Why does window roll down automatically when the door is being closed while unlocked?
Old Feb 14, 2023 | 09:42 PM
burnedplzza's Avatar
Windows(on the front side) close down if I close the door while it is unlocked.
Why does it do that? Is it a safety feature??
Old Feb 15, 2023 | 02:51 AM
wild willy2's Avatar
Are you talking about this?
​​​​​​The motion is referred to as indexing. It allows the glass to plant itself firmly into the rubber seal while still being able to quickly detect an attempted opening of the door and pull it back down so as not to tear the seal.
Old Feb 15, 2023 | 02:59 AM
Turbobink's Avatar
There’s a little booklet in the glove compartment, or perhaps in one of the stow-away compartments in the trunk … it’s called the “owners manual”.
It’s a good read.
Old Feb 15, 2023 | 08:13 AM
wytnyt's Avatar
It’s a good read.
troll much?
on some cars that have tight rubbers around the windows when you touch and begin opening the door the window will drop slightly to allow door movement ,im not sure if this is what your referring to tho.
Old Feb 15, 2023 | 12:32 PM
Turbobink's Avatar
Originally Posted by wytnyt
troll much?
No … not much at all.
Old Feb 15, 2023 | 01:03 PM
The window rolls down 100%. So I don't think it is indexing. Also Indexing is described as "window indexing feature is used to lower the window when the door is opened"
But mine rolls down when the door is closed.
Old Feb 15, 2023 | 01:04 PM
It completely shuts down not a little bit
Old Feb 15, 2023 | 04:52 PM
Richard66's Avatar
Do a window auto up/down relearn. Maybe that will fix the problem.
Old Feb 15, 2023 | 05:11 PM
notinuse's Avatar
I doubt the problem is window indexing, since the Maxima has a frame around the door window.
Old Feb 15, 2023 | 06:18 PM
I will try that later, let's see
Old Feb 16, 2023 | 04:13 PM
wytnyt's Avatar
i wonder if the door window switch is causing it from the jar of the door being closed,to me thats all it can be
does it do it every time?
will it still do it if to softly close the door?
Old Feb 17, 2023 | 10:49 PM
It does it sometimes and it doesn't. I'm taking my car to the dealership and will have them looked at it.
The thing is though, they specialize for ford cars. so I'm not sure how they will handle it
Old Feb 22, 2023 | 07:42 AM
Goldpanda94's Avatar
I'd go to a Nissan dealer if you have one even remotely near you, especially for an electrical problem which this sounds like it possibly could be.
Old Mar 14, 2023 | 01:01 AM
Car was taken to Nissan and the issue was as follows : Connecting rod was not attached to actuator. Re/Re Cylinder and lock actuator.
The problem was fixed. However, I have this new issue now after repair(people say not to worry abt it and it is not that abnormal?) - (https://maxima.org/forums/4th-genera...e-pressed.html).
I'm not sure if repairing window had anything to do with that
BigOgre
Feb 15, 2009 08:29 AM
i30ish
Apr 12, 2006 08:20 PM
VASHtheSTAMPEDE
Jun 25, 2004 12:11 PM
patel_anu
May 1, 2004 04:24 PM
vict0r
Mar 17, 2002 04:05 PM
