Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Steering Issues
Old Jul 14, 2007 | 05:40 PM
L.I. I30t's Avatar
Steering Issues
While driving straight on any road then making a right or left turn the steering wheel does go back to the center. If its a right turn and the vehicle goes back to traveling straight the steering is @ 2 o'clock, similar to an lack of or bad alignment. I have replaced most of my steering and suspension parts except for the rack n pinion itself. I held off from changing this part due to its labor intensity and place of a new rack ( $1,000 ). Does anybody have a idea?
Old Jul 14, 2007 | 06:56 PM
irish44j's Avatar
retired moderator
hate to ask the obvious, but have you had an alignment recently? Sounds like you have excessive toe.....
Old Jul 17, 2007 | 05:07 AM
L.I. I30t's Avatar
Problem solved. The rack was leaking ( I knew this for over a year ) and the fluid was collecting near the lower control arm bushing. It ate away at the bushing causing movement of the arm. So I replaced the arm and the rack then aligned the vehicle. Everthing is back to normal. Thanks irish44j for your reply.
lowpost99
Oct 26, 2025 06:53 PM
gustavison
Oct 4, 2015 06:50 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
pktaske
Sep 4, 2015 08:40 AM
