Sponsored by:
Sponsored by: CARiD
3rd gen VQ35DE Full ECU Swap Progress Thread
Old Nov 11, 2008 | 12:16 PM
  #161
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by Kevlo911
You can hook up power to the cluster and run the speedo so that the mileage increases/decreases
Cool. I may play around with this.
Old Nov 11, 2008 | 04:41 PM
  #162
GRNMAXDMON's Avatar
Aaron i need you to speed up the process my friend so that i can swap mine in as well.
Old Nov 11, 2008 | 07:12 PM
  #163
Aaron92SE's Avatar
NWP Engineering.com
Alright. I'll try to work harder.
Old Nov 12, 2008 | 05:34 AM
  #164
mmg23max's Avatar
Good job bro,I like how the project coming along
Old Nov 12, 2008 | 12:41 PM
  #165
CapedCadaver's Avatar
Call me Wookiee Goldberg
seriously? running the voltage backwards will wind the mileage down on a digital odometer? On a mechanical one like the 3rd gen, yea, but i didn't think that would work on a 5th gen speedo....
Old Nov 12, 2008 | 02:48 PM
  #166
GRNMAXDMON's Avatar
how the hell would you make it to go backwards once you wire it up???
Old Nov 12, 2008 | 06:15 PM
  #167
Aaron92SE's Avatar
NWP Engineering.com
Got my pulley in today.
Old Nov 12, 2008 | 06:24 PM
  #168
hadman's Avatar
I guess you going to grind the a/c rib off that one...?
Old Nov 12, 2008 | 06:48 PM
  #169
Aaron92SE's Avatar
NWP Engineering.com
No, the AC and alternator are on the same rib for the 3.5.
But I can run this engine down the 1/4 mile without any belts though if I wanted to.
Old Nov 12, 2008 | 07:00 PM
  #170
hadman's Avatar
Oh I didn't realize they share a rib. I guess you could say our pulley has a 'spare rib'
Old Nov 12, 2008 | 07:55 PM
  #171
doublea's Avatar
Talking
Nice pulley !
Old Nov 12, 2008 | 09:06 PM
  #172
Aaron92SE's Avatar
NWP Engineering.com
Heads are off!
Old Nov 12, 2008 | 09:45 PM
  #173
95BLKMAX's Avatar
bahahaha!!!! indeeeeeeeeeeeeeeeeeeeeeed!!!!
damn cylinder 1 looks like it could use some sand paper elbow grease lol
Old Nov 13, 2008 | 08:28 AM
  #174
Aaron92SE's Avatar
NWP Engineering.com
All the cylinder walls look to be in near perfect condition. There are no marks or scratches at all on any of them. Just a nice crosshatch.
Piston #1 is at TDC in that picture. So you are seeing the top of the nasty piston.
Old Nov 13, 2008 | 07:23 PM
  #175
GRNMAXDMON's Avatar
Aaron, how is the wiring so far???
Old Nov 13, 2008 | 07:30 PM
  #176
aznsap's Avatar
this is going to be awesome
Old Nov 13, 2008 | 09:37 PM
  #177
95BLKMAX's Avatar
oh damn! man i'd go down town on those piston tops with a wire brush head on the drill. but that's just me LOL
Old Nov 13, 2008 | 11:31 PM
  #178
nismology's Avatar
No point in doing that if the same thing is going to happen again. Re-ringing the motor is the only worthwhile course of action, if anything.
Old Nov 14, 2008 | 07:40 AM
  #179
Aaron92SE's Avatar
NWP Engineering.com
Wiring? I haven't come close to that part of the project yet. Step 1 is to get this engine together on the stand. Then I'll physically install it in the engine bay with the 4th gen crossmember. Then I'll worry about installing the wiring harness.
I already have a dash harness. And I already ordered the engine harness, but it got lost in transit! They claimed they have found it, but I can tell they don't know for sure. I know the package is insured, but it's just a hard part to find, I don't want my money back. I want the harness!
In the meantime, I can go through the harnesses, label and prune out what I don't need like eng92 did.
Yeah. And I don't want to scratch up the top of the pistons. Did you get my PM?
Old Nov 14, 2008 | 09:14 AM
  #180
grey99max's Avatar
LandShark has Cosworth
Wow - great minds and all that...
That's exactly what I did to mine. Cleaned out the head chambers, too, then lightly buffed the block with the wire brush before installing the 2005 350Z 3-layer head gaskets. I guess those things worked - the engine still runs rather well.
Old Nov 14, 2008 | 10:08 AM
  #181
Matt93SE's Avatar
STFU n00b!
Why bother cleaning it? The first time he sprays, it'll burn right off.
Old Nov 14, 2008 | 10:33 AM
  #182
95BLKMAX's Avatar
maybe it's just me, but there's something that FEELS wrong about putting it all back together, seeing how dirty those pistons were. Would it make a difference? slim if any. It's mostly a psycological factor here.
I cant work on an engine if its got dirt and grime all over (as you know I keep a huge stock of brake parts cleaner LOL). Same applies to putting the engine back together. I could not let my self put Aaron's motor without cleaning it off
Old Nov 14, 2008 | 07:55 PM
  #183
grey99max's Avatar
Or detonate, with all that crud glowing in the dark.....
Has it been sucking oil? Did the IM have lots of motor oil in the intake elbow and intake runners? Mine did - so I installed two inline oil-air separators between the PCV valve and the vacuum intake stub on the elbow. They sure collect a lot of oil after a few runs, too...
Old Nov 14, 2008 | 08:00 PM
  #184
Aaron92SE's Avatar
NWP Engineering.com
Old Nov 14, 2008 | 08:23 PM
  #185
grey99max's Avatar
OK - that motor has been sucking oil from somewhere - it seems like all cylinders have deposits on the pistons. That is not pretty - and looks a lot like my engine did when I peeled the heads off. (with 60K miles)...
Since I wasn't going to pull the pistons or re-ring the engine, I chose to tilt the engine over past vertical on one side, washed the pistontops with acetone, wire-buffed the pistons - and head gasket surfaces, then flipped the block over and did the same on the other bank. cleaned the wire brush with acetone at the same time. Then I buffed out the combustion chambers the same way. Clean off the cylinder walls with a cloth soaked in acetone. The whole thing came out clean and tidy. Put some motor oil in each cylinder when done.
Second choice is to replace at least the rings, or pistons and rings, and still wire-brush the heads - because I bet there is the same crud in the corners of the combustion chambers.
You will start to enjoy the acetone fumes as well...
Old Nov 14, 2008 | 08:42 PM
  #186
KRRZ350's Avatar
I hope your oil pump blows up, I really do.
Old Nov 15, 2008 | 04:59 AM
  #187
t6378tp's Avatar
Turbo 3.5
hey could you pm me a pic of this or if aaron does not mind pic it here
I've been meaning to install one but stop modding the car when the tranny broke
Old Nov 15, 2008 | 08:29 AM
  #188
accordingtou's Avatar
VQ30 DE T
Ah just run a vacuum hose to washerfluid reservoir during idle
(Back yard meth inj).
I would also like to see how you guys route the catch can
Old Nov 15, 2008 | 08:42 AM
  #189
DrunkieTheBear's Avatar
Turbo'd Saab
I would do the second choice. I'm sure you could pick up a set of better piston rings and just have the pistons dry blasted or clean them with actone, no need to disconnect the rod from the piston, then just rehone the cylinder walls, reinstall with a nice set of HR or ARP bolts. Spend about $200 for piece of mind
Old Nov 15, 2008 | 09:11 AM
  #190
nismology's Avatar
I agree with everything but the rehone. As long as the factory crosshatch is intact, leaving well enough alone is best. Otherwise the pattern will be uneven which is undesireable. The only time rehoning is suitable is when the cylinders have completely glazed over and have lost their oil-holding capabilities.
Old Nov 15, 2008 | 09:19 AM
  #191
Turbo'd Saab
I thought a good idea to rehone (I'm thinking of the flexible ball-type honing that you can attach to a drill and do yourself) is when you get a new set of piston rings, this gives the piston rings a new surface to set themselves into (or seed if you will) especially if crosshatch with the ball hone, I was planning on honing my 3.0 with the new pistons and rings going in.
Also nismology did you get my PM on the LIM info?
Old Nov 15, 2008 | 09:31 AM
  #192
Aaron92SE's Avatar
NWP Engineering.com
Yes. I won't hone this block. The cross hatch is perfectly in tact and the cylinder walls are flawless.
If I were to rering the pistons, I'd overbore it and start from scratch. But I do have to stop spending money somewhere.
And I think the pistons look like any 49K mile piston would look like. I will still clean them carefully, but it looks normal to me.
Old Nov 15, 2008 | 02:51 PM
  #193
grey99max's Avatar
Here's a photo of my two in-line oil/air filters:
These were purchased at Harbor Freight... connected between the PCV valve and a vacuum line into the SSIM.
Old Nov 16, 2008 | 10:39 AM
  #194
KRRZ350's Avatar
Oops, sorry, wrong link, here it is: Custom PS lines
Old Nov 16, 2008 | 12:21 PM
  #195
t6378tp's Avatar
Turbo 3.5
did you put anything between the front valve cover and the intake mid pipe
Old Nov 16, 2008 | 03:15 PM
  #196
Aaron92SE's Avatar
NWP Engineering.com
Thanks. I may need a custom hose fabricated.
Old Nov 16, 2008 | 05:52 PM
  #197
Aaron92SE's Avatar
NWP Engineering.com
Look better?
Old Nov 16, 2008 | 06:43 PM
  #198
Turbo'd Saab
OOOOOOOOOOOOOOOOOOOO perddy
Old Nov 16, 2008 | 07:21 PM
  #199
grey99max's Avatar
Nope - just a baby cone filter on the valve cover. It doesn't go any further than that.
Old Nov 16, 2008 | 07:24 PM
  #200
grey99max's Avatar
Look better?
Dang ! That looks good - don't you feel better now? (You do good work).
So did you use a wire brush and did you do the block and heads as well? The block-head surfaces look clean enough to eat from.
