Sponsored by:
Sponsored by: CARiD
350z IM on fwd maxima
Old Mar 7, 2006 | 07:43 AM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Would it be possible to just cut the neck and weld on a new TB plate facing the drivers' side?
Old Mar 7, 2006 | 07:45 AM
  #42
vsamoylov
go ahead and try it
Old Mar 7, 2006 | 07:49 AM
  #43
Nismo3112's Avatar
Custom User Title
Ding ding ding. We have a winner!
Old Mar 7, 2006 | 08:07 AM
  #44
Tatanko's Avatar
Bacon Lover
That's what Vasily and I were discussing last night, but since he doesn't much care about it...well...
Vasily, check your PMs.
Old Mar 7, 2006 | 08:14 AM
  #45
IceY2K1's Avatar
I was just hoping he had some insight into whether it *MIGHT* be possible, since I don't have a 350Z UIM sitting here in front of me....
Old Mar 7, 2006 | 08:15 AM
  #46
chris'smax's Avatar
are you sure it will fitt even with the neck cutt off? I have been thinking about this and it still seems the manifold doesn't slope down enough in the front.
Old Mar 7, 2006 | 08:19 AM
  #47
Puppetmaster's Avatar
Well, it seems his "insight" was hardly helpful.
Originally Posted by vsamoylov
go ahead and try it
Old Mar 7, 2006 | 08:23 AM
  #48
Originally Posted by virgilio7
I don't think this can be done cause of the way the runners are setup. one bank is going to have more flow than the other. 3 runner are going to get all the air. you will have to turn 90 degrees the whole plenum.
I was actually thinking along those lines too (and I'm still learning here). The openings from the runners are currently all in line with the IM, but if you rotate the lower 90 degs, they'd be perpendicular. Wouldn't that disrupt the flow pretty significantly even if the lower could be designed to feed all 6 cylinders equally?
Or maybe I'm misunderstanding what Matt's idea is...
Old Mar 7, 2006 | 08:24 AM
  #49
chris'smax's Avatar
+1 on that brotha
Old Mar 7, 2006 | 08:27 AM
  #50
chris'smax's Avatar
i am not going to be worrying about 6.3 % flow that the 335cc injectors give over the 315cc injectors. if i were using way bigger injectors then its a different story
But why would you use bigger injectors than necessary and not tune the AFR back to stoich? That makes you LOOSE POWER. Its like shooting yourself in the foot.
  #51
Kevlo911's Avatar
Kevlo for President
He usually isnt because his bro does everything and the way they do everything is the right way.
Old Mar 7, 2006 | 08:35 AM
  #52
gtr_rider's Avatar
192.168.1.1
ha
Old Mar 7, 2006 | 08:42 AM
  #53
Nismo3112's Avatar
Custom User Title
I'm sure it will still be too tall, but instead of having a total of 4 bends in the intake piping like vsymoylov, there will be no bends, maybe 1 bend, and the intake piping won't have to be routed in front of the engine.
Old Mar 7, 2006 | 09:13 AM
  #54
IceY2K1's Avatar
+1....the hood clearance will still be an issue, I just don't like how he routed it.
Kinitex or whoever could easily change their mold to have a straight inlet and slant down even if needed. I wonder how many orders it would take to get them interested.
Old Mar 7, 2006 | 09:22 AM
  #55
Jeff92se's Avatar
I'm needing a caw
There's supposed to be one for the V6 altima going on now. Not sure if they ever finished but it WAS being produced.
Old Mar 7, 2006 | 09:27 AM
  #56
Glude's Avatar
The thread on the altima board is long. Who knows if they will ever finish that thing, plus its going to cost 800+.
Old Mar 7, 2006 | 09:30 AM
  #57
Nismo3112's Avatar
Custom User Title
I woulndn't put my money on that their manifold is going to be coming out. 80 pages and 1200 posts later and they still have yet to come out with anything.
Old Mar 7, 2006 | 09:34 AM
  #58
SR20DEN's Avatar
VQ Wizard
Some people just refuse to listen and learn from the experience of others. Have fun with another new project with sub-par performance.
Old Mar 7, 2006 | 09:52 AM
  #59
Kevlo911's Avatar
Kevlo for President
Maybe if his bro decides to do it he will let us know and somehow make it seem that he was right all along
Old Mar 7, 2006 | 10:55 AM
  #60
maxS
[QUOTE=SR20DEN]Above 40% throttle it will not. You need to put the 315cc injectors back in, or get a piggyback fuel computer to compensate for the 20cc flow difference while in the static maps.
There is no science behined this statement
Old Mar 7, 2006 | 10:58 AM
  #61
vsamoylov
you used 390cc not 335cc injectors. so the difference between 315cc and 390cc is 75cc so that is a 24% increase. here we are talking about less way less flow.
and the reason why i said go ahead and try it because i dont see a point in it. and whoever said about the bends in the piping nothing is wrong with it and there is nothign wrong with putting the piping in frotn of the engine. look at the sc guys and where the piping runs.
  #62
maxS
And some people go nuts when they get their but kicked.
Old Mar 7, 2006 | 10:59 AM
  #63
vsamoylov
if doing things the cost effective way and having logic and getting it done is the right way, i cant argue with that.
Old Mar 7, 2006 | 11:00 AM
  #64
virgilio7's Avatar
kinetix is supposed to release it anyday now. BUT, they been saying that for a while. last week they said 2 weeks max for final test fitting.
Old Mar 7, 2006 | 11:07 AM
  #65
maxS
BTW, we really are having FUN with this project and its performance...
Old Mar 7, 2006 | 12:17 PM
  #66
Kevlo911's Avatar
Kevlo for President
Oh the irony...
Old Mar 7, 2006 | 12:32 PM
  #67
chris'smax's Avatar
He's not arguing that it is a small jump in injector size, he is just saying you will not be hitting the full potential of your setup. Some 5.5gen guys gain a substantial amount of power by using a safc to tune their afr. You are just digging your self deeper in a hole by not tunning that car while running larger than stock injectors. I believe that the 5.5 gen runs rich after 5k rpm w/ factory settings. Do yourself a favor and get a piggyback, tune it and enjoy it
Old Mar 7, 2006 | 12:52 PM
  #68
tavarish's Avatar
fwd gone rwd cr00
so with my 4th gen ECU, i'll definitely be sure to use an AFC. the ECU won't be able to compensate for the larger injectors, and i'll be sure to use the stock 3.5 injectors. No point in doing it wrong the first time.
Old Mar 7, 2006 | 12:56 PM
  #69
chris'smax's Avatar
It will compensate while in closed loop. When in open loop (above 40% throttle) that is where the SAFC is used to make fuel adjustments. And yes you will have to use the the 3.5L injectors or DEK injectors along with the 3.5 or DEK injector clips
Old Mar 7, 2006 | 01:23 PM
  #70
SR20DEN's Avatar
VQ Wizard
How many A33Bs have gained power from removing excess fuel from the STOCK 315cc injectors? About 95% of the A33Bs on Maxima.org that have piggyback fuel computers installed have had to remove 5-10% from the MAF voltage while using the STOCK 315cc injectors.
If that still doesn't spell it out for you I don't know what will. But you've already made your point clear that you refuse to agree so it's pointless for me to offer anymore assisntance in this thread.
Have fun with your car and your 11:1 A/F Ratio.
Old Mar 7, 2006 | 01:30 PM
  #71
tavarish's Avatar
fwd gone rwd cr00
why run rich at all? No point, if all you have to do to lean it out a bit is to use stock injectors. AFC here I come!
Old Mar 7, 2006 | 01:54 PM
  #72
NmexMAX's Avatar
dot dot dot ...
No dyno no care.
No track times, no dynos to go by, nothing.... Just pictures. But from the pictures should come data.
Old Mar 7, 2006 | 02:59 PM
  #73
Nismo3112's Avatar
Custom User Title
I never said there was anything wrong with your piping, although I think most would agree that getting rid of the plenum elbow and using one straight intake piping would be a better choice.
Old Mar 7, 2006 | 03:47 PM
  #74
IceY2K1's Avatar
NA intake resistance is far more serious then on a FI car.
Just look at how optimized, ie straight, the stock 350Z setup is. If you care to learn why, read the SAE technical paper on it and the 20% less restriction it caused.
Old Mar 7, 2006 | 04:44 PM
  #75
vsamoylov
Man everybody is soo smart here with their comments.
first of all about the piping. a couple of 45 degree bends in 3 inch piping will provide intake resistance? prove that.
open loop is when the throttle is wide open. how is 40% open loop? so you are saying i am driving in open loop all the time which means no feedback from o2 sensors?
the ecu still compensates for the added fuel
Old Mar 7, 2006 | 04:49 PM
  #76
maxS
well... ppl, please do not make silly conclusions, you don't have all the info on the setup, trust me. how about if i said that we are running a z ecu, that should be good enough, right?
the other thing, if someone can prove that a few 45 deg bends on 3" piping create that much of a restriction, i WILL rework the setup.
Old Mar 7, 2006 | 04:56 PM
  #77
chris'smax's Avatar
Dude i just don't see why you are arguing w/ everyone on the ecu/ injector issue. It is stated in the damn FSM. Why do you think all these people bother with piggy backs? It sure isn't becuase they light up pretty. You will run rich and you you will see it if they hook up a wideband to your car on the dyno.
Old Mar 7, 2006 | 05:11 PM
  #78
NmexMAX's Avatar
dot dot dot ...
I commend you on what you did, but with these types of statements its still hard to respect yor knowledge. Open loop is not what you stated.
The info you need to read up on is in the FSM. What you typed, and your opinion on what exactly is happening when you say 'compenasate' makes no sense in relation to what the FSM states.
Old Mar 7, 2006 | 05:45 PM
  #79
vsamoylov
directly from fsm
"The amount of fuel injected from the fuel injector is determined by the ECM. The ECM controls the length of time the valve remains open (injection pulse duration). The amount of fuel injected is a program value in the
ECM memory. The program value is preset by engine operating conditions. These conditions are determined by input signals (for engine speed and intake air) from both the crankshaft position sensor and the mass air
flow sensor."
In addition, the amount of fuel injected is compensated to improve engine performance under various operating conditions as listed below.
<Fuel increase>
. During warm-up
. When starting the engine
. During acceleration
. Hot-engine operation
. When selector lever is changed from “N” to “D”
. High-load, high-speed operation
<Fuel decrease>
. During deceleration
. During high engine speed operation
  #80
vsamoylov
The mixture ratio feedback system provides the best air-fuel mixture ratio for driveability and emission control. The warm-up three way catalyst can then better reduce CO, HC and NOx emissions. This system uses
a heated oxygen sensor 1 in the exhaust manifold to monitor if the engine operation is rich or lean. The ECM
adjusts the injection pulse width according to the sensor voltage signal. For more information about the heated FE
oxygen sensor 1, refer to EC-240. This maintains the mixture ratio within the range of stoichiometric (ideal
air-fuel mixture).
This stage is referred to as the closed loop control condition. CL
Heated oxygen sensor 2 is located downstream of the three way catalyst (manifold). Even if the switching
characteristics of the heated oxygen sensor 1 shift, the air-fuel ratio is controlled to stoichiometric by the signal from the heated oxygen sensor 2. MT
