Sponsored by:
Sponsored by: CARiD
3.5 tb on a 2000 max
Old Dec 7, 2004 | 10:19 PM
frankd121's Avatar
3.5 tb or q45 tb on a 2000 max
Would you get noticible gains with the 3.5 tb or should I go with a larger tb, lets say a q45 tb? Also, if the 3.5 is worth it, how would you by pass the electronic drive by wire?
Whats the stock size of the VQ30 tb? I know the Q45 tb is 90 mm... and is it possible to mount on of these on a VQ30?
Old Dec 8, 2004 | 06:59 AM
subs1000w's Avatar
i dont thinkyou can just bypass the drive by wire
isnt a q45 TB someting like 90mm. it would proboly be to big
Old Dec 8, 2004 | 07:56 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Drive-by-wire is probably easy to remove and attach older 5th/4th gen TB spool.
IACV is the problem and probably TPS.
Old Dec 8, 2004 | 11:15 AM
Nismo3112's Avatar
Custom User Title
I dont think a 2000 Max has DBW
Old Dec 10, 2004 | 06:35 AM
Zack342's Avatar
It would be easier to use a non drive by wire 3.5 throttle body from a Pathfinder.
Old Jul 27, 2005 | 02:43 PM
Max1man's Avatar
But what year I been scouring for a clear definate answer but never is a year given hehehe. I think it's the 2001 Pathfinder VQ35 TB that works on the Max's VQ35 IM isn't it? Also isn't clear yet if it's a direct bolt on or if adapter plates are needed.
Old Jul 28, 2005 | 08:06 AM
DandyMax's Avatar
3.5 in the works
2001 3.5L Pathfinder (>08/00). You'll need an adapter plate for a DE, DE-K, or MEVI.
Old Jul 28, 2005 | 08:28 AM
Max1man's Avatar
Is this the same adapter that places the pathy tb on a 3.0 USIM?
Old Jul 28, 2005 | 08:59 AM
Kevlo911's Avatar
Kevlo for President
No, the 00-01 needs a differ adapter plate for the Pathy TB than the 4th gens.
Old Jul 28, 2005 | 10:15 AM
DandyMax's Avatar
3.5 in the works
Sorry, I didn't mean to imply the plate was the same for DE, DE-K, or MEVI... just that you'd need "a plate" to fit the TB on any of those manifolds.
Old Jul 28, 2005 | 11:19 AM
MoMax00's Avatar
im just wondering what kinda of gains would a swap like this produce? and where to find adapters for that kinda swap, does it have to be custom made?
Old Jul 29, 2005 | 05:29 PM
laylow1988's Avatar
i'm in the process of doing this modd. stephanmax is making the adapter plates for me while i search for the tb. he sells them for $100. try pm'ing him
Old Aug 1, 2005 | 05:57 PM
MoMax00's Avatar
does anyone have an idea of what kinda gains it might produce and also if i were planning on doing turbo to my car in the future would that be a problem being it would have more intake air flow?
Old Aug 1, 2005 | 07:04 PM
vipervadim's Avatar
I like Maximas
a larger TB 70mm (3.5L) would only be beneficial to a turbo/sc setup
more air into the engine + more fuel = more power.
now imagine how much air would flow at a time through a 60mm tb and then a 70mm tb.
but using a q45 tb will ruin your engine responce because of flow. air flows faster through a smaller diameter hose than a larger one (physics) if you go too big air will flow very slow (vq30 engine vacuum is not like a 4.5L v8 vacuum) and you won't be putting more air into the engine
with a PF tb or vq35 tb you will increase engine responce.
Old Aug 3, 2005 | 06:53 PM
MoMax00's Avatar
Ok i see what u guys are saying by putting more air in, but waht about gains what kinda gains would it show 1-5hp? anything like that? also would it be an easy swap with having the right adapter for it all ready?
QueensMAX
Sep 15, 2015 04:14 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
MaxRPM6
Sep 11, 2015 06:56 PM
ballerchris510
Sep 11, 2015 05:29 PM
MaxLife17
Sep 8, 2015 02:36 PM
