Sponsored by:
Sponsored by: CARiD
Mix and Match coils
Old Jun 15, 2005 | 08:18 AM
Kevlo911's Avatar
Kevlo for President
Mix and Match coils
I am changing my rear vavle cover gasket since it leaks, I am replaceing the vavle cover with the 00 one and I am going to use the 00 NONupdated coils in the rear and my 97 coils in the front. I should not misfire correct? Thse coils were working when I removed them from the old engine.
Old Jun 15, 2005 | 10:05 AM
BSwithTF's Avatar
I'm not sure what you mean by 'non-updated coils' but I'm running '01 coils in the rear and '96's in the front with no problems.
Old Jun 15, 2005 | 10:17 AM
Kevlo911's Avatar
Kevlo for President
00 Had coild problems, the newer coils had a grey dot on them. I have the original coils, w/o grey dot. But since yours work, mine should too.
Old Jun 15, 2005 | 10:41 AM
MaxesRule's Avatar
Sorry to but in guys, but Kevlo, are you switching coils to avoid grinding down the rear coil mounts, or b/cuz the 4th gen coils won't fit properly on the 5th gen rear valve cover? Is there any way to avoid grinding down those coil mounts on the 4th gen rear valve cover when installing the 00 VI?
Oh, and thanx for your reply on helping me install a VI on my 96. Hopefully I'll have the money for the parts sometime soon, so I'll let u know when I'm ready.
Old Jun 15, 2005 | 11:08 AM
sx7r's Avatar
http://forums.maxima.org/showthread.php?t=410232
Old Jun 15, 2005 | 01:30 PM
Kevlo911's Avatar
Kevlo for President
Those 00coils are in and running good, no misfires.
Old Jun 15, 2005 | 07:39 PM
eckohb's Avatar
so can you use the 4th gen valve cover with the VI? the only 5th gen part that will be on my car will be the VI. I guess we'll be going with the grinding of the coil mounts, seems to be the best bet. Also will be using 4th gen coils. Kevlo, did you 1/4 mile your car yet? Dyno?
Old Jun 16, 2005 | 06:39 AM
Kevlo911's Avatar
Kevlo for President
Power is really really weak. But the 00vi difference is there. That dyno sucked bad, I am going to redyno and tune here. I used someone elses AF tuning so it is wrong anyways, I can get more power out of it. The redline is no tuning or rpm switch and those numbers also suck.
Old Jun 17, 2005 | 11:20 AM
eckohb's Avatar
did you use the smt-6 or 7 for the tuning? why did the dyno suck? you can definitely see the effect of the VI being on as the power keeps climbing. What rpm did you have the rpm switch set at?
Old Jun 17, 2005 | 11:24 AM
Kevlo911's Avatar
Kevlo for President
SMT6 AF tuning only, no timing. 4900 switchover.
I should be making more power. Redline is w/o smt in. It's only 155hp That is a stock Maxima. I have a ypipe too
Old Jun 17, 2005 | 11:27 AM
eckohb's Avatar
thats what i was going to say. Thats what a stock auto should be putting out. KS bad, or throwing any codes? So you set the rpm switch for 4900 and thats when it opens? I remember reading that people had to set it earlier because these switches are designed for 8 cyl. vehicles.
Old Jun 17, 2005 | 11:30 AM
Kevlo911's Avatar
Kevlo for President
Well I am using the SMT6 as my RPM switch too. So it opens at 4900. No codes or ghost codes. I think I may have had bad gas on the dyno because car started to knock on first run when I had some timing advance.
Old Jun 17, 2005 | 11:32 AM
eckohb's Avatar
oh, didnt know the SMT was the rpm switch. I gotcha. Is that the best switchover point? Or do you have to dyno to actually find the best point. I know some people were using 4600, but i read some other guy say anything lower than 5000 causes it to bog. We are going to start ripping my car apart tonite, and hopefully finish up the install on saturday.
Old Jun 17, 2005 | 11:33 AM
Kevlo911's Avatar
Kevlo for President
If the dyno didnt fck up, I would know the better switch over but as you can see tha gaps do not help at all.
Anything lower than 4900 is not good, you lose power.
Old Jun 17, 2005 | 11:42 AM
eckohb's Avatar
alright cool. yeah, the gaps dont help at all. Looks like we'll aim for 4900 then. good luck with tuning your car to get it running right. That thing should be a beast, not putting out i/y/e numbers
TallTom
57
Oct 14, 2025 05:16 PM
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
