Sponsored by:
Sponsored by: CARiD
3rd gen VQ35DE Full ECU Swap Progress Thread
Old May 7, 2009 | 06:48 PM
  #601
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by Gunther
Looks right at home in there. Glad the axle thing didn't hold you back for too long, I was worried it was gonna be a major set back.
Same here! I thought this axle situation was going to set me back by more than a week. But, I was happy when I measured the VQ axle overall length.
Just a few minutes ago, I installed the axle. The ABS ring didn't want to fit in the hub though. But I grinded about 15 thou out of the hub and it now fits and the wheel spins freely.
Old May 7, 2009 | 06:53 PM
  #602
SurraTT's Avatar
HR Swap Pioneer
so the motor is in
soon to be running?
Old May 7, 2009 | 10:46 PM
  #603
STILLENGLE's Avatar
great build man, keep it up.
Old May 8, 2009 | 05:18 AM
  #604
GRNMAXDMON's Avatar
Another teaser pic! I have plenty of pictures that I will post later of the assembly of the engine as well as the actual install process.
pimp, now take it back out and ship me the whole assembly.
PS: don't forget the brackets.
Old May 8, 2009 | 06:34 AM
  #605
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by SurraTT
so the motor is in
soon to be running?
Yes, motor is in as shown in the pic.
My goal is to try to fire it up by Monday if possible. We'll see how things go. I'm sure there will be more obstacles.
Thanks.
The brackets aren't a plug and play type of thing. One of them had to be modified. I will post pictures soon.
Old May 8, 2009 | 07:25 AM
  #606
Aaron92SE's Avatar
NWP Engineering.com
I've been VERY busy with this project the past couple months. I've been so busy that I haven't had time to post pictures as I did the work. Let me catch up. 56K warning!
Heads installed:
Rear Timing Cover installed:
Timing Chain put on:
Tensioners put on:
Old May 8, 2009 | 07:26 AM
  #607
Aaron92SE's Avatar
NWP Engineering.com
Front Timing Cover installed:
Oil pan is next:
Intake Manifolds next:
Here was my oil pressure switch and OP gauge sending unit. But during the install, I found out that it's in the way of the passenger side axle. So, just yesterday, I removed the dummy light switch and screwed the sending unit in by itself.
Old May 8, 2009 | 07:27 AM
  #608
Aaron92SE's Avatar
NWP Engineering.com
Timing Cover and Pan all installed:
Engine is all ready for the swap!
I know I have the throttle body upside down. I found that out later when I was plugging in my EC harness. I fixed it.
Here are the brackets I had made by one of my local machinists. My 'Plan A' was to use the short one for the rear and the angle iron one for the front. The angle iron was suppose to sit above the lip on the front of the car and provide extra metal to weld onto for reinforcement. But that didn't work. More details are given later during the install process.
Another shot. Beautiful work, huh?
Old May 8, 2009 | 07:28 AM
  #609
Aaron92SE's Avatar
NWP Engineering.com
Here's the car on the lift. The entire engine swap took a day and a half to complete. I was hoping to have the entire job done in less than 8 hours though. But we ran into little issues with axle fitment, crossmember bracket fitment, and the front engine mount.
The old VE engine and transmission dropped from underneath:
No engine in bay:
Another shot of old engine:
Separated the transmission from the engine so I could use it on the VQ35DE.
  #610
Aaron92SE's Avatar
NWP Engineering.com
Bye bye VE! It's been fun, but time to upgrade!
Had to swap torque converter housings to allow the RE4F04V to bolt up to the VQ block. I used a 4th gen torque converter housing from an RE4F04A trans. Worked exactly as planned!
Here's some shots of the crossmember brackets going in. As you can see, I couldn't use the angle iron 'Plan A' bracket. I left the tranny in the stock location using the stock mounts. So where ever the engine ended up, it is what it is. The crossmember was about 1/2" towards the rear of the car, more than I expected. So there was no way to use the angle iron bracket for the front. The "Plan B" bracket for the front was used. I was going to install this up underneath the front beam of the car. The angle iron bracket was going to go above the lip to help raise the crossmember up. I didn't want the crossmember hanging down any further than what it was to begin with. It was way too low, especially with 22" slicks mounted. So instead of putting the Plan B bracket underneath the front beam, we put it on top of the lip and it fit up tight in that corner as shown. But ALL the weight is resting on that lip, which is very weak. You can bend it with pliers pretty easily.
Welded:
So a diagonal reinforcing plate was installed giving it the same strength as what the angle iron bracket would have given. The radiator does touch, but it won't be a problem.
Old May 8, 2009 | 07:30 AM
  #611
Aaron92SE's Avatar
NWP Engineering.com
The rear bracket was installed as planned:
As previously mentioned, the front engine mount was a problem. What mmg23max did on his VQ35 swap was cut the motor mount housing out of the engine bay of a 4th gen. Then he welded that to the 3rd gen after he bent all his ABS line out of the way. I don't have easy access to a 4th gen, so I decided just to make a solid mount using the two M6 holes already in the 3rd gen body. I didn't have to move the ABS lines. It's a pretty weak mount especially considering the base is held in by only two M6 bolts. But we'll see how it holds. The two main mounts are poly filled and should be pretty sturdy.
Another shot of car on lift:
In this pic, you'll see a VE axle axle with the VQ35 block. The support bracket location on the VE axle is 3" closer to the tranny than the one for the VQ. I first thought to fab up a custom support bracket and still use my stock VE axle. But I quickly found out that the headers wouldn't work without major reconstruction! So to get my car out of the shop, I just postponed that problem for another day. I later found out that the 4th gen axle works in the 3rd gen. The ABS ring is a tad different and won't line up perfectly with the ABS sensor, but it may still pick up a signal. Also, as mentioned in my post last night, the ABS ring is a tad too large for the 3rd gen hub. So I grinded a little bit on the hub and now it fits.
Well that's all my swap pics!
Old May 8, 2009 | 08:31 AM
  #612
gtr_rider's Avatar
192.168.1.1
nice set of pics
Old May 8, 2009 | 08:39 AM
  #613
Kevlo911's Avatar
Kevlo for President
Impressive, glad you took the time to have detailed pics
Old May 8, 2009 | 10:29 AM
  #614
t6378tp's Avatar
Turbo 3.5
nice
Old May 8, 2009 | 11:14 AM
  #615
VQpwrdSpeC's Avatar
Very nice progess!! Cant wait to see what it runs
Old May 8, 2009 | 11:15 AM
  #616
grey99max's Avatar
LandShark has Cosworth
You made it fit!
Hella job - now if it starts...
Old May 8, 2009 | 11:25 AM
  #617
GRNMAXDMON's Avatar
well, how much for the brackets that you ended up using?
Old May 8, 2009 | 01:18 PM
  #618
Aaron92SE's Avatar
NWP Engineering.com
Probably around $150-200 for those two brackets. They aren't cheap. And as you can see, they are flawless. But, you'll have to fab up that diagonal plate yourself though since the angle iron bracket didn't work out.
Old May 8, 2009 | 02:04 PM
  #619
maxine'sMan's Avatar
Nice work man.. Keep 'er comin'!!
Old May 8, 2009 | 05:39 PM
  #620
505max94se's Avatar
VERY nice Aaron!!
Old May 8, 2009 | 06:37 PM
  #621
CapedCadaver's Avatar
Call me Wookiee Goldberg
sweet. so you just used your original tranny mounts to align everything right? and then added the other mounts based on that positioning?
Old May 8, 2009 | 07:08 PM
  #622
gtr_rider's Avatar
192.168.1.1
will the VE trans hold up?
Old May 8, 2009 | 07:11 PM
  #623
Gunther's Avatar
He has had it rebuilt, and built up, I don't remember what specifically. But his mindset if [when] this one breaks, he'll know the weak point and be able to build that up more, until the tranny is VQ proof.
Old May 9, 2009 | 07:34 AM
  #624
GRNMAXDMON's Avatar
sweet, i will let you know when/if you can send a set.
Old May 9, 2009 | 01:29 PM
  #625
Aaron92SE's Avatar
NWP Engineering.com
Yeap. You got it.
It should. It's the same as the 4th gen trannies and they hold up ok. But, my tranny is original at 203K. So who knows how long it'll last.
I've never had my transmission rebuilt. It is 100% original. When this one dies, I will probably just swap in a used one and see how long that one lasts. But I don't see the reason to build up this transmission when Jime is doing just fine on a stock unit. If I start having problems holding the power though, I'll probably build it up.
No problem.
Old May 9, 2009 | 01:31 PM
  #626
Aaron92SE's Avatar
NWP Engineering.com
I just finished wiring everything up and I plugged in my battery for the first time. Everything turns on and the fuel pump is building pressure like it should.
But, what is the security light suppose to do when you first turn the ignition switch to ON? Mine doesn't do anything. It just stays off.
But when the key is OFF or ACC, the light blinks. Is this all normal?
Old May 9, 2009 | 01:39 PM
  #627
pmohr's Avatar
No more Maximas...
Yes, you're all good.
If the security light stays on while the key is ON or while cranking, then the ECU/NATS isn't recognizing the key.
You know damn well org hell will be brought upon you if you don't record the first startup and put it online
Old May 9, 2009 | 01:46 PM
  #628
Aaron92SE's Avatar
NWP Engineering.com
Ok thanks. So the security light isn't suppose to come on for a few seconds and then go out when the ignition is ON? My just stays out the entire time.
So, is that the normal thing to do? Take a video of initial startup? The first startup can be very nerve racking. I was nervous giving juice to my ECU for the first time.
I may just put fluids in the engine, tranny, and radiator and fire this thing up tonight. I still have to install the LH header and o2 sensor.
But all the codes I'm getting are expected things like EVAP and VIAS. So that is good.
Old May 9, 2009 | 01:48 PM
  #629
pmohr's Avatar
No more Maximas...
It shouldn't stay on for any amount of time in the ON position, AFAIK. As long as it's not lit, you should be good.
After this long of a project, I think an initial startup vid would be a good thing to make. And of course, we all want to see it.
Old May 9, 2009 | 02:17 PM
  #630
Aaron92SE's Avatar
NWP Engineering.com
Yeah, thanks. I was just making sure.
My initial startup will consist of a camshaft break in procedure. So as soon as I crank it, if I feel everything is ok, I will let it run at 2K rpm for a while. So I have to get all the fluids in the car and make sure the cooling fans kick on like they should. All this will be open headers as well since I have to have my Ypipe custom made.
Old May 9, 2009 | 02:34 PM
  #631
Gunther's Avatar
My mistake about your tranny, I could have sworn it was you who said that. Good luck firing it up!
  #632
oooooh...... in for videos of the loudness
i like the way you set about doing all the wiring ahead of time, that way when you got the engine in it was *almost* just like putting in the engine that belonged in the car.
Old May 9, 2009 | 02:38 PM
  #633
grey99max's Avatar
Ohdamn, Ohdamn, Ohdamn, he's gonna do it !!
Old May 9, 2009 | 06:05 PM
  #634
Aaron92SE's Avatar
NWP Engineering.com
Oh it's cool. I believe I did mention that I wanted to beef up my tranny in an old thread. I just didn't go through with it.
I like the way you emphasized "almost". haha But you're right, I did all the wiring ahead of time. That's just how it all worked out in the end. While I was waiting on engine parts, I didn't twiddle my thumbs for one second. I concentrated on wiring. Then, once the dash harness was pruned, I decided to go ahead and solder it in my car while all my schematics and notes were fresh in my head.
Today, I finished up the DPST ECCS relay. I just pulled the pins out of the stock SPST ECCS relay and plugged them in the DPST and ran a separate 15A fuse to the battery as the 02 Maxima FSM shows. Then I found an empty slot on the passenger side engine bay relay box for my Throttle Motor Control Relay to go. I did the same thing and pulled some pins out of spare relay sockets that I had and soldered everything in. I had to pulled several feet of wire to the other side of the engine bay where the battery is to give it power (15A fused). I undid the wiring harness underneath the front engine bay rail and tucked my wiring carefully away so you can't see it. The engine really does look like it came that way from the factory! Well, except for my ugly solid front engine mount.
Originally Posted by grey99max
Ohdamn, Ohdamn, Ohdamn, he's gonna do it !! .
Haha! I am not getting my hopes up though. Cause I know I will run into more obstacles. That's what I'm telling myself. Take it one day at a time.
I finished all the wiring today and gave power to the ECU. Fuel pressure seems to be fine. The only codes I'm getting are ones I expected, which is GREAT NEWS. I am only getting 85% throttle though and I can't figure out why. The APP sensor is in spec according to the voltage specifications in the FSM at the two ECU terminals. I pulled the ASCD brake switch and that didn't help. If anybody has any ideas, please let me know.
I bolted up the new steering wheel and plugged everything in and everything works on the cluster! Turn signals, horn, etc. The high beam light doesn't work, so I'll fix that some other time. And the gear selection works somewhat decently. If you have the OD off, it will show 3rd gear no matter which gear you're actually in. But, if the OD is on, it will show the right gear.
Tomorrow, I plan to attempt to fire this engine up. Coolant, Oil, and tranny fluid and I should be set. Oh yeah, I have to finish wiring in my manual high speed cooling fans switch first to make sure my fans work like they should before cranking this engine.
Exciting times! I really appreciate everyone's interest!
Old May 9, 2009 | 06:10 PM
  #635
pmohr's Avatar
No more Maximas...
Do all of the learning procedures here:
http://www.technosquareinc.com/350reset.htm
Same thing as the Z33.
As for the IAVL, you shouldn't need to start it up at all. They're all worth a shot, anyway.
Old May 9, 2009 | 06:24 PM
  #636
Aaron92SE's Avatar
NWP Engineering.com
Thanks. Those directions are found in the FSM and in the installation instructions I wrote for the NWP 02-08 Maxima Thermal Intake Spacer Kit. I did do the first two, but didn't bother with the IAVL procedure. I could give that a shot tomorrow. Wouldn't hurt.
I know Jime was having problems with not reaching 100% WOT and it was due to the brake switch. When the brakes are engaged, it limits throttle position. This effects you being able to stall it up at the line if needed. For the VE, I've found that I get better 60 foots by not stalling it up and just shocking the converter from near idle. But that could change drastically with this new engine.
Oh, and I didn't reset the ECU using that procedure. All I've done is clear the codes a few times.
Old May 9, 2009 | 06:41 PM
  #637
Aaron92SE's Avatar
NWP Engineering.com
Does the ignition key LED suppose to always stay on? Even when the key is removed?
I also found out that my cluster doesn't illuminate when the head lights are on. I gotta fix that quick!
Old May 9, 2009 | 06:55 PM
  #638
Jime's Avatar
What is telling you that you only have 85%? If its an OBDII reader etc, don't believe it, check the throttle opening visually. A lot of people have been fooled into thinking they weren't getting a fully open throttle when they were.
The key led should blink occasionally when key is removed and go out when key is on, thats how you know the NATS is working. If it comes on steady you have a problem.
Old May 9, 2009 | 07:22 PM
  #639
Aaron92SE's Avatar
NWP Engineering.com
Thanks Jim. Yes, it was my Auterra DynoScan software saying 85%. But, the one time I did glance at the throttle body, I looked 100% open (parallel to airflow). I will look closer tomorrow.
Atleast I know my NATS is working. Thanks!
Old May 10, 2009 | 01:40 PM
  #640
grey99max's Avatar
I'm wondering - what are your plans for break-in oil ??? Personally, I'm looking at the Royal Purple break-in stuff, but ???
