Sponsored by:
Sponsored by: CARiD
swapping ecu's
Old May 6, 2005 | 10:13 PM
MyownNismo's Avatar
Future Camaro SS owner
swapping ecu's
Is there anyway I can swap a 00 ecu to a 2k1 ecu to get the TS ECU.
Old May 7, 2005 | 06:19 AM
Kevlo911's Avatar
Kevlo for President
I have asked this a few times but got no real answer. I know one problem will be the EGR system. 00Fed spec have it and the 00Cali and 01 do not. It won;t throw a CEL because its not in the ECU to begin with. If the wireing harness is the same, I don't see why it would not work. It should be like the 97-98 using 95-96 ECUs
Old May 7, 2005 | 07:02 AM
Ghase's Avatar
I wondered the same thing, but for me it might not be necessary because I’ am getting SC maybe by mid summer.
Old May 9, 2005 | 03:35 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I've looked over the wiring diagrams a bit and 2000 Cali spec-to-2001 looks identical as far as ECU pinout is concerned. Also, the ECU connectors are all the same, so it should plug right in. Once(read *IF*) the 2001 Cali-spec TS ECU was released, my next step was to attempt this. I hope someone does this anyways, just to know.
If you have a FED spec or auto, then you could have more complications like the EGR to no EGR(mentioned above) and maybe the TCM stuff...I'm not sure.
Old May 9, 2005 | 05:14 PM
MyownNismo's Avatar
Yeah I am fed spec and auto. What could be some effects if it wasn't to work. I don't see how the TCM would effect anything cause isn't the anniversary was the only one with a different tranny.
Old May 9, 2005 | 05:24 PM
IceY2K1's Avatar
What wasn't to work? EGR system?
TCM just means more wires, since the ECU and TCM are interconnected. Might be plug-n-play also, I haven't looked at the schematic for autos though.
I'm sure there will be some differences, ie NOT just 100% P-N-P, however all the "critical" stuff the FSM shows seems to match between the 2000 Cali and 2001s.
Old May 9, 2005 | 05:59 PM
MyownNismo's Avatar
If the ecu wouldn't work. If it all comes down it wouldn't let the car start right.
Old May 9, 2005 | 06:03 PM
IceY2K1's Avatar
Depends on what isn't compatible/complete.
The car could start, but just throw codes or idle rough or possibly go into limp mode or just run like crap since it's fuel/timing maps are for an EGR setup, I don't know.
Old May 9, 2005 | 06:47 PM
2kGLE's Avatar
That's good to know. I have a 2k1/5spd/cali ECU sitting around that I was hoping to try this with, but I haven't decided exactly what I'm going to do with my car yet…been busy with school.
Just to put another idea out there, I was thinking, for 2000/2001 people interested in doing 3.5 swaps couldn't TS essentially put the 3.5 maps onto the 2k1 ECU and tweak it accordingly? I spoke with Brian at TS a while ago about the possibility of them tuning a 5.0 gen with a 3.5l hybrid (3.0 timing chain/oil pan, intake/headers/exhaust, etc). My idea was to reflash the 2k1 ECU with their current 3.5/headers program and tune it to accommodate for the lack of VTC. Brian said it should work in theory, but he would have to talk to Tedeshi (sp) about it. I haven’t followed up on this yet but I thought it was worth mentioning. Can anyone here come up with a reason this wont work?
Old May 17, 2005 | 02:25 PM
michaelnyden's Avatar
well I am getting a 2000 cali spec...so if I get an 01 cali spec ecu it should just plug right in right? without any cel's...I would hope...
Old May 17, 2005 | 02:53 PM
amomaxima's Avatar
i have been wondering the same thing for a while and i seee that there is a lot of emphasis on whether the car is fed or cali and i dont know which mine is, can anyone tell me how to figure it out. Also if i am reading right the cali 00 and 01 are the same ecu? Do i have that right. Cuase if i can use a 2k1 ecu i am down to try it and see what happens.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
