Sponsored by:
Sponsored by: CARiD
1st Fully Built 5.5Gen - NA
Old Jun 30, 2010 | 10:36 AM
  #241
NmexMAX's Avatar
dot dot dot ...
Originally Posted by SR20DEN
This car really loves fuels with extra octane.
I see what you did there ..
Yes, rich has treated me the same as he did to you (Paramy), nothing's changed there.
As for said eBay link, 05 L31 = WBo2's/A34 ECU.
Here's the old info I found, I know
http://forums.maxima.org/6th-generat...ghlight=OSIRIS
http://forums.maxima.org/all-motor/5...ris-uprev.html
Old Jun 30, 2010 | 10:49 AM
  #242
Kevlo911's Avatar
Kevlo for President
Originally Posted by Deckdout2
Interesting, how long ago was this?
2 years ago
Old Jun 30, 2010 | 11:03 AM
  #243
Deckdout2's Avatar
Play with my balls
Paramy *Likes* this.
Old Jun 30, 2010 | 11:11 AM
  #244
NmexMAX's Avatar
dot dot dot ...
t3h jungle juice
Old Jul 4, 2010 | 09:11 PM
  #245
j23a45m9's Avatar
I am great full to read up on your build. take your time, good luck with it and the new house!
Old Jul 5, 2010 | 06:10 AM
  #246
Grand_hustle17's Avatar
Updates???... dyno numbers and progress
Old Jul 6, 2010 | 09:49 PM
  #247
Deckdout2's Avatar
Play with my balls
Cross your fingers for Sunday.
Old Jul 9, 2010 | 03:55 PM
  #248
Child_uv_KoRn's Avatar
Bad *** Newb
In another thread I was suggesting wiring the A34 ECU as a piggyback similar to the UTEC thereby leaving the stock ECU alone to function normally. Just tap and splice all required wires (about 30). I'm only concerned about the cut wires dangling off the stock ECU, but I think some resistors on them will keep reflection from frying anything.
I am really willing to do this now. I'm so goddamn tired of this POS stock ECU. My car is SLOW and I have full bolt-ons minus cams!
Old Jul 9, 2010 | 05:04 PM
  #249
NmexMAX's Avatar
dot dot dot ...
I hate to add more to this, but what makes you think the A34 ECU is any better, in your context of using it and only it as a piggyback (no other tuning items)? It be advantageous to 'covert' to the A34 ECU just because there are more tuning choices. (i.e. UTE, eetc straight 'bolt on', no wiring nec.)
Myself and another 6th gen member have compared timing and cam timing logs, and they're identical (timing/cam timing). A cheap or expensive piggy back can be used to control fuel of course, and then they'd be identical.
Old Jul 9, 2010 | 05:09 PM
  #250
Bad *** Newb
That's what I'm talking about. I'd use osiris with it.
Although, I forgot the part about removing security. That's not a cheap flash.
Old Jul 9, 2010 | 05:11 PM
  #251
NmexMAX's Avatar
dot dot dot ...
Ahh ... I see what you're saying now.
Old Jul 11, 2010 | 10:50 AM
  #252
03BlkSETE's Avatar
Old Jul 11, 2010 | 03:01 PM
  #253
accordingtou's Avatar
VQ30 DE T
Old Jul 11, 2010 | 04:54 PM
  #254
Deckdout2's Avatar
Play with my balls
You know what sucks about today? This crappy excruciating heat and humidity!
I was excited to tweak this puppy, but we're gonna have to final tune it on a much cooler day. (whenever that happens)
She is tuned much better than ever before though off the road, so it's the fastest it's ever ran. I'm hoping to go to the track Wed evening, so I'll see what happens there. Nothing else to report at this time.
Old Jul 12, 2010 | 03:36 AM
  #255
tuko316's Avatar
What numbers did you put down in this bad weather?
Old Jul 12, 2010 | 03:41 AM
  #256
tuko316's Avatar
What is redline set to?
Still must be impressive numbers. How traction running through the gears?
Old Jul 12, 2010 | 04:08 AM
  #257
JonBlz's Avatar
a.k.a. STuNtMAN
damn what a beautiful build i like it alot
Old Jul 13, 2010 | 03:59 PM
  #258
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Got dyno graphs? Are you still planning to compare intake manifolds?
Old Jul 14, 2010 | 08:44 AM
  #259
Deckdout2's Avatar
Play with my balls
I believe redline has been bumped to 7500 rpms. I break the tires in the 1st 3 gears.
No numbers at the moment.
Old Jul 14, 2010 | 08:46 AM
  #260
Deckdout2's Avatar
Play with my balls
I don't have any dyno graphs. Have a couple things to look into before a final dyno tune. I took the manifolds with me, but there was no point in dynoing those at the time, since I still haven't dialed in what I've got on there now. I am still planning on doing a comparison of these, however.
Old Jul 14, 2010 | 09:46 AM
  #261
t6378tp's Avatar
Turbo 3.5
Butyou had to dyno something or you just don't care to share the results
Old Jul 14, 2010 | 10:59 AM
  #262
Cool. I honestly don't care about the numbers, as every dyno is going to read different. I just want to see how the curve looks with your mods, and see how it does at the track with a 0-500ish DA!
Old Jul 14, 2010 | 01:18 PM
  #263
Deckdout2's Avatar
Play with my balls
The tuning was not numbers based. There's areas in the air/fuel that wouldn't accept the fuel corrections or return curves that were all over the place, and there are issues with it knocking still in some areas in the rpm range when modifying the timing maps. I'm pulling 3 codes at the moment, and are thinking that this maybe what's causing the issues. One main one is the Cam Timing Advanced code, which because we can't change that, we're trying to figure out what the issue might be. We also couldn't tune on 93 Octane for the life of us to get a clean map. I'm currently running on E85 tune at the moment, which is actually running much better. I don't want to solely stick with that map however, and I need to draw a map for Premium but I can't until I get these codes figured out. Also, not sure if the E85 is flowing enough fuel using the Maxima fuel system is why it's not accepting the fuel corrections well, even though I'm switched out to the 380cc's. I don't have the Walboro 255 installed either since, the one I have didn't come with a strainer and I have to get one.
There's too many variables that we had to deal with in the short time span we had on the dyno to worry at that point about numbers. I will try again as soon as this is all worked out.
Old Jul 14, 2010 | 01:23 PM
  #264
Deckdout2's Avatar
Play with my balls
Note: I'm going down the 1/4 tonight though, as she stands to see what times she'll pull. Will update once I return.
Old Jul 14, 2010 | 01:44 PM
  #265
t6378tp's Avatar
Turbo 3.5
are worried about the e85 eating up your fuel system
I think you need about 25% more fuel when running e85 to make the same power with 93octane but don't quote me. So going by that its safe to say on e85 and at your current power level you should be or very close to maxing out a stock pump on 93octane gas let only e85
good luck at the track
Old Jul 14, 2010 | 01:50 PM
  #266
ajcool2's Avatar
Goodluck. Hopefully those issues dont hurt your time to much.
Old Jul 14, 2010 | 01:59 PM
  #267
RedBeauty84ZX's Avatar
This is a huge misconception with E85, running E85 on a fuel system not originally designed for ethanol isnt going to do anything. TONs of people are running E85 on older fuel systems and I have never heard of anyone having any problems with it "eating" away at parts. Maybe after 100K+ miles and YEARs of driving will you notice something, and even then I doubt it.
Its baout 30% more fuel needed to make the same power, but its also a lot cheaper then 93 octane and a lot higher octane at about 104-106 octane.
Old Jul 14, 2010 | 04:08 PM
  #268
tuko316's Avatar
good luck at the track.
Old Jul 14, 2010 | 04:24 PM
  #269
datdude20's Avatar
p0011 or p0021??? .....man im having the same issue. the first time it happend to me because my timing chain skipped a tooth because the timing chain tensioners were bad. the second time it happend was because i had a bad cam sensor. if i was u i check the vtc solenoids and cam sensors first. if those are good then your going to have to take off the timing cover and make sure the timing chain didnt skip...... Goodluck
Old Jul 14, 2010 | 05:49 PM
  #270
tookrzy4u192's Avatar
I wanna see track numbers! Hope you get those issues fixed soon
Old Jul 15, 2010 | 05:17 AM
  #271
Shift_Max's Avatar
Can you shed some more light on your fuel corrections issue?
Old Jul 15, 2010 | 05:30 AM
  #272
321VQ35MAX's Avatar
How did she do?
Old Jul 15, 2010 | 06:01 AM
  #273
Deckdout2's Avatar
Play with my balls
It's been confirmed that whatever is going on with the car has put a wrench in the performance. Great launches......great shifts......full interior+sub (issue).......19" Volks (issue).........210+ coolant temps (issue).......hot as sin even at 8pm (issue).......14.008 @ 102......effin horrible! Got to run twice, and that was the best of the 2. I know everyone's hung on numbers at this point, but it's not my main focus at this time. I just need this thing to run flawlessly.
I'm really leaning towards pulling the timing chain cover and double checking to make sure the timing is still lined up on this thing. We're going to look at one more thing before we do that though. I've swapped over fairly new cam shaft position sensors in both heads, and I'm still pulling the cam over advancing code. Now I've got a misfire code and an o2 code, which might or might not be related. The o2 code is probably from the fuel mixture since it's tune to 100% E85 at the moment, but it might not like that gas.
The issues pertaining to fuel corrections is just that. No matter how much we add or take away fuel, the changes don't "seem" like it's sticking and/or getting mixed results on the same corrections, tuning on 93 Octane was worse (we blamed the heat). The curves in the same spots didn't look like they were changing much if any, like the Utec wasn't doing it's job. I'm not sure what's going on with this thing at the moment. I just know it's getting a little irritating, and I hate the Utec and the BS that comes with it. I'm ready to dump more cash and switch to another fuel management system. Utec provides minimal support, and their interface is outdated for what I need. Sure if I only had all the boltons, and just wanted to make "simple" fuel corrections, I think this would pull out all the hidden power. It just seems to be a very finicky unit to use, and the communication between that and the tuner bugs the hell outta me.
These issues were warned to me when I started this build, and it takes time to get them right, so I knew this walking in. I'm just rambling at this point. I know it'll all get ironed out at the end. I'm just need to learn to not be so impatient I guess.
Old Jul 15, 2010 | 06:55 AM
  #274
NmexMAX's Avatar
dot dot dot ...
Is the UTEC pre or post ECU, as in will the Cipher log the actual timing curves?
Old Jul 15, 2010 | 07:52 AM
  #275
ajcool2's Avatar
Thats crazy another memeber on another maxima forum is having the same issue with his Utec. He said he was going to try switching to a 350Z MAF.
Post #229
http://www.nycmaximas.org/showthread...page=6post=229
Old Jul 15, 2010 | 08:02 AM
  #276
Aaron92SE's Avatar
NWP Engineering.com
My UTEC fuel correction sucks too! I will spend hours tuning the AFR perfectly at 13.0. Then a month or two later, I find my AFR will be 11.5 in some areas of the map and 13.5 in another area. I've been having this problem constantly since the first day I installed my first UTEC. I have tried over 3 different UTECs too. So I have to tune my fuel every month or so if I want to keep it reasonable.
The only good thing about this system is that when you tell it to run a certain ignition timing, it runs it!
Old Jul 15, 2010 | 08:19 AM
  #277
ajcool2's Avatar
This is the same issue alot of the Z and G guys have and one of the reasons I sold mine before I installed it. I had a friend that lost his $600 tune out of the blue on his G and that was enough for me.
Old Jul 15, 2010 | 08:54 AM
  #278
Aaron92SE's Avatar
NWP Engineering.com
I spent a few hundred for tuning on a dynojet. Even though the AFR is completely screwed up now, I don't feel like it was a complete waste since I now know exactly what ignition timing is best for my engine with a smooth 12.8-13.0 AFR. So now, I just do a few street pulls in 2nd gear and get it back to normal before a heads up drag event.
I would love to be able to get the Osiris working with a Z33 ECU. It will happen soon.
Old Jul 15, 2010 | 09:11 AM
  #279
datdude20's Avatar
I'm almost certain The timinig is off..I was having the same issue
Old Jul 15, 2010 | 09:12 AM
  #280
Deckdout2's Avatar
Play with my balls
I'm glad to see I'm not the only one having this issue, not to say that I'm happy about that fact for myself or others. It just takes away alot of doubt that something we were doing was not correct.
I highly second the Osiris option!
aj- Read your link also, and I'm starting to see a pattern with this UTEC now.
