Fuel injector Replacement
Old Jul 30, 2023 | 06:40 PM
Les7311's Avatar
Fuel injector Replacement and P0420
Am planning surgery to replace the fuel injectors and spark plugs, plus clean the MAF at 306k miles.
Replaced the spark plugs several times so no prob getting into the guts
any special to look out / check etc getting out them injectors, etc??
surgery is to combat the dreaded P0420 in prep for emissions.
Peep at 6:30 in vid
replaced Catyl and O2’s about 2 years back…
Old Jul 30, 2023 | 08:59 PM
schmellyfart's Avatar
Cat efficiency codes are usually related to o2 sensor issues, unless your cats are clogged.
Old Jul 31, 2023 | 03:50 AM
Les7311's Avatar
OEM sensor, by radiator, replaced about 3 months back.
gas range remains @ 530 miles on a full tank; ( averaged about 400 miles when Catyl bad - replaced both about 2 years back)
running lean now
front 3 plugs gaps 0.081, 0.083, 0.092, and replaced April 2022. ( New plugs gap is .044)
Old Jul 31, 2023 | 04:19 PM
Les7311's Avatar
@LtLeary
tried sending you a DM x 3. Uncertain if it went through. Let me know…👊👊
Old Aug 1, 2023 | 10:10 AM
LtLeary's Avatar
Originally Posted by Les7311
@LtLeary
Got Em!
Old Aug 1, 2023 | 10:27 AM
LtLeary's Avatar
By the way, your rear cat off of bank 1 will probably need replacement. You can certainly try replacing the O2 sensor but no matter what I tried with my P0430, I had to ultimately replace the front bank 2 cat. Good luck with those connectors on the injectors. I had to give up on mine after breaking two (Big fingers + low patience = Dang!)
Old Aug 1, 2023 | 01:22 PM
Les7311's Avatar
Haven’t touched the rear since a CEL didn’t show, but will consider.
yup, ouch!!!! Guess you called quits after. Been Utubing quite a few “how to” clean and replace. Parts enroute, but curious to the spray zones and may try testing the OEMs….
Old Aug 4, 2023 | 11:39 AM
LtLeary's Avatar
Please do keep is updated on your efforts! Even failires teach.
Old Aug 4, 2023 | 12:08 PM
Les7311's Avatar
@LtLeary Et Al:
Will do. Injectors and plugs arrived yesterday, surgery this weekend.
did surgery Re: video below - yet to start 2nd solenoid at back - so far the solenoid by coolant jug is clean and not clogged)
car passed emissions after clearing code and drove several cycles over 3 days. Ghastly P- code show as “pending “ in OBD.
10 miles later, same emission test day, P code returned —- at least am good for another 2-years on emission.
Old Aug 5, 2023 | 05:19 PM
Les7311's Avatar
Update.
Surgery lasted about 2 1/2 hours.
wont get into details. A YouTube vid around how to change spark plugs.
the rails held w 4 bolts. I used the vid below to lift the rails
two of the “O-rings” decided to disintegrate into the rails. Simply remove the injector next to the problem injector, placed a hose over the neck and blow. This dislodged the fragments.
Cleaned some grease residue, reversed procedure.
here’s my plugs and injectors.
Old Aug 5, 2023 | 05:23 PM
Les7311's Avatar
The gaps on the plugs were off and replaced.
first 3 w new plug taken from the front (by radiator….)
Old Aug 5, 2023 | 05:32 PM
Les7311's Avatar
The solenoids… that’s another story
was able to get to them (front by coolant is easy - bolts)
back one:
jack up engine by oil pan
remove both mounts
remove coolant and brake jugs
the plate above the serpentine is a PITA. Finally removed about 30 minutes later.
removed both solenoids and they were not clogged.
watch video above.
cleaned MAF sensor
Car doesn’t run rich/lean, no P0420 code or other CEL
see how the miles and performance goes
am running about 28 mpg before surgery (about 550 miles on a full tank)
hoping for another 250k miles ( now at 306k miles)
Old Aug 8, 2023 | 07:30 AM
Les7311's Avatar
Almost 500 miles later and see Bank 1 readings: scroll up and see P0420 w readings on a fail.. lots of take aways
95maxxima
Jul 19, 2022 01:08 PM
maxprivate
Forced Induction
Jul 1, 2022 09:20 PM
Crusher103
20
Apr 16, 2013 11:43 AM
gapboi210
Jul 21, 2010 09:26 PM
4thgradedropout
Jun 14, 2005 12:04 AM
