Sponsored by:
Sponsored by: CARiD
Another 00VI installed on a 4th gen.
Old Dec 15, 2004 | 02:28 PM
  #41
krismax's Avatar
Father of the 00 VI
With the brackets that attach to the rear of the IM's I took them off and trashed them they unbolt from the engine.
Old Dec 15, 2004 | 06:49 PM
  #42
BSwithTF's Avatar
Originally Posted by IceY2K1
You need to turn down your fuel pressure to compensate for the 240cc-->290cc injector increase. Krismax didn't have a problem, but he was using a 4th gen IAC and StephenMax doesn't have a problem because he opened up the throttle plate and is running 370cc w/JWT ECU.
Just something you might consider.
I installed a V-AFCII thinking I would have this problem and went to get it tuned. The guy at the dyno said the A/F was as good as he could get it. He tried to change some stuff in a couple area's but didn't have any luck. I've read JWT ECU's don't react well to S-AFC's/V-AFC's. I didn't get a graph, but I am going to dyno again on the 18th and I will request an A/F graph this time for sure so I can review it and put it on here for you guys to see as well. I'm going to try the throttle plate idle control method and see if that helps.
Old Dec 16, 2004 | 05:06 AM
  #43
Stephen Max's Avatar
Originally Posted by JMooney5115
Stephen Max: About how long would this take to swap?
Mooney
I didn't keep very good track of the time I spent on it, but I spent several evenings modifying the lower IM, making the adapter plate and match porting the IM, and about four hours removing the mevi and lower IM and installing the modified lower and the 00VI. Installing the 00VI took a lot longer than I expected because of having to grind down the coil pack front mounting bosses on the rear valve cover.
Old Dec 16, 2004 | 07:10 AM
  #44
I took a look at Z32 maf volts that I datalogged during my last dyno session a couple of weeks ago compared to maf volts with the 00VI installed. It shows the 00VI produces as much as a 6% increase in airflow compared to the MEVI.
One caveat though, is that the data for the 00VI was collected on a considerably colder day than the dyno session (about 30 degrees).
At any rate, I am going to dyno again tomorrow, then we can compare results corrected to standard temp and air pressure.
Old Dec 16, 2004 | 07:36 AM
  #45
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
That's not measured during cold starts, which is where you are having an issue. You need to turn down the base fuel pressure for cold starts when the ECU dumps in tons of fuel for cold start enrichment.
Old Dec 16, 2004 | 07:45 AM
  #46
BSwithTF's Avatar
Ahh, I see. Damn, gotta buy more parts.
Old Dec 16, 2004 | 08:22 AM
  #47
Nismo3112's Avatar
Custom User Title
What are the coil pack mounting bosses? Krismax didn't have to do this??
Old Dec 16, 2004 | 08:24 AM
  #48
Jason R's Avatar
aka UNCDooD
BSwithTF you got PM.
Old Dec 16, 2004 | 08:30 AM
  #49
Those are what the coil packs bolt onto. There was interference with the underside of the 00VI and those bosses. I'll explain all this and show pics if I can get around to doing the writeup.
Either Krismax had to do this or he used a 5th gen rear valve cover and coil packs.
Old Dec 16, 2004 | 08:48 AM
  #50
Nismo3112's Avatar
Custom User Title
A write-up would be great... Are the coil packs still able to be bolted onto the valve cover?
Old Dec 16, 2004 | 08:55 AM
  #51
I'm using the back bolts but not the front.
Old Dec 16, 2004 | 09:08 AM
  #52
Broaner's Avatar
2060lbs and falling...
Does the IM have enough support if this is done? I'd like to get rid of those things because it makes removing and installing the IM much more difficult. Also, they are worth about a pound. I'm still using the USIM but I'm wondering about this.
Old Dec 16, 2004 | 09:17 AM
  #53
The 00vi is lighter and uses 6 bolts at the lower/upper IM interface the way I have it mounted. It feels quite rigid and I feel the support is very adequate for street use. Probably wouldn't want to do any serious off-roading, though.
Old Dec 16, 2004 | 10:58 AM
  #54
Broaner's Avatar
Would you say it'd be alright to remove one of them atleast?
Old Dec 16, 2004 | 11:08 AM
  #55
Sure.
12345
Old Dec 16, 2004 | 11:28 AM
  #56
krismax's Avatar
Father of the 00 VI
Nope,i used 96 valvecover and 96 coils it all fit perfect.
Remember you didnt use the 00 lower IM that prob changed it for you.
If i person uses the 00 lower and upper you will have a bolt on beauty.
Old Dec 16, 2004 | 11:31 AM
  #57
krismax's Avatar
Father of the 00 VI
I have the 00 back brackets if you want to buy them there really prob 3-5lbs and i didnt use a one and i bought them brand new.
Think about this when i went to the maxima meet same day i swapped it in front of deezo i grabed the dek manifold and started violently rocking the car just by the IM. Trust me if i can do that then the IM doesnt need the rear braces.
Old Dec 16, 2004 | 11:38 AM
  #58
Thanks for the info.
Old Dec 16, 2004 | 11:48 AM
  #59
Broaner's Avatar
Cool. Count me 3-5Ibs lighter.
Old Dec 20, 2004 | 10:09 PM
  #60
kraimer21's Avatar
I'll do a writeup later this week, and I'm going to try to get to the dyno stand by Friday, too.
Did you ever get a chance to do it?
Old Dec 21, 2004 | 05:37 AM
  #61
I did the dyno, but haven't started on the writeup. Probably after Xmas.
Old Dec 21, 2004 | 11:02 AM
  #62
goodhead's Avatar
i have 00 vale covers if anyone needs them
Old Dec 21, 2004 | 06:31 PM
  #63
96sleeper's Avatar
Looking at the dynos, it doesn't make power higher up than the MEVI, which is what everyone originally thought. The curve is just higher everywhere. That looks like the dyno gains of an intake manifold that has been extrude honed. I wonder if the gains from the 00VI come partially from the fact that it is smoother plastic compared to cast aluminum? Just a random observation and thought.
Old Dec 22, 2004 | 05:25 AM
  #64
I think so, too. But the curvature of the runners is greater than with the USIM as well, resulting in a lower loss air path to the engine. Anything that reduces abrupt changes in cross-sectional area and flow direction will result in more air flow in a duct for a given pressure drop.
Old Dec 22, 2004 | 08:10 AM
  #65
IceY2K1's Avatar
I'd say that is part of it...per SAE tech doc:
"REDUCTION OF INTAKE RESISTANCE – Intake
resistance has been reduced in the VQ30DE by adopting
a plastic intake manifold so as to reduce surface
roughness."
Also, to StephenMax point:
"REDUCTION OF AIR LEAK OF VARIABLE INTAKE
SYSTEM – In the VQ30DE, the air leak in the variable
intake system has been reduced by adopting a labyrinth
structure for the rotary valve, which is used as the inertia
adjustment valve. Since the inertia effect can be utilized
more effectively, volumetric efficiency is improved."
Old Dec 22, 2004 | 08:15 AM
  #66
IceY2K1's Avatar
Also, the heads/cams are probably the bigger restriction now.
Old Dec 22, 2004 | 08:45 AM
  #67
JeffesonM's Avatar
living out of a maxima...
SM... you're PM box is full!
Old Dec 22, 2004 | 08:49 AM
  #68
Try again, I deleted some stuff.
Old Dec 22, 2004 | 10:01 AM
  #69
JeffesonM's Avatar
Old Dec 24, 2004 | 02:09 AM
  #70
Nismo3112's Avatar
Custom User Title
Pics of my progress:
Old Dec 24, 2004 | 07:24 AM
  #71
Kevlo911's Avatar
Kevlo for President
4th gen TB? Any close up pics of it? Does hte tb spring/cable area move all the way to WOT?
Old Dec 24, 2004 | 09:59 AM
  #72
Nismo3112's Avatar
Custom User Title
Yep its a 4th gen TB, I had to make the adapter out of 2 plates so there would be enough clearance for the cable mechinism to rotate freely, and also for the TPS to sit nicely.
Old Dec 24, 2004 | 10:53 AM
  #73
Kevlo911's Avatar
Kevlo for President
Ya, I have to do some modification to my block for those 2 reasons. I should have went with hte Pathy TB and it would have been in yday.
Old Dec 25, 2004 | 05:18 PM
  #74
Nismo3112's Avatar
Custom User Title
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
Lowered_a33
Sep 1, 2015 07:49 PM
