Sponsored by:
Sponsored by: CARiD
1st Fully Built 5.5Gen - NA
Old Aug 25, 2010 | 09:16 PM
  #321
Rods03Max619's Avatar
So did he tune and clear all the codes and dynoed yet!!
Old Aug 26, 2010 | 06:13 AM
  #322
Deckdout2's Avatar
Play with my balls
No he didn't, at least not yet....
Car was dropped off to Matt yesterday. The mad scientist is gonna tear apart the timing chain cover, and realign the timing chain correctly for the teeth I skipped. At least he's going to verify that this is the issue first. Then he's gonna have to pull apart the intake manifold and replace the coils and plugs I fried. Ask any racer, any real racer.....whether it's 1 code or 5 codes, a code is a code and needs to be fixed before tuning can commence.
Old Aug 26, 2010 | 07:51 AM
  #323
datdude20's Avatar
rofl:
Old Aug 26, 2010 | 08:01 AM
  #324
vastmax's Avatar
So you and the mad scientist are gonna have to rip off the manifold and replace the piston rings you fried?
Old Aug 26, 2010 | 09:36 AM
  #325
NmexMAX's Avatar
dot dot dot ...
Fried coils? whaaa ...
Old Aug 27, 2010 | 12:26 PM
  #326
jkpgt96's Avatar
Fried Coils....lame excuse...lol
Old Aug 27, 2010 | 01:03 PM
  #327
ajcool2's Avatar
Fried Chicken???
Old Aug 27, 2010 | 01:59 PM
  #328
Deckdout2's Avatar
Play with my balls
Price's Chicken Coop. Top 5 in the Nation......Source: Google & Travel Channel
Old Aug 27, 2010 | 02:33 PM
  #329
DrunkieTheBear's Avatar
Turbo'd Saab
So you blew the welds on the intake manifold?
Old Aug 27, 2010 | 07:25 PM
  #330
SurraTT's Avatar
HR Swap Pioneer
and the rivets on the floor pan. Diamond plate FTL
Old Aug 28, 2010 | 11:47 AM
  #331
Deckdout2's Avatar
Play with my balls
Nox is a helluva drug.
Old Aug 29, 2010 | 10:27 PM
  #332
Scottwax's Avatar
That's Mr. Detail to you
Used to be so easy to tune cars, just play with the timing curve and carburetor jetting, adjust one thing at a time until you get your highest trap speed.
All I had to do when I built a really stout .030 over 350 for my Chevelle was to bump the primary jetting up 2 jets and drill 1/8" holes in the primary throttle plates to get more air flow at idle (244 duration at .050 lift, .501 lift and 106 degree centerline). I think I changed the rear accelerator pump squirter too (Holley double pumper).
Now with all the sensors and computers, it is a real pain when you get into a serious n/a build like this one. Hopefully once you get the timing issue taken care of you will start seeing the true potential of your build. If the timing chain didn't jump, look real close at the IVT solenoids. Doesn't take much dirt in them to cause problems.
Old Aug 30, 2010 | 06:59 PM
  #333
Deckdout2's Avatar
Play with my balls
Confirmed that the timing chain skipped teeth. We suspect that on initial startup, the timing chain tensioner didn't have any oil pressure behind it, and cause the chain to be loose. We have a feeling this is the root cause of my tuning problems. I surely hope so, that's all I can say.
Old Aug 30, 2010 | 09:40 PM
  #334
00maximact's Avatar
that thing is sexy as ****
Old Aug 31, 2010 | 05:19 AM
  #335
tuko316's Avatar
atleast its a step foward. How can oil pressure built up before startup? Turning the crank by hand or is it just something that happens by chance?
Old Aug 31, 2010 | 06:44 AM
  #336
Deckdout2's Avatar
Play with my balls
We turned the crank by hand after assembly, but to my understanding, it is something that you just hope gets enough pressure to put tension on the chain as it starts. Matt says that it should be ok this time around.
Old Aug 31, 2010 | 06:58 AM
  #337
gt20ir's Avatar
remove the spark plugs, un plug the fuel injectors, crank the motor over until you have oil pressure....
Old Aug 31, 2010 | 07:17 AM
  #338
Deckdout2's Avatar
Play with my balls
Then there's that. Thanks for the headsup!
Old Aug 31, 2010 | 08:00 AM
  #339
datdude20's Avatar
See...I told ya . Can't wait til u get this thing right
Old Aug 31, 2010 | 08:37 AM
  #340
datdude20's Avatar
I was told to do the same thing
Old Aug 31, 2010 | 08:48 AM
  #341
t6378tp's Avatar
Turbo 3.5
Why not just soak the tenioner and prime it in oil
Old Aug 31, 2010 | 09:14 AM
  #342
t6378tp's Avatar
Turbo 3.5
Once you pull the pin the chain will be tight
Old Aug 31, 2010 | 12:13 PM
  #343
ajcool2's Avatar
Hopefully that was the issue.
Old Aug 31, 2010 | 01:11 PM
  #344
vastmax's Avatar
great you found this P...any timeframe when itll be all back together? I know Matt's a pretty busy guy...
Old Aug 31, 2010 | 01:21 PM
  #345
Deckdout2's Avatar
Play with my balls
I was quote a couple of weeks, but it just all depends on timing and family life, which I completely understand. I'd like to go over there and help him out this week, but we shall see.
Old Aug 31, 2010 | 02:46 PM
  #346
jkpgt96's Avatar
Good to hear! Can't wait to see the results!
Old Sep 7, 2010 | 12:44 PM
  #347
MIKERNM1990's Avatar
any update?
Old Sep 8, 2010 | 05:29 PM
  #348
Deckdout2's Avatar
Play with my balls
My crappy run from July.
Old Sep 8, 2010 | 08:29 PM
  #349
SR20DEN's Avatar
VQ Wizard
Typical Civic driver in the other lane.
Look in your driver side mirror at 0:52
Old Sep 8, 2010 | 09:10 PM
  #350
perkman87's Avatar
they let you roll with shorts, they wont let us here in fl
Old Sep 9, 2010 | 07:07 AM
  #351
Deckdout2's Avatar
Play with my balls
LOL, how I didn't notice that before I don't even know. I think I was looking at the rearview mirror. LOL
Really? None of the tracks we've been to up here have had any code unless you run faster then xx.xx times. (track specific) I'm sure at that point you'll not only need a helmet but proper clothing as well.
Old Sep 15, 2010 | 11:28 AM
  #352
quarter mile?
Old Sep 17, 2010 | 09:06 PM
  #353
krazy6's Avatar
Originally Posted by MIKERNM1990
quarter mile?
Are you serious?
Old Sep 17, 2010 | 09:27 PM
  #354
JonBlz's Avatar
a.k.a. STuNtMAN
cant wait til its all finished
Old Sep 17, 2010 | 09:29 PM
  #355
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Originally Posted by krazy6
Are you serious?
lol.... something tells me he is.
Old Sep 18, 2010 | 01:20 AM
  #356
De O's Avatar
So you went back a teeth or two? I need to check this as well my car is throwing the same code since i put in my cams.
Old Sep 28, 2010 | 06:44 AM
  #357
Shift_Max's Avatar
SO is it true that you are going with Uprev now?
Old Sep 28, 2010 | 07:14 AM
  #358
SurraTT's Avatar
HR Swap Pioneer
how is the compression?? being a tooth or 2 off hopefully did not touch the valves
Old Sep 28, 2010 | 09:12 AM
  #359
Deckdout2's Avatar
Play with my balls
I had very high hopes to go this route, but the development at the moment is just not there. It's more complicated then one would think, and the thought of running 2 ecu's is not that appealing to me. So until there is a much simpler fix as in someone making this work, then I will retain the Utec for now. Once I get this thing back on the road, I'm hoping that it will be somewhat of a beast anyway.
Have not checked the compression. Will check it when it all gets put back together. We don't suspect that anything was damaged by being off 1 tooth.
Just a slight update. The chain has been aligned properly, and the proper procedures to get the tension pressurized has been completed. The timing chain covers will be cleaned and installed back on tomorrow. Should be cranking it back up soon here.
Old Sep 28, 2010 | 12:57 PM
  #360
accordingtou's Avatar
VQ30 DE T
05 ecu & harness will allow you to use uprev.
