Sponsored by:
Sponsored by: CARiD
Fan Control Mod
Old Apr 28, 2007 | 01:04 PM
Tatanko's Avatar
Bacon Lover
Fan Control Mod
Now I've done some searching and I've even looked at Jime's website, and I can't come to a conclusion on exactly how to go about doing this. I'm wiring up a switch for use in the cabin, primarily for drag racing obviously. I am confused, however. Jime outlines how to do it two COMPLETELY different ways on here and on his website, using two different methods, two different switches, etc.
I'd like to go with the way he does it on his website, but he is a little vague. I see which pins control the fans, and understand how I'm to use the switch, but, are there wires coming out of the ECU at these two pins? If there are, and I am to use them, how does an SPDT switch allow for an "auto" mode? What I mean is, the SPDT switch seems to only allow for manual control (either low or high speed) and doesn't seem like it allows the ECU any control over the fans once you're done manually controlling them.
Here is the page for reference if anyone is unfamiliar with it:
http://jime.homeip.net/fan.html
How does this thing get wired up?
Old Apr 28, 2007 | 02:30 PM
eng92's Avatar
I think the part you are missing is that you are not cutting the wires to the ecu, you are just tapping into them.
You just provide a manual ground with the switch and when the contact(s) are open, the fans operate normally.
Old Apr 28, 2007 | 02:52 PM
Tatanko's Avatar
Bacon Lover
I see, I see. Makes sense now. T-ing in rather than interrupting. Thank you, sir!
Smackasmith
Feb 1, 2016 12:40 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
asianstyle
Sep 10, 2015 11:30 AM
