Sponsored by:
Sponsored by: CARiD
Another 3.5 swap thread
Old Mar 2, 2010 | 06:15 AM
  #161
Crusher103's Avatar
Originally Posted by essential1
+ 1 to those grounds. I've experienced the same thing during a couple swaps. They are that imprtant.
If you have an AFC (or anything hardwired to the ECU if i'm not mistaken), It wont turn on when you try to crank the car up if these wires are not grounded properly. Just a a tip to help with trouble shooting.
lmao at the vid in ur sig, who would have guessed.....
Old Mar 5, 2010 | 09:01 AM
  #162
CapedCadaver's Avatar
Call me Wookiee Goldberg
ibvq35neverdrives
Old Mar 5, 2010 | 09:35 AM
  #163
Aaron92SE's Avatar
NWP Engineering.com
Have you found out the problem yet? Get that thing running and come out to the track tomorrow.
http://forums.maxima.org/washington-...march-6th.html
Old Mar 5, 2010 | 10:16 AM
  #164
bigleman's Avatar
Advocatus Diaboli
Spark Plugs
Old Mar 5, 2010 | 05:03 PM
  #165
Crusher103's Avatar
it runs, and i have a couple of witnesses to it running, and a vid should be coming up soon.
picking up an axle tomorrow, and seeing about the exhaust. probably try and take care of that on monday. then i will be terrorizing the streets.
Old Mar 5, 2010 | 05:16 PM
  #166
Aaron92SE's Avatar
NWP Engineering.com
Awesome! What was the problem with no spark?
Old Mar 5, 2010 | 05:22 PM
  #167
Crusher103's Avatar
yea spark was the problem, the CKPS was to far from teh flywheel, but now its been starting up and running.
Old Mar 5, 2010 | 05:37 PM
  #168
Aaron92SE's Avatar
NWP Engineering.com
Cool. Glad it was something simple! Just let me know when you want to take it to the track and we'll have a track meet, even if it's just me and you.
Old Mar 5, 2010 | 06:09 PM
  #169
ajcool2's Avatar
Glad you got it ruuning. Any leaks?
Old Mar 5, 2010 | 06:34 PM
  #170
Weimar Ben's Avatar
Helicopters! Money!!!
I think you owe me some mad props.
Old Mar 5, 2010 | 07:18 PM
  #171
pics of throttle cable mount?
Old Mar 5, 2010 | 07:25 PM
  #172
Crusher103's Avatar
those will be coming soon, i think u'll like my setup, not what u expected
Old Mar 6, 2010 | 07:23 AM
  #173
Crusher103's Avatar
going to take some pics, and i know this will **** a couple of people off, i just picked up some 350Z seats for $35, pics of them will be up in alittle
Old Mar 7, 2010 | 12:24 AM
  #174
u be all slow n shiit
Old Mar 8, 2010 | 08:00 PM
  #175
Crusher103's Avatar
been alittle preoccupied....can u blame me, i drove it today and good news is the clutch feels amazing, the car has no vibrations what so ever. the motor was breaking up as if it was not getting enough fuel as soon as the revs were over 4k.
Old Mar 9, 2010 | 08:08 AM
  #176
Aaron92SE's Avatar
NWP Engineering.com
I should be hitting the track again at Coastal Plains the Friday after next. Hopefully, you can make it out.
A fuel pressure gauge is a very good thing to have. I installed mine with a T-fitting and a small fuel injection rubber hose so I can put the gauge under my windshield wiper and read it while at WOT.
Old Mar 9, 2010 | 09:36 AM
  #177
Crusher103's Avatar
can anybody help me with the idle? here is whats happening i start the car and its quite difficult to start, but it will rev to like 3500 on start up, drop to 1600 idle there for 2-3 secs then drops to 700 normal idle but the motor is cold it will stay there for about 4 secs, and this is whats bugging me it will then drop to 300-400rpm, and it will idle there for about 10secs, but the strange part about that is the car does not respond to the pedal being depressed. its almost like its off but its not off.
It seems like it almost flooding the cylinders with fuel on start up so i have taken away as much fuel as i can, i need to get a friend over here so he can tell me what the fuel pressure is on start up, because it can idle on 30psi, it was doing it yesterday even thou the idle was like 2600rpm(vac leaks)
Old Mar 9, 2010 | 09:40 AM
  #178
bigleman's Avatar
Advocatus Diaboli
Spark plugs
Old Mar 9, 2010 | 09:43 AM
  #179
Crusher103's Avatar
yo, shut up.
Old Mar 9, 2010 | 08:53 PM
  #180
QNO_A32's Avatar
TPS in spec? and your breaking up issue might be that crank POS sensor....any codes? Congrats on having a 3.5 swap !
Old Mar 9, 2010 | 09:36 PM
  #181
DrunkieTheBear's Avatar
Turbo'd Saab
LAWLS @ biggles
Old Mar 9, 2010 | 11:56 PM
  #182
MDeezy's Avatar
dude... told you ages ago to adjust the TPS sensor. You put the path finder on and you have to adjust that sensor or you probably will have idle problems kind of like what your having now. Check the FSM and get it in spec. then re drive and see..
Old Mar 10, 2010 | 08:18 AM
  #183
Crusher103's Avatar
i just disconnected the TPS, to see if it would help at all and it didnt. the only difference is now, it will start normally and the revs go up to 2k then drops to 1600, and then drops to 700 then teh 300-200 range and just dies from there, the fuel pressure is still low, its at 30psi. 30psi was supporting a high idle and revs up 4500rpm the other day when the car had vac leaks, i even drove it up and down the street, now that i dont have vac leaks it wont respond to the accelerator being depressed
Old Mar 10, 2010 | 08:43 AM
  #184
MDeezy's Avatar
adjust the tps period.
Old Mar 10, 2010 | 08:50 AM
  #185
ajcool2's Avatar
^Yup. Also I think my fuel pressure is set to around 45psi.
Old Mar 10, 2010 | 09:05 AM
  #186
Crusher103's Avatar
i dont think it will do anything even i adjust it, the car is not responding to the go fast pedal. i need to buy a multi-meter because i dont have one.
Old Mar 10, 2010 | 09:14 AM
  #187
bigleman's Avatar
Advocatus Diaboli
Is your gas pedal moving your TB?
Old Mar 10, 2010 | 09:18 AM
  #188
Crusher103's Avatar
yea it is, i re-did my throttle cables the otherday to make sure they were nice and tight, and when i drove teh car the other day the throttle was very responsive.
Old Mar 10, 2010 | 09:23 AM
  #189
bigleman's Avatar
Advocatus Diaboli
Is it still connected? It may have come loose.
Old Mar 10, 2010 | 09:29 AM
  #190
Crusher103's Avatar
i have been taking it on and off alot, and u can feel the Springs on the TB through the pedal.
i discovered a problem just now there was a pocket of air in the coolant hose were the coolant temp sensor sits, yes i did bleed the system but i still got a pocket of hot air. so i just got rid of that i will try again after lunch.
Old Mar 10, 2010 | 10:12 AM
  #191
MDeezy's Avatar
no.... adjusting the TPS is making sure the ohms are within a specifc parameter with the throttle closed, then between a specific parameter with the throttle wide open.
Check the FSM and do it. Each time you take off the TPS you need to re do it.
The adjustment is done but loosening the bolts that hold it, then slowly turning the tps clockwise or counter close wise to get it within spec. Once you have it. Tighten it down and dont move it. Once you have it adjusted there should be no need to take if off again, unless it goes bad.
Old Mar 10, 2010 | 10:22 AM
  #192
bigleman's Avatar
Advocatus Diaboli
he wont do it
Old Mar 10, 2010 | 10:30 AM
  #193
MDeezy's Avatar
he wont...and his car will never run right....
hard to pick up girl with his car revving all crazy as he's trying to look cool creeping at 3mph with his rpms at 4k
Old Mar 10, 2010 | 10:45 AM
  #194
Crusher103's Avatar
yea i know that, just even with the TPS not inspec the car should respond to the throttle being depressed. thats why i was saying it was not that, but i will try that if its still acting the same thou.
Old Mar 10, 2010 | 11:00 AM
  #195
Crusher103's Avatar
ok with the TPS disconnected and the air temp sensor disconnected it responds to the throttle opening and closing, no idle but i got some response from it.
Old Mar 10, 2010 | 11:01 AM
  #196
MDeezy's Avatar
it can respond to the throttle being pressed but if its not calibrated to understand what is full throttle and wat is closed so it can calculate the in between why would it respond properly?
stop being lazy and fix that ish..
Old Mar 10, 2010 | 11:03 AM
  #197
MDeezy's Avatar
Old Mar 10, 2010 | 11:05 AM
  #198
Crusher103's Avatar
from what i understand i need to get teh car to warm up anyway to set the TPS, so i will need to get it to respond to the throttle to get it to warm up.
  #199
bigleman's Avatar
Advocatus Diaboli
i told you he wouldnt
Old Mar 10, 2010 | 11:06 AM
  #200
Crusher103's Avatar
and like i said it was responding to the throttle on Fri, Sat, Sun, and Mon, without the TPS set. but all of a sudden it stopped yesterday.
