Sponsored by:
Sponsored by: CARiD
6 speed
Old Mar 28, 2007 | 12:55 PM
  #161
JClaw's Avatar
Whats definitive on the spacer? Can the SAME spacer work in order to use the 5-speed flywheel and clutch on the 6MT?
IMO if the spacer works its less of a hassle (not to mention the stock 50$ flywheel being only 18 lbs) to use the 3.0 clutch-flywheel combo. Theorically it should work with the same spacer thickness me and broaner used for our S13s with the RWD 6MT trans. But everybody seems to be contradicting one another. Whats the final answer on this one? Will the same spacer work or not?
Old Mar 28, 2007 | 01:08 PM
  #162
MAXSE5SPD's Avatar
i attempted to use the spacer. it moved the tob out, but in doing so, the clutch fork was altered so it would hit the drivers side of the cutout in the trans, therefore leaving about 1-1.5" of pedal play.
[IMG][/IMG]
i believe the spacer can be made to work. it would appear that if the pivot pin was also spaced out some, the spacer would work. but i ran out of time and patience, so i just baught all the 6spd stuff to get the car running.
Old Mar 28, 2007 | 01:09 PM
  #163
nismology's Avatar
If the spacer worked he'd be using it right now. Besides, using the 6-speed flywheel/clutch opens you up to a plethora of possible combinations.
Old Mar 28, 2007 | 07:12 PM
  #164
MAXSE5SPD's Avatar
so i worked a bit today. i got the axle kind of installed. i had to shave down a bunch of the support bracket
heres how far in the axle is
i still im weary of the 5spd bracket working. its just doesnt seem like the axle is far enough in.
also, it would appear that my starter solenoid is fried......great.
Old Mar 29, 2007 | 07:26 PM
  #165
JClaw's Avatar
[IMG][/IMG]
Do you have a picture of the spacer you used? I dont see why this works PERFECTLY on my 6-speed RWD trans, but cant work on a FWD 6-speed. I dont see the fork being all that different.
Nismology - A 5-speed flywheel with a 5th gen clutch is ALOT cheaper an aftermarket 6-speed clutch and flywheel and doesnt require you to 1) swap timing rings and 2) the stock 50$ steel flywheel is guaranteed to never warp and it weights 18 lbs - which is in the neiboorhood of what AFTERMARKET 6-speed flywheels weight. So IMO the spacer is still worth looking into. Once we figure it out, all we will need are the measurements for the spacer and the whole clutch-flywheel deal with be a heck of a lot cheaper since anyone doing the swap can simply use their stock flywheel and current aftermarket clutch.
Old Mar 29, 2007 | 07:52 PM
  #166
SR20DEN's Avatar
VQ Wizard
At least it appears you got a HLSD.
Old Mar 29, 2007 | 07:53 PM
  #167
nismology's Avatar
In terms of what's cheaper, agreed. In terms of the flat-out better option, i'll stand by statement. Many more options because it opens you up to the world of aftermarket 350Z flywheels/clutches which are abundant. Aftermarket 6-speed flywheels are generally in the 13-14 lb range, BTW.
Old Mar 29, 2007 | 08:31 PM
  #168
MAXSE5SPD's Avatar
mine is 13. i dont have a pic of the spacer right now, i can take one tomorrow. whats your guys opinion about the pass axle?
Old Mar 29, 2007 | 08:36 PM
  #169
nismology's Avatar
To tell you the truth, from that angle it looks like it's fine. The metal cap on the axle is just there to keep dust/dirt out of the seal. The seal is made on the axle shaft itself.
Old Mar 29, 2007 | 08:38 PM
  #170
MAXSE5SPD's Avatar
i just wasnt sure if enough of the axle splines were in the trans. i think when i get some more money, im gonna get a custom pass axle with an inch added from raxles.
Old Mar 29, 2007 | 08:40 PM
  #171
nismology's Avatar
If that metal cap is completely covering the lip of the seal, it's far enough.
Old Mar 30, 2007 | 03:46 AM
  #172
JClaw's Avatar
Originally Posted by 95turbo gxe
Well I found out From Tilley that you will have to use both 6 speed axel and you can retain the 4th gen hubs.
Whats up with Tilley.. did you speak with him recently...
Old Mar 30, 2007 | 04:26 AM
  #173
JClaw's Avatar
Does anyone know where we can get a good price on a stock 6-speed clutch. Im assuming theres an online source for this since the stock 5th gen clutch can be had for 180$ online. From what Ive heard the stock 6-speed clutch is verrry strong.
Old Mar 30, 2007 | 06:29 AM
  #174
MAXSE5SPD's Avatar
ive talked to tilley a few times on engineswaptech.com. charles talked to him on aim.
Old Apr 1, 2007 | 08:56 AM
  #175
MAXSE5SPD's Avatar
another update: the car is very close to being done. the 6spd axle went in, all the suspension is bolted up, wheels are on and its off jackstands for the first time in 43 days.
but im still having my electrical problem. whats happening is, what i believe a bad ground somewhere, but i took off all grounds from the battery and cleaned all of them, and made sure everything was tight.
ill try and start the car, this is what will happen.
1/10- the car will actually crank
4/10- all the dash lights will dim and there will be a spark noise, then all the lights will slowly return to normal
5/10- the starter solenoid will click rapidly.
the battery has enough volts. i attemped this after trying to charge it, and while i was jumping the car.
what do you guys think? any inputs will be greatly apprecated.
heres some pics of the car on the ground
http://s65.photobucket.com/albums/h217/MAXSE5SPD/
Old Apr 1, 2007 | 11:57 AM
  #176
Nismo3112's Avatar
Custom User Title
Seems like a starter issue to me. I know there's a power wire that goes to it directly from the battery, and a single pin wire too. What did you do about that?
Old Apr 1, 2007 | 11:59 AM
  #177
MAXSE5SPD's Avatar
well that specific wire is a male connector on the harness and a male connector on the 6spd starter, so i cut off the connectors wired and heat shrinked the wires together.
Old Apr 1, 2007 | 06:37 PM
  #178
nismology's Avatar
You mean you soldered the wires together, right?
Old Apr 1, 2007 | 08:22 PM
  #179
MAXSE5SPD's Avatar
no they werent before. but they are getting soldered tomorrow. and i am getting a new battery because my battery has had enough.
new problem: pass axle seal is leaking. great........
Old Apr 2, 2007 | 04:44 AM
  #180
SR20DEN's Avatar
VQ Wizard
http://forums.maxima.org/showpost.ph...7&postcount=15
Old Apr 2, 2007 | 04:56 AM
  #181
MAXSE5SPD's Avatar
how much are they? dealer only?
Old Apr 2, 2007 | 08:03 AM
  #182
Kevlo911's Avatar
Kevlo for President
Umm call and check lol
Old Apr 2, 2007 | 12:25 PM
  #183
MaxObesset's Avatar
for the 6th flywheel to work in your 97 you have to get it machined to have the same about of teeth i think theres 180 teeth on thr 4th gen flywheel and on the 6 speed one there 3 4 seperate spots thats what i was told
Old Apr 2, 2007 | 02:14 PM
  #184
MAXSE5SPD's Avatar
i got a bolt on 3.0 timing ring and attached that to my 350z flywheel.
Old Apr 3, 2007 | 07:33 PM
  #185
MAXSE5SPD's Avatar
another update: i baught a new battery and installed it and that fixed the starting problem. the car cranks everytime now. the cps sensor is pretty close but just not where it needs to be yet. heres me cranking it......note the beautiful starter noise.
the first 2 cranks were with the sensor in the normal spot, third was with it as far to the drivers side as i can, and the last was moving the sensor back and forth.
Old Apr 3, 2007 | 07:36 PM
  #186
Kevlo911's Avatar
Kevlo for President
Yeah I could never live with that kind of starter/startup noise
Old Apr 3, 2007 | 07:39 PM
  #187
MAXSE5SPD's Avatar
dont have much choice, cuz i dont know exactly whats causing it
Old Apr 3, 2007 | 07:57 PM
  #188
SR20DEN's Avatar
VQ Wizard
I haven't put any more effort into solving it either. I've just been dealing with it.
Old Apr 3, 2007 | 08:20 PM
  #189
liqidvenom's Avatar
brotherhood of tq
that sounds is something im used to hearing when ever we start up my friends jetta
Old Apr 3, 2007 | 08:36 PM
  #190
Nismo3112's Avatar
Custom User Title
Sounds like an old GM starter or something.
Old Apr 4, 2007 | 05:10 AM
  #191
MAXSE5SPD's Avatar
ya definately. it reminds me of a carburated v8. lol
Old Apr 4, 2007 | 08:25 AM
  #192
JClaw's Avatar
WTF... is he using that 290$ aftermarket flywheel... what could cause this...
Old Apr 4, 2007 | 08:37 AM
  #193
Kevlo911's Avatar
Kevlo for President
The flywheel
IIRC, some brands dont have the propper teeth for the starter so it makes that noise. Most have been fixed but some brands havnt.
Old Apr 4, 2007 | 10:01 AM
  #194
Red Lion's Avatar
lol, MaxSE5pd, doesn't your flywheel have the bolt-on ring gear from Travis? Isn't it supposed to have the same number of teeth as the 3.0 flywhee? Maybe the starter you're using has a different number of teeth than the 3.0 starter?
Old Apr 4, 2007 | 10:05 AM
  #195
Kevlo911's Avatar
Kevlo for President
No timing ring is not the same and he doesnt have a 30 starter/tranny
Old Apr 4, 2007 | 10:09 AM
  #196
nismology's Avatar
The thing he bought from travis is the timing ring. That has nothing to do with the starter noise.
Old Apr 4, 2007 | 10:25 AM
  #197
Red Lion's Avatar
ahhhh, lol I see.
I'd still venture a guess that the reason for the sound is the starter being different between FWD and RWD (since he's using an FWD starter with an RWD flywheel).
Old Apr 4, 2007 | 12:24 PM
  #198
Kevlo911's Avatar
Kevlo for President
I said some brands fixed the problem it's not a rwd/fwd thing
Old Apr 4, 2007 | 05:09 PM
  #199
MAXSE5SPD's Avatar
i just got an autozone starter. i dont mind the starter noise. if my starter craps out then i mite try anothr brand to see if i can fix it.
Old Apr 4, 2007 | 05:12 PM
  #200
Kevlo911's Avatar
Kevlo for President
It's not the starter...
