it works… it worked pretty well after I did that…
kevin_ohio
Dec 17, 2017 10:32 PM
robtroxel
Jan 10, 2017 09:00 AM
JakeOfAllTrades
18
Oct 2, 2015 08:01 AM
t84a
Nov 24, 2013 05:59 AM
tse54re
May 15, 2011 11:42 AM
