Rear deck vibration/rattle with bass heavy music
Old May 9, 2020 | 07:16 PM
ChricC212's Avatar
I have a 2016 maxima platinum and with bass heavy music I hear a lot of vibration coming from the rear deck. My bass is set to +1 away from the maximum but in my 2007 maxima the bass was set to the max and I still never heard any vibration. Is this happening to anyone else?
Old May 10, 2020 | 01:27 AM
Mikey319's Avatar
I have the same issue in my 2018 Platinum. It’s very annoying . My rear sunshade also makes a lot of noise too. I’m hoping they can fix it when I bring it in next.
Old May 10, 2020 | 04:12 AM
wild willy2's Avatar
I don't think I have ever ridden in a Nissan with the Bose that did not do this.....Yes, it is annoying
Old May 10, 2020 | 04:59 AM
Turbobink's Avatar
If the volume of your sound system is causing your car to fall apart, perhaps you should consider turning it down.
Old May 10, 2020 | 05:07 AM
It does not have to be loud to rattle.....
Old May 10, 2020 | 08:46 AM
compyelc4's Avatar
If it were my car, and I just had to have a lot of bass, I would climb back there and start pushing on every freakin' part I could get to. When you get to the culprit isolate the vibration with foam backing, screw tightening, you know...... Also check you speaker mount. Could be speaker frame vibrating on its mounting surface. Other than these suggestions, can't know.
Old May 10, 2020 | 10:11 PM
dmstangu's Avatar
It's the sun shade. Put a couple pieces of foam between the shade and its housing.
https://maxima.org/forums/8th-genera...ml#post9168427
Old May 12, 2020 | 07:37 AM
robtroxel's Avatar
Great tip and it worked on my 2019 Platinum. If I was ambitious, I would disassemble that rear shelf area and add some acoustic matting on that whole area. ..On second thought...naw!
aksansai
Nov 10, 2007 09:10 PM
DMCfirestar500
Feb 24, 2005 10:13 AM
blackmax7
Feb 18, 2005 10:38 PM
eperalta
Dec 10, 2003 10:52 AM
2kBlackMax
Dec 10, 2001 02:32 AM
