Sponsored by:
Sponsored by: CARiD
MEVI, EU, advanced timing = ........
Old Mar 21, 2007 | 12:03 PM
NCSU_MAX's Avatar
Maximoneypit
bigger injectors or FPR? My thoughts were injectors since the stock ones have 100000 on them anyways. If so what size? Also do I need an upgraded fuel pump? I also plan on getting a wideband. thanks guys,
Grant
Old Mar 21, 2007 | 12:06 PM
Kevlo911's Avatar
Kevlo for President
Negative. You need about 250-260WHP before you even max out the stock fuel pump let alone the injectors.
I am close to 200whp and I have to take away fuel(stock af map) from my 290cc injectors so I doubt the 260-270cc stock injectors are close to being max'd out.
Old Mar 21, 2007 | 01:08 PM
NmexMAX's Avatar
dot dot dot ...
Your thread isn't clear. You have EU listed in the title, and advanced timing.
From what it seems, you want to try and put lager injectors or an AFPR in order to indirectly affect timing such as the way some do it on here. That's the way I read it.
BUT:
If you have an EU, why would you 'indirectly' affect timing when you can directly do it?
Old Mar 21, 2007 | 01:20 PM
RA030726's Avatar
I'm nutty for Nissans
Go with an AFPR and keep the stock pump. Tune and adjust the fuel pressure if needed.
Old Mar 21, 2007 | 02:41 PM
ObsidianIce69's Avatar
Looking at the mods listed in your sig you don't really need any of them at this point. If you're going to do one just go with the injectors. send em out to Deatschwerks and get em serviced. you're looking at about no more than $30 per injector for their top level service and there are different levels
Old Mar 22, 2007 | 03:29 PM
NCSU_MAX's Avatar
Maximoneypit
BUT:
Yea sorry, probably attributed to my ignorance when it comes to tuning
So heres the deal: I have an EU and MEVI and would like to extend the rev limiter and advance the timing.
1. Is there anything else I need to make this work well. Ive been told a wideband would be best to send an AF ratio signal to the EU - something I should invest in?
2. Can I tune myself (acquire runfiles etc. for the EU) or should I take the car somewhere to be tuned?
Thanks guys,
Grant
Old Mar 22, 2007 | 03:42 PM
Kevlo911's Avatar
Kevlo for President
Buy a cheap wideband that has an output so you can put the output to the EU. Then you just drive and data log with the EU and tune yourself. Or if you can get the autotune working for you, you can use that and just lightly tune timing until you get on the dyno.
Old Mar 22, 2007 | 04:48 PM
NmexMAX's Avatar
dot dot dot ...
Just to clear something up... You can do the timing thing with the EU alone, no AFPR needed.
Kevlo nailed it.
Runfiles are only directly from a Dynojet, which you do not have. As for the tuning, kevlo said it best again, damn know it all.
Old Mar 23, 2007 | 12:35 AM
SPiG's Avatar
SomePsychoGuy
I think you mean Logging. Yes, EMU can do that, timing, A/F, lots of other stuff.
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Starrider
Sep 17, 2015 07:26 AM
305head
Aug 26, 2015 09:03 PM
