Sponsored by:
Sponsored by: CARiD
Timing Advance - Definitive Proof
Old Oct 4, 2011 | 02:06 PM
  #41
Unklejoe's Avatar
Originally Posted by NmexMAX
You're right.
My idle changes when I change my timing.
Yup. That's why you're supposed to do the idle relearn after you get your timing advanced.
Old Oct 4, 2011 | 02:36 PM
  #42
NmexMAX's Avatar
dot dot dot ...
My MAF/idle situation is pretty well custom to all that is custom due to all the little things I've done.
My issue was, on a normal day, I was able to change the base timing and leave it as is. On this one day, it wouldn't take once I got out of that screen, the idle cahnged and the timing was back to w/e it was prior.
reason being, my idle that day (too little fuel addition) caused my idle to fall below the threshold I was supposed to be at, and canceled the timing to stick, as the idle was out of tolerance, as we all know, the idle must be within spec as well as the ECT. IAVL/idle/BTDC wont take unless those parameters are met.
After a few points of fuel correction, it was fine, and stuck, without needing to do the idle relearn.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
