Sponsored by:
Sponsored by: CARiD
What's the most beneficial A/F ratio?
Old Jan 20, 2006 | 06:00 AM
  #41
TILLEYS99's Avatar
Lives in a 11sec maxima
Originally Posted by 98SEBlackMax
All these VQ35 4th gen swaps and no one has done a decent tune...
Only if I had the cash to blow on this car.
And why do you say that....the maxima ECU wont let you go overboard on tuning cause it just changes it next run. The guy at the dyno did what was best for NA, keep in mind that he is a smart guy and dynos penske indy cars. He tried adding fuel but the ecu just fights it till its back to normal.
Old Jan 20, 2006 | 06:46 AM
  #42
Kevlo911's Avatar
Kevlo for President
That is the problem, he needs to lean it out more.
Old Jan 20, 2006 | 10:00 AM
  #43
98SEBlackMax's Avatar
Maxima.org Insomniac
I agree that the ECU limits major tuning changes. However when I tuned my ECU it never fought any of the A/F or Timing advance changes. It only lost power when it had a CEL for the cam sensor and that is at the limit of timing advance with the SMT-6.
Old Jan 20, 2006 | 11:22 AM
  #44
Alex_V
so you guys have never thought about megasquirt? For about $180 you can control fuel and spark completely. diyautotune.com has prices and for info go to megasquirt.info For your VQ's Id use Megasquirt 1 and Megasquirt N spark-extra software. Thats what Im using in my RWD project and Im using it on a VQ30. It'll work fine with the stock coil over plug setup too.
~Alex
Old Jan 20, 2006 | 12:15 PM
  #45
Velicos's Avatar
My N/A VQ35 I'm creating the most power using the following:
3500-4000rpm 13.0 AFR
4000-5000rpm 12.8 AFR
5000-6800rpm 12.5 AFR
Old Jan 23, 2006 | 02:02 PM
  #46
vipervadim's Avatar
I like Maximas
~Alex
Can't wait to see your results Alex...
Old Jan 23, 2006 | 06:38 PM
  #47
Alex_V
Yea I cant wait to start either!! The weather needs to make up its mind though, 20-30 one day then 40-50 the next. Oh well Im going to order the MS soon and put it on my VG to see how to set it up and tune it. I cant wait till spring so I can start working on the body.
Allen- Hows the IM going?
~Alex
Old Jan 23, 2006 | 07:22 PM
  #48
NmexMAX's Avatar
dot dot dot ...
So what's the answer to this thread?
Old Jan 23, 2006 | 08:33 PM
  #49
DandyMax's Avatar
3.5 in the works
The answer is go tune your own car and find out... everyone's car and mods are different not to mention atmospheric conditions and dynos but generally it seems it's in the range of high 12's to mid 13's.
Old Jan 23, 2006 | 08:35 PM
  #50
NmexMAX's Avatar
dot dot dot ...
That's EXACTLY my point ....
Just like every car has a different base A/F before tuning, every car is different and will react so to various A/F's.
Just like 1/4 mile times and dynos, it depends on the conditions on the day of tuning, etc:
On a side note, I've heard that keeping a constant line (straight) is best for VQ35's. Other's tune a bit more rich up top. One logic for this is to reduce/reguate heat up top, as well as companesate for spark energry reducing as engine speeds increase. May or may not be true.
Another one of those situations where there are too many variables to decide what is the best A/F for a given car for a given day.
Back to the cookie cutter method...
Old Jan 25, 2006 | 07:51 AM
  #51
Fred Allen Burge's Avatar
~Alex
No progress lately, had a wedding to go to this last weekend, this coming weekend I'll make some nice headway, I'll post up in the original thread.
allen
vybz05
Dec 10, 2015 07:38 PM
Serotta33
Sep 17, 2015 12:14 PM
AT978
Sep 6, 2015 10:31 PM
