Sponsored by:
Sponsored by: CARiD
Russ's 00vi Swap
Old May 12, 2010 | 06:21 PM
  #81
hornepirate's Avatar
ah okay...do you know any reason why my OD light would blink at me when i put the car on the on position
Old May 12, 2010 | 06:23 PM
  #82
bamboomerang's Avatar
FWIW - it helps to have the throttle plate exposed when adjusting that screw. I had to turn it way more than expected to get it to an eyeballed A32 TB 'cold position'
The goal is to use the TB to supplement the IACV with air at startup, so open the plate to get the necessary air, and then calibrate the TPS - think of this as your cold start calibration). Then once it starts all the time and is DDable, tweak your idle (ie bring it down) by unplugging your TPS, and turning your IACV 1/4 a turn, repeat until desired warm idle is set - this is your 'warm' calibration.
Hold the TB in your hand while doing this, it's 4 easy bolts.
Old May 12, 2010 | 06:33 PM
  #83
what are you reffering to by bring my iacv down a quarter of a turn? im using an a33 IACV
Old May 13, 2010 | 02:06 PM
  #84
alright neve3r got around to calibrating the TPS last night but am gonna do it tonight. Double checked everything with a small metal strip to detect air leaks. everything is good and blew air through the brake booster and checked all 5 of my vacuum lines and none have any leaks and i sealed the brass fittings with silicone and double checked all of the intake assembly and what not
tonight in about an hour ill be setting the TPS and playing with the idle screw...i was a bit confused as what the haynes said...do i wanna test the volts on the brown or the gray plug?
Old May 13, 2010 | 02:46 PM
  #85
I meant generally, with the A32 valve, I couldn't get both a cold start and decent idle with the A33, so someone else would have to chime in on getting that setup working.
I forget which plug, the haynes has a pic and an illustration, I think the writeup even tells you which color the wires are coming off that plug, its all there.
Old May 13, 2010 | 02:49 PM
  #86
buttonhook's Avatar
is the resister unpluged
Old May 13, 2010 | 02:55 PM
  #87
ah okay and yeah i think my od light was blinking because of either the sensor being unplugged and or the fact that im a retard and left my obd2 scanner plugged in for 3 hours draining my battery even further haha
Old May 13, 2010 | 06:39 PM
  #88
im stumped I set the TPS to .52ohms closed throttle per Haynes manual and 3.92 WOT and still had a warm idle of 3K...cold start was good though started at 2k dropped to 1100rpm then shot up to 3k ...i played with idle screw and everything to no avail...unless i get any other hints or tips to get my crazy idle under control ill be removing it all tomorrow afternoon and probably get a mevi instead
Old May 14, 2010 | 02:33 PM
  #89
Did you drive the car around? How long has it run? How much did you open the screw on the TB? Are your throttle cables way too tight or caught on something? So I take it for some reason an A32 IACV isn't an option for you?
Old May 14, 2010 | 10:22 PM
  #90
checked and re checked everything and no a32 iacv not an option i needed the car running by today so i put everything back to stock...decided i needed dependability more than anything
im a bit bummed but it took me maybe a day or two to actually install taking a few hours here and there but i spent a week figuring and trouble shooting
Old Aug 9, 2010 | 10:19 AM
  #91
Well im starting Part two of this. My issue last time was that...well i ran out of time to figure out the warm Idle. Cold idled fine then shot straight to 3000rpms steady
this time im using a 4th gen IACV and will be making my own block plates for the EGR, 5th gen tb
deciding if i should not run coolant through the 5th gen throttle body since i will have no IACV. I could use some input
Install will be next week sometime
Old Aug 9, 2010 | 10:27 AM
  #92
Bypass the coolant - it serves no function without that TB mounted iacv.
Old Aug 9, 2010 | 12:52 PM
  #93
ajcool2's Avatar
+1
Im guessing you found a throttlebody already? I have another one without the IACV.
Old Aug 9, 2010 | 08:33 PM
  #94
Yeah man i picked one up for $30 i just need to make the block plates myself but i appreciate AJ
that works ill just bypass the coolant then lol
Old Aug 9, 2010 | 10:12 PM
  #95
96nismoSE's Avatar
let me know if you need help again.
Old Aug 10, 2010 | 10:53 PM
  #96
Will do guys. always appreciate the input.
My vacation got push forward a week so ill be starting a little tomorrow and doing the majority of it on thursday and friday.
tomorrow ill be wiring up a harness and my summit switch set at 4800.
thursday ill be grinding down the coil bosses and the coil packs as well as reloacting the PCV valve using a 90* bend. Making an IACV block plate and an EGR block plate
Friday i will be doing the install
the LIM is already drilled and my EGR is already bypassed and so are the coolant lines...
hopefully it will be a simple clean install
**excuse my post 14 hour shift grammar
Old Aug 11, 2010 | 06:28 AM
  #97
you don't have to modify the coil packs - mine are stock and I can R'n'R them with the UIM installed, or I can R'n'R the UIM with the coils in.
Old Aug 11, 2010 | 07:28 AM
  #98
using the 4th gen rear valve cover?
Old Aug 11, 2010 | 08:08 AM
  #99
4th gen rear valve cover - same setup as you. Shaved the bosses pretty far down though, I think I had to add some material from a pinhole that started. Ran a hose under the UIM with a modified heater elbow (glued into two hacked pcv valve ends in stock location) with the valve up near the firewall and it works w/out incident
Old Aug 11, 2010 | 09:05 AM
  #100
the 4th gen coils just fit right in with the shaved bosses no issue? did you shave down the front and rear bosses or only the rear?
Old Aug 11, 2010 | 12:47 PM
  #101
Only two of them, the 'front' two on the rear cover closest to the driver side. Do what you need to, I just cut and test fit and thats all that was necessary for my application so I moved on.
Old Aug 11, 2010 | 01:12 PM
  #102
alright that works...ill be doing all the small customizing tomorrow and ill keep it updated and let everyone know the progress
Old Aug 11, 2010 | 05:19 PM
  #103
thats the size of my IACV adapter...is the brass nipple big enough for the IACV?
Old Aug 11, 2010 | 06:25 PM
  #104
I went with 3/4 inch, but whatever. Bigger is better considering the stock a32 IACV is mounted on the UIM. If theres a cold start issue open up the throttle plate a touch (calibrate the TPS at the WOT setting so little adjustments will be fine) - that fitting should be big enough to allow sufficient bypass air at idle, though. Once you get stuff installed and you think that hose's size 'might' be a variable, just don't start maxing out the idle air control screw in either direction, its best to keep it somewhere in the middle and get the TB setting tweaked.
You don't need an IACV, so just get the TB somewhere in the ballpark range and the computer will help smooth out the idle/dashpot, then make small adjustments from there.
Old Aug 11, 2010 | 07:35 PM
  #105
alright thatll work
Old Aug 12, 2010 | 08:02 AM
  #106
alright well last night i didnt get anything done so today im going to be modifying all the small things im on m way to ace to pick a 1/2" brass nipple for the iacv and a couple misc bolts ill need as well as a couple aluminum plates to make a block of plate for the TB and EGR. Ill be grinding down the coil bosses and what not.
Old Aug 12, 2010 | 05:42 PM
  #107
So update for today. I got my block off plates made for the Throttle body and EGR. Made the 1/2 brass fitting for the UIM Drilled my LIM and got some M8 inserts plugged in for the M6x120 bolts so i can tape those inserts. And ground down the towers a bit on the uim so I can give myself an extra 10mm for the Bolts.
Im using the 5th gen IACV port box looking thing for my Coolant I dont wanna buy a hose for it so I made a block plate for it and ran the coolant into it. never saw the done before when it was completely separate from the Throttle body so figured id do it. I would leave it attached but i would run into clearance issues.
On tabs for tomorrow. ACE hardware run to pick a 90* brass fitting so I can re route the PCV valve. Im gonna plug the 90* fitting into the rear valve cover and put the PCV valve in the middle of the hose somewhere. Any feed back on this Idea???
Also, tomorrow i will finish cutting down the Coil bosses im cutting an inch and a half off of them and will go from there, Then do the test fitting for the UIM and cutting holes for the two outer bolts.
Hoping to finish it up tomorrow night ish and hope that itll fire right up and run good!
  #108
sorry about the mini Essay!
Old Aug 13, 2010 | 12:54 PM
  #109
I re routed the PCV valve today and made some better plates for the tb and IACV but the Rear valve cover is a pain. I exposed the top of it a bit. what the best way to seal it up?
Old Aug 13, 2010 | 04:03 PM
  #110
nvmd i jb welded some pennies the uim and it seals pretty good i just need to file down a couple of my block plates to make them sit properly then bolt on the UIM tomorrow hope to have it running by tomorrow night or sunday afternoon
Old Aug 14, 2010 | 08:08 AM
  #111
Well im tired of using the A32 Rear cover so immaking a junkyard trip to find an A33 one if i dont find one ill just order it.
Old Aug 14, 2010 | 08:25 AM
  #112
Whats the problem? if you dont have a33 coils you might have to modify/rig something to make the a32 coils 'sit' in an a33 RVC
Old Aug 14, 2010 | 12:54 PM
  #113
problem is i dont have a spare rear cover and dont wanna cut them down any more so im just gonna get the rear cover and do it the right way its too much of a headache to do it with the 4th cover.
Old Aug 14, 2010 | 01:30 PM
  #114
??? just ground down the two bosses a little bit, takes 15 seconds with a grinder/cutoff wheel, then those two coils only get one bolt to hold them in, simple.
Old Aug 14, 2010 | 06:31 PM
  #115
i need to go pick up a grinder or cut off wheel. I have a small dremel and its not doing the job lol
Old Aug 30, 2010 | 08:34 AM
  #116
small update...after running into snag after snag and deciding to never use the 5th gen IACV again im coming along. I got my EGR tube cut and welded closed so that i no longer to worry about that being a clearance issue. 4th gen rear cover is completely cut down to specs...and i believe to have fixed my coil misfiring issues and O2 issues...
im going to wait at least a month before i go back to installing the 00vi due to it being about 105 here. will update as needed
in the mean time im gonna plan out a pcv bypass and a slight port/polish on the intake side (rough but no incredibly rough) do the VIAS fix before hand and paint the 00vi. all other pre install prep has been completed. including wiring up a vias harness to the summit rpm switch
Old Dec 27, 2010 | 08:43 PM
  #117
Well Today I started to put the 00vi with a guy who i have been working with (professional nissan tech) and we got the car up and running tonight idles between 900-1050 in Park/nuetral and about 600-700 in drive and reverse
car runs great with very little issues so far only thing changed from the previous setups was the use of a IACV adapter and my own custom block plates for the car videos will be posted as well as pictures in the near future
on a side note last time in august i tried doing the install it was 105 ...now its about 33 degrees in south florida...absolutely freezing for me
Old Dec 27, 2010 | 09:03 PM
  #118
I'm so happy you got this done bro. Wish I coulda been there to help and see it run.
Old Feb 6, 2012 | 02:32 AM
  #119
wranglerwheelmaxima's Avatar
when you are adjusting the IACV and the tps is disconnected the car should be off or running?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
