Sponsored by:
Sponsored by: CARiD
1st Fully Built 5.5Gen - NA
Old Jul 15, 2010 | 09:13 AM
  #281
Deckdout2's Avatar
Play with my balls
Originally Posted by datdude20
I'm almost certain The timinig is off..I was having the same issue
We're going to check that asap as well. Thanks for the assist!
Old Jul 15, 2010 | 09:50 AM
  #282
Shift_Max's Avatar
Is Uprev the only thing that would work as a replacement to the Utec? What about Haltech even though the price of it is so much higher.
Old Jul 15, 2010 | 10:08 AM
  #283
Deckdout2's Avatar
Play with my balls
That's another option, but as you said it will be costly. I could do a Greddy Blue, and a V-Manage as well. However the most viable options that would be perfect for feature packed would be the Haltech, Osiris, and (supposedly) this UTEC. I think however the UTEC is very much geared towards FI cars.
Old Jul 15, 2010 | 02:08 PM
  #284
t6378tp's Avatar
Turbo 3.5
You'll need to run a 04+ ecu to use Osiris the 95-03 ecu's do not have enough memory. I have this system on my G35 and have been kicking around the idea of a full 04 maxima or 350Z ecu 3.5swap in my 4gen so I can use Osiris in that too
Old Jul 17, 2010 | 10:09 PM
  #285
CMax03's Avatar
Originally Posted by Aaron92SE
My UTEC fuel correction sucks too! I will spend hours tuning the AFR perfectly at 13.0. Then a month or two later, I find my AFR will be 11.5 in some areas of the map and 13.5 in another area. I've been having this problem constantly since the first day I installed my first UTEC. I have tried over 3 different UTECs too. So I have to tune my fuel every month or so if I want to keep it reasonable.
The only good thing about this system is that when you tell it to run a certain ignition timing, it runs it!
That sucks but practice makes perfect!
Old Jul 21, 2010 | 06:58 AM
  #286
wakebord99's Avatar
I've been following the progress since the 1st post and it sounds like you are going about the whole process correctly.
I have some experience with engine builds/ecu mods as I fully built my 97' eclipse 420A into a 400+ HP turbocharged monster. After 1 year and 16k+ down the drain i sold it due to reliability issues. I hope you have better support than I do!
I'm looking forward to hearing how your able to resolve your current concerns.
Old Jul 21, 2010 | 08:27 AM
  #287
NmexMAX's Avatar
dot dot dot ...
So, did you use a UTEC, or was that just a random post?
Old Jul 24, 2010 | 09:52 AM
  #288
Deckdout2's Avatar
Play with my balls
Baseline Run no tune 14.008@102
http://www.youtube.com/watch?v=VuyF4W1SEhE
Another run
http://www.youtube.com/watch?v=pvzwjJMoiAw
Old Jul 24, 2010 | 10:23 AM
  #289
tookrzy4u192's Avatar
what was your 60'? nice run.. when are you going back after it's tuned?
Old Jul 24, 2010 | 10:29 AM
  #290
Deckdout2's Avatar
Play with my balls
Horrible. 2.3's It's all street prepped. No weight removed and on 19" street tires. I need to get some lightweight wheels and drag radials.
Just bought a house so I might not be able to until I get settled in, also that day was the last day for TNT here so I might have to go some where else with different track conditions.
Old Jul 24, 2010 | 04:22 PM
  #291
krazy6's Avatar
What was your 1/8 mile ET and MPH?
Old Jul 26, 2010 | 12:40 AM
  #292
505max94se's Avatar
Old Jul 26, 2010 | 06:01 AM
  #293
Deckdout2's Avatar
Play with my balls
Originally Posted by 505max94se
Gotta find my time slip in the mess of all this moving. Will post when/if I locate it.
Old Jul 26, 2010 | 09:14 AM
  #294
Shift_Max's Avatar
Might be off topic but what is stopping users to swap over to an 04+ecu on the 5.5 gen?
BTW do you mind posting a pic of your fuel corrections tables? Just out of curiosity.
Old Jul 26, 2010 | 09:29 AM
  #295
ajcool2's Avatar
Wiring.
Old Jul 26, 2010 | 03:17 PM
  #296
krazy6's Avatar
Cool, thanks man!
Old Aug 2, 2010 | 12:35 AM
  #297
MIKERNM1990's Avatar
ur time slip look horrible maybe clutch have slip?
Old Aug 2, 2010 | 04:53 AM
  #298
datdude20's Avatar
the car is not 100% YET
Old Aug 3, 2010 | 06:42 PM
  #299
niceguy's Avatar
Nice job so far....from the video, it almost looked like the Civic had caught up but then when the times posted, he was nowhere close....if you pulled a 2.3 on that run, then a better 60' would put you where, around 13.6/13.7s perhaps?
Keep up the good work...have fun finding time for anything once you start moving in (one of the spare bedrooms still had stuff boxed up after a year!)
Jeremy
Old Aug 3, 2010 | 07:20 PM
  #300
datdude20's Avatar
Jeremy
His car shouldn't run a 13 anything.
Old Aug 4, 2010 | 02:35 PM
  #301
jkpgt96's Avatar
^^This...looking forward to seeing the numbers out of it that we should get to see!
Old Aug 6, 2010 | 09:57 AM
  #302
HotshotVQ35's Avatar
agreed fully built 3.5 should easy be in the 12s. the 60' isnt THAT bad, but even if he got a 1.8 on slicks this is only a mid 13 sec car, hopefully a good tune will yield some good power, as the trap isnt that good either. either way props on a nice build...
Old Aug 6, 2010 | 07:09 PM
  #303
niceguy's Avatar
That was my point as well and I admire your patience and commitment to the project...
Old Aug 6, 2010 | 08:12 PM
  #304
MoncefA33's Avatar
A tune is the key to his power, considering timing/rev limit have not been optimized for those cams.
Old Aug 6, 2010 | 08:36 PM
  #305
datdude20's Avatar
after figures out y he getting a timing over advanced code. likei said before ...the timing chain might have skipped 1 or 2 teeth. The same thing happened to me. Once i got that issue my car ran hard as shznit
Old Aug 6, 2010 | 08:49 PM
  #306
MoncefA33's Avatar
Oops I missed that post. Yeah check this first...
Old Aug 7, 2010 | 09:33 AM
  #307
Deckdout2's Avatar
Play with my balls
That's what I'm hoping for, is that my timing chain skipped teeth. It would solve alot of unanswered issues for me right now, and more then likely be done with the car at that point.
I just moved out last weekend, and living out of a suitcase for the next 4 months till my house is finished being built will be no fun. The car should go into Matt's garage in the next couple of weeks so he can tear it down again and realign the timing chain, then back on the tune. We'll hope to see what happens here shortly. Haven't thrown in the towel quite yet, but have been very close to. arrrgh!
Old Aug 8, 2010 | 06:10 AM
  #308
datdude20's Avatar
Naw don't even think about throwing the towel in.. U have done way to much to do that
Old Aug 8, 2010 | 06:13 AM
  #309
datdude20's Avatar
What check enginge codes were u getting again
Old Aug 9, 2010 | 03:56 PM
  #310
nismology's Avatar
Old Aug 9, 2010 | 10:09 PM
  #311
Deckdout2's Avatar
Play with my balls
Cam timing over advanced, Misfire in cylinder 2 I believe (coil I assume), o2 sensor (doesn't like E85 I'm guessing, or Sim is dead), don't remember the last one, I need to read it again with the Cipher.
Originally Posted by nismology
Old Aug 10, 2010 | 04:55 AM
  #312
Shift_Max's Avatar
I had a question regarding the utec. Where is yours mounted? Reason being is the actual body of the utec grounded as well as the ground wire on that molex connector?
Old Aug 10, 2010 | 07:47 AM
  #313
Deckdout2's Avatar
Play with my balls
Pics are in this thread. I'll have to check on the grounding of the body though. I don't recall, as I didn't install this myself and haven't followed the ground wire.
http://forums.maxima.org/all-motor/570679-utec.html
Old Aug 10, 2010 | 10:10 AM
  #314
datdude20's Avatar
P0021 or p0011
Check the vtc solenoids first...if its not those then be ready to take that timing cover off
Old Aug 10, 2010 | 10:29 AM
  #315
Deckdout2's Avatar
Play with my balls
P0021 or p0011
I want to say P0021, but I'll have to confirm that again as well.
I actually used the VTC Solenoids off my original motor when there were no codes for timing, so I'm almost positive that it's still in working order.
Old Aug 24, 2010 | 11:31 AM
  #316
why u not share to us for get whp number or dyno sheet? i hope maxima.org r interesting on your post for show to us for list of mod but u not give a whp number to us? and aaron did give to us 290 whp and jaypee did it. we really interesting on your 5.5 gen max is first built engine. we want to know about ur whp number?
Old Aug 24, 2010 | 01:13 PM
  #317
vastmax's Avatar
what....the....fck.....
Old Aug 24, 2010 | 01:27 PM
  #318
DrunkieTheBear's Avatar
Turbo'd Saab
GTFO NOOB!
Old Aug 25, 2010 | 01:05 PM
  #319
jkpgt96's Avatar
my brain hurts..
Old Aug 25, 2010 | 02:01 PM
  #320
Grand_hustle17's Avatar
yep
GTFO NOOB!
why is he a noob??? jaypee really did dyno 291whp with his setup which is waaay less than the OP's
