Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
BBK wanted, but forced into having 16" wheels... HELP!
Old Oct 4, 2006 | 09:52 AM
Chefasaurus's Avatar
Fire in the hole!
As title states, I need to know what my options are for upgrading my brakes (hopefully someone says Z32 calipers!) and staying behind 16" SE wheels.
I am getting a set of autoX slicks for my birthday, but dad's requirement was that I didn't go above 16", for the obvious cost involved. I autoX a LOT. I also drive a lot... I've put 3200 miles on my car, and I've had it for 6 weeks, and work is 8 blocks away from the house.
So, as tempting as it is to get Blehm's or Jeff's BBK kit (or even K-Sport/Wilwood/Brembo), I REALLY don't want to have to bump up to 17's. That money can be better used on K-Sport coilovers, a RSB, and FSTB.
help?
Old Oct 4, 2006 | 09:56 AM
Jeff92se's Avatar
I'm needing a caw
Z32 30mm aluminum calipers and the Z32 rotors that have a diameter that's shaved a few MM. I'd even use the NA or Turbo Z32 wheels also. Light, cheap and will clear those wide calipers
Old Oct 4, 2006 | 10:01 AM
d00df00d's Avatar
Old enuf to pick his own gears
With what brackets?
Old Oct 4, 2006 | 10:03 AM
Jeff92se's Avatar
I'm needing a caw
Exactly. What brackets? As in no brackets.
He won't be able to get the great torque arm advantage of moving the caliper out but he will be able to utilize the multipiston design for brake feel and the thicker rotor for fade resistance.
Originally Posted by d00df00d
With what brackets?
Old Oct 4, 2006 | 10:07 AM
Kevlo911's Avatar
Kevlo for President
SE wheels... I would say Q/J calipers and Q/J/Z rotors milled down.
Old Oct 4, 2006 | 04:48 PM
irish44j's Avatar
retired moderator
Jeff, so the Z32 rotors + calipers will bolt right up with no modifications? Interesting......
I think his only problem might be offset - you definitely need to push the wheels out farther to fit the Z32 calipers. Find a 16x8 with a 30 offset and you're good to go.
Old Oct 4, 2006 | 04:50 PM
mtrai760's Avatar
'Trynna' is not a word
You could also use the last gen RX7 wheels.
Old Oct 4, 2006 | 07:52 PM
Fire in the hole!
I have some of those.
I can get the Z32 30mm aluminum calipers for 150 shipped, from a friend in New Orleans... is that a good deal? The caliper will mount right up to my stock bracket? What about the rotors? Will a reputable machine shop be able to do the milling down? If all this is true, and the stuff will fit, this is AWESOME. I mean, I'm not trying to have F1 stopping power... but I am looking for something to get rid of these weak sauce brakes that are pretty much garbage after 2 or 3 hard autoX runs (we usually get 6-8 runs... you can imagine how much fun it is to drive the following 4-6 runs on crap brakes.).
I've got the time and money to buy the parts and do the work, but like I said, I'm in a bit of a situation where I HAVE to stay in 16" wheel-land.
Old Oct 5, 2006 | 09:09 AM
Jeff92se's Avatar
I'm needing a caw
Any machine shop should be able to do that. But you should research and make sure what the exact measurement is. Something like 3mm off the radius. You might also need to grind off some of the tie rod or control arm or something. I forget. Nothing difficult
This is the most OG semi-BBK here on the .org.
Old Oct 5, 2006 | 09:33 AM
burnurass's Avatar
How about a 240SX 5lug rim? it has a +40 offset.
Old Oct 5, 2006 | 10:00 AM
VIP Maxima
where is the best place to mount the caliper?
i was thinkin across from where OEM goes for some weight distribution !
as for purchasing the z32 calipers goes.. try www.rockauto.com loaded rebuilt ones go for $130
Old Oct 5, 2006 | 10:25 AM
SPiG's Avatar
SomePsychoGuy
No you just put the Z32/J30/Q45 calipers in where the A32 were. Just bolt them in. Once you mill the rotor it is pretty much bolt on.
Old Oct 6, 2006 | 10:19 AM
Fire in the hole!
and it still fits behind my SE wheels, right? Will I need spacers?
Old Oct 6, 2006 | 10:24 AM
Jeff92se's Avatar
I'm needing a caw
Z32 no way.
J/Q? maybe
Not sure why you ask. You wont' be able to put any decent sized meats on those skinny SE wheels.
Old Oct 6, 2006 | 11:58 AM
Dubbya's Avatar
VK56 Inside
I would do 4mm off the radius. 3mm just barely clears. You need to grind down the control arm a little right behind the rotor.
Old Oct 6, 2006 | 12:20 PM
MaximaSE96's Avatar
Maxima Owner
16"s wont fit with jeff or matts kit AT ALL......the caliper rubs the wheel....i doubled up my 20mm spacers so 40mm for a test fit with 300zx tt wheels...so i would say Z32 calipers and milled rotors is ur best bet
Old Oct 8, 2006 | 10:45 AM
Matt93SE's Avatar
STFU n00b!
Z32 calipers of any variety WILL NOT FIT under stock 16" Maxima wheels. no chance in hell without a spacer.
What is your current setup?
Rotors?
Pads?
Fluid?
lines?
For auto X use, you should have ZERO problems with fade simply running something like Hawk HPS on factory-sized brembo blanks with some good brake fluid. You don't even need SS lines to get rid of the fade, but it will help with brake feel.
If you're having problems with heat fade after that, then you've got some serious issues somewhere.
Old Oct 8, 2006 | 11:09 PM
A33 VQ30DEK's Avatar
just invest some money into some light weight 17 inch wheels.
Old Oct 9, 2006 | 06:13 PM
Fire in the hole!
Birthday present (from ALL of the family) is a set of 16" Toyo RA-1 tires, on a set of 300ZX wheels... otherwise, I would.
The other reason is because I have my SE wheels as DD's, and they're fine, with decent tires left on them.
how big of a spacer? I can order one from H&R and have it here in 3-5 days... just curious as to how thick.
Old Oct 12, 2006 | 10:42 AM
Fire in the hole!
how thick of a spacer? 10mm?
Old Oct 23, 2006 | 06:12 AM
buttonhook's Avatar
you can't use the BBK kits with 16" wheels you need 17" at least. but if you wanted to go the 300zx rotors milled 3-4mm then you might be able to do that. if your interested in that then check out my for sale I have the z32 caliper and wheels adapter/spacers for sale and save your self some $$$
http://forums.maxima.org/showthread.php?t=496658
Old Oct 23, 2006 | 07:41 AM
Matt93SE's Avatar
STFU n00b!
are you listening? don't mess with a brake kit for Auto X.
you simply don't need it. get some Hawk HPS or Axxis MM pads and stainless brake lines and you'll be good. most of the time you don't even get the brakes WARM in a 60 sec autoX run.
also remember that modifying your brakes more than that will put you in a higher class than you should be competing. trust the guy with experience on that one. ever tried to be competitive in a Maxima in Street Mod? fawk.
BkGreen97
Apr 2, 2016 05:47 AM
jds22
Sep 4, 2015 01:52 PM
Wareagle92
Sep 3, 2015 07:18 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
