Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Replacing fr struts. What else?
Old Oct 27, 2008 | 12:38 PM
Madmax66's Avatar
My front right Tokico is shot and am replacing w/ Monroe Gas matics per org member. I've read several threads that suggest replacing sway bar bushings, strut mounts, etc. Are there things I should DEFINITELY replace w/ new struts? And what parts need to be CHECKED for wear/replacement? 97' w/ 165K miles....lil aggressive in turns at times but generally led a good life. Axles were replaced 2 yrs ago. Thanks!
Old Oct 27, 2008 | 02:13 PM
Matt93SE's Avatar
STFU n00b!
Whoever told you to install Monroes is a moron. go find them and kick them in the *****.
Old Oct 27, 2008 | 08:28 PM
MrDicks95SE's Avatar
Offset Is Everything.
i wouldve stuck with the Tokico's instead of getting Monroe's. I duno who told you to go that route but on some ball kicking.
Old Oct 27, 2008 | 08:32 PM
The Law's Avatar
I R The Law
[QUOTE=Matt93SE;6676153]Whoever told you to install Monroes is a moron. go find them and kick them in the *****.[/QUOTE
on kicking the *****. Tokico is hell of a lot better.
Old Oct 28, 2008 | 10:49 AM
Madmax66's Avatar
OK, well let me preface that a bit. I was initially asking about re-installing the OEM struts when he suggested the Monroes. I'm keeping the Eibachs for the lowered ride...and am OK w/ a more compliant ride...and lookin to spend as lil $$ as possible to get a decent ride.
Better suggestions? And per original ??....anything else I should def replace?
Thanks!
Old Oct 28, 2008 | 11:13 AM
jg_98max's Avatar
Strut bearings, if they weren't already on the list.
Monroe's may not have enough damping to control the Eibach's, which could lead to a bouncy ride.
Old Oct 28, 2008 | 11:28 AM
Madmax66's Avatar
For less bucks...KYB's? Or just replace the one bad Tokico blue and hope the drivers side isnt ready to die? Bearings seem to be a popular item and what about Eibach adjustment kit...given I have Eibachs on there now?
Thanks!
Old Oct 28, 2008 | 02:58 PM
RA030726's Avatar
I'm nutty for Nissans
gr2 would be the better match for eibachs for sure. the ride will be more harsh however, so if you need a comfy ride stay with the hp's.
Old Oct 28, 2008 | 03:12 PM
Madmax66's Avatar
GR2's MUCH harsher than Tokico's? Wow. DEF don't want that. Think the Monroe Sensa Trac's any better match?
Old Oct 28, 2008 | 03:49 PM
in general, KYB are valved stiffer than Tokico's. stay with Tokico if you want a smoother comfortable ride.
Old Oct 28, 2008 | 05:57 PM
RA030726's Avatar
Honestly I wouldnt pair any non adjustable with such a stiff spring like eibach. Monroes are crap from what I read. They may work fine, they may blow in a month. I really dont know.
If you really wanted a good ride, read comfy, you would buy konis and shorten them.
Old Oct 29, 2008 | 03:18 PM
Matt93SE's Avatar
STFU n00b!
If you want a comfy ride, get rid of the Eibachs and go with something softer. The struts are only used to slow the motion of the car and should compliment the springs. Putting a crap soft strut under a stiff spring will only result in the "riced-out honda bounce" and give you crap ride quality.
If you want to keep the Eibachs, then replace the fronts with a new PAIR of Tokicos, or buy a pair of GR-2s up front. On 3 gens, the Tokicos are a much better strut and last longer than the GR-2, but that's evidently not the case for 4 gens... Either way, you need somethign condierably better than Monroe.
Put it this way..... I wouldn't put Monroes on my Grandma's Buick. They're STILL too soft.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
